» Cox 020 PeeWee rebuild questions by 706jim Today at 9:32 pm
by roddie Today at 8:48 pm
by 1975 control line guy Today at 8:05 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by Levent Suberk Today at 2:10 pm
by rdw777 Today at 10:28 am
by layback209 Today at 1:20 am
by rsv1cox Yesterday at 6:55 pm
by roddie Yesterday at 6:20 pm
by roddie Yesterday at 3:27 pm
» Octura engines?
by UncleLumpy Yesterday at 8:16 am
» Tatone EM-7
by sosam117 Yesterday at 7:50 am
Cox Black Widow .049 Question?
Hi lads,
Would you guys fit it with a 1702 high compression head for better performance?
plus it looks great with it. I want the inside to have some serious RPM`s!!!
I plan to run it on 1/2 A fuel and a Cox 5x3 or 4.5x4 Thimble Drome prop. (Competition Series)
Cox Factory Parts Cat. #1702 .049/.051 Glow Head High Compression $12.59
Mr G
Mr G
coxxoc- Gold Member
Re: Cox Black Widow .049 Question?
Depends how much you have burning a hole in your pocket
G.
If you look at my thread Raw Power which started life as a bit
Of a leg pull, it'll give you links to my utube.
Several bucks And blown up engines later I've got a reliable
(talk about tempting fate) 22,000 rpm out of a bee type motor.
It's all available from Bernie at Cox ca int and using freshly made
Fuel I know there's more to come.
Best
J
To answer your question
Yes you'll get at least 500 increase prob more
Don't forget though, add one head gasket for every
10% nitro
Pps
If you search black widow using the search function on the home page
Rusty has just about the most definitive 'how to'
With the B/W
G.
Best
J
10% nitro
Pps
With the B/W
John Goddard- Diamond Member
The racers are mostly the only ones that use a smaller than 5" props on a BW, and those engines are expected to be spent after a short life. The fastest turning props I've ever seen are APCs. My hotrod BW turns a 6x2 APC over 20,000 RPM on the bench. I just have a standard Bee crank in it.
APC 5.5x2 - 21,500
APC 5.5x2.5 - 18,300
APC 6x2 - 20,300
Master Airscrew 6x3 - 16,300
APC 5.5x2 - 21,500
APC 6x2 - 20,300
I had a considerable decrease in RPM when I used a 1702 head on my Killer Bee. The standard head seemed to do fine. Maybe my 1702 is bad.
Thanks Rusty, John and microflitedude
Mr G
Mr G
coxxoc- Gold Member
If it glows and doesn't leak compression, it should work. I put Bernie's 5 fin high compression heads on my almost-Killer Bee and my Black Widow and it woke both of them up considerably. I'm using about 3 shims. I run Glowplugboy fuel with extra castor in everything now. It continues to run smoother and needle better than Sig 25 and 35. Even the Tee Dee on the pressure bladder likes the GPBoy fuel.microflitedude wrote:I had a considerable decrease in RPM when I used a 1702 head on my Killer Bee. The standard head seemed to do fine. Maybe my 1702 is bad.
And, you're quite welcome Coxx
The Killer Bee originally came with a 1702 head! Try a different 1702.
Well, all of my Black Widows have high comp 1702 heads on them. They originally came with a 325 standard head. My black widows all seem to run great with a high compression head, they also run fine with a 325 head.
Thanks Rusty and Admin!
Mr G
Mr G
coxxoc- Gold Member
» Black Widow Question
» black widow Question
» Black Widow?
» Black Widow backplate question
» Black Widow?
