cox engines props Cox_ba12
cox engines props Pixel
by roddie Today at 8:48 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by rdw777 Today at 10:28 am
» Octura engines?
» Tatone EM-7
cox engines props Empty
cox engines props
cox engines props Empty cox engines props
Post  cjuliano Thu May 17, 2012 6:27 pm
what would be better a smaller prop or larger on a stander stock .049 ?
cjuliano
cjuliano
Bronze Member
Bronze Member
cox engines props Empty Re: cox engines props
Post  EXModelEngines Thu May 17, 2012 6:38 pm
It depends on the particular application.
I'd usually recommend a 5x3 or 6x3 prop. The 6x3 may be better for slower, 'sport' flying be it control line or R/C. The 5x3 is a good all around propeller, and is available in a basic variety as well as a competition series.
Regards, Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  Admin Thu May 17, 2012 6:46 pm
I Agree With Above with Matt, it depends on the application. I usually run 5x3s but I have played with the 5x4s, 6x3s, 6x4s, 5.5x3s as will as some 3 bladed props (not so easy to get these days) on my .049s
Post  cjuliano Thu May 17, 2012 6:47 pm
my friend has a three blade prop that he is going to give me.
how are those
cjuliano
cjuliano
Bronze Member
Bronze Member
Post  EXModelEngines Thu May 17, 2012 7:00 pm
A 3-blade isn't a bad prop in the right application, but they usually restrict power in .049's in my opinion.
If its an aircraft where power will not be an issue then a 3-blade will work fine.
What are you looking to do with your engine?
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  RknRusty Thu May 17, 2012 9:49 pm
I think the 3 blade props cavitate at the comparatively extreme RPM model engines turn, thus the power loss.
Post  dinsdale Fri May 18, 2012 12:42 am
3 blade props:
http://coxengines.eu/parts.html
http://www.wightsmodelaircraft.com.au/wmaPropellers.html
http://coxengines.ca/propellers/
http://stores.ebay.com/Model-Engines-and-Parts-Warehouse/Cox-Propeller-/_i.html?_fsub=200584017&_sid=2265057&_trksid=p4634.c0.m322
http://masterairscrew.com/3-bladeseries.aspx
dinsdale
dinsdale
Account Deactivated by Owner
Post  John Goddard Thu May 24, 2012 2:36 am
RknRusty wrote:I think the 3 blade props cavitate at the comparatively extreme RPM model engines turn, thus the power loss.
Ya got me Rusty
Huh...
John Goddard
John Goddard
Post  John Goddard Thu May 24, 2012 2:43 am
cjuliano wrote:what would be better a smaller prop or larger on a stander stock .049 ?
As above CJ depends on what model and What you want it to do.
Easiest way to imagine it is the bigger a prop is, is akin to a higher
Gear on your car or cycle. Low gear great for quick getaway and going
Up a hill. High gear not much fun going up a hill but fast going
Down.
Very Happy
John Goddard
John Goddard
Post  nitroairplane Thu May 24, 2012 5:15 am
Sorta but that being said, why do 3Ders use late diameter low pitch props?
Because they climb better.
nitroairplane
nitroairplane
Post  John Goddard Thu May 24, 2012 8:14 am
nitroairplane wrote:Sorta but that being said, why do 3Ders use late diameter low pitch props?
Exactly because it's like being in first gear all the time.
If you get into trouble you just open the throttle and point the
Nose up. Also coming down they act like a brake.
On my QQYAK I run an APC 16x4 Wide, on the down lines
You can actually hear the hisssss as the prop slows the
Thing down.
Very Happy
John Goddard
John Goddard
