» Tribute Shoestring buildby 944_Jim Yesterday at 11:00 pm
by GallopingGhostler Yesterday at 7:39 pm
by roddie Yesterday at 7:14 pm
by rdw777 Yesterday at 6:58 pm
by LooseSpinner99 Thu Nov 14, 2024 4:38 pm
by Kim Thu Nov 14, 2024 3:28 pm
by bsadonkill Thu Nov 14, 2024 1:19 pm
by Levent Suberk Thu Nov 14, 2024 11:39 am
by rdw777 Thu Nov 14, 2024 11:24 am
» Pathé Modeling Videos
Fuel line Pinch Off?
Re: Fuel line Pinch Off?
Pinch of? It's not a kind of clip that closes the gas Line ??
davidll1984- Diamond Member
I suppose it could be. I did have a line clip on the fuel line prior to the set up i have now, but i took it off.davidll1984 wrote:Pinch of? It's not a kind of clip that closes the gas Line ??
kevin king- Silver Member
Me personally I don't use that I always empty the tank I rinse the gas lines with metilhidrate befor storage
For fuel cut off:
https://www.amazon.com/X-DREE-Nitro-Tubing-Clamp-Aircraft/dp/B096PJB6M2
For securing fuel lines:
https://www.dubro.com/products/fuel-line-clips
Levent Suberk- Diamond Member
Kevin, here's what I use. The key to quick successful runs is to make this easy. Most of my setups, I use the colored pinch offs I made in the picture. These are extremely light. I clip one on, I prime, flip, and pull it off. I use these the majority of the time. I also bent the wire style which I still use as well. This uses a engine bolt and I slide it into the U shape which pinches it, I prime, flip and with my holding hand, Iuse my thumb and flip it out of the U. I can start a engine in less than 3 seconds with my method once set.
Achieving a close needle initially is the utmost importance. Once the bladder is full, bleed out the air. I do this by pointing the nose up and the venturi to the ground. This was you don't even have to worry about the crank window on the crankshaft, the fuel will go straight to the ground and not into the case. A surge of air will come out and some gurgling prior to the stream. You want to close the needle so that fuel is not pouring out but dripping. Watch the drops and space them approx 3/4" apart using the needle.
Pinch off the fuel line and your just about ready. Prime the cylinder and hook up the battery. Flip and burn off the prime you just placed. Once everything is cleared. Prime again, flip and once the engine is running, open the pinchers. If the engine goes too rich, close the pinchers slightly until you can close the needle. If the engine is too lean, the engine will surge back and forth revving up and then slowing down . If this happens, the needle needs to be opened. YOU CAN"T RUN A ENGINE TOO LEAN ON BLADDER so don't worry about that. To achieve the proper setting on bladder is to lean the engine up. Quickly pinch the fuel line with your finger, if the engine wants to quit, the setting is too lean, if the engine speeds up, your just right. Keep leaning and pinching until the engine wants to quit and back it off a little and launch.
This is the wire style I bent up, I don't care to have line clips hanging onto my fuel line.
These are my pinch off devices I made from basswood and a sewing bobbin in the center. I just use rubber bands. TO prevent the tubing from slipping out of the jaws, I glue some sandpaper on them
Damn thats some good info, Thank you!
» Fuel line that stays on a td fuel niibble
» .010 fuel line
» FUEL LINE QUESTION
» Fuel line dimensions
» Cox Engine Fuel Line Size?
» .010 fuel line
