» Tribute Shoestring buildby Oldenginerod Today at 9:38 pm
by GallopingGhostler Today at 7:39 pm
by roddie Today at 7:14 pm
by rdw777 Today at 6:58 pm
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Tribute Shoestring build
yes , I sprayed it with Windexticomareado wrote:Also, you really need to get your engine mount set up with blind nuts in place before doing the other stuff I mentioned. If in doubt about balance, go a little nose heavy--much easier to add tail weight.
Did you apply the silkspan wet ? Minor wrinkles can be dealt with (usually self-correct) in later coats of clear dope.
akjgardner- Diamond Member
Looking great! I am green with envy!
"yes , I sprayed it with Windex' -- Well, whatever you do, don't drink any disinfectant; I don't care what the media says Orange Man said.
Looking Good Joe !! I think its 3 coats of dope in all that needs to bee applied (been awhile ) And some light very fine paper sanding (600G) at least, bee sure to wipe it down before applying next coat to get rid of the debris .
The silkspan is going to need butyrate dope on top as nitrate is not fuel proof. Sig Supercoat clear is high shrink which will tighten up the wrinkles better than the nitrate. I personally would have at least 2-3 more coats of butyrate sanded in between prior to color. Sig Supercoat colors are low shrink dope which will slow the shrinking process down.
Thanks for all the help guys. as iv'e not done much silkspan/tissue.
When you do use butyrate, don't puddle it in any intersections, ( fuse joint, stab joint ). It can form a blister which isn't easy to repair.
Looks good to me! Don’t sweat the small stuff. It’s gonna get scratched, oily and knocked around if you are doing it right.
You might want to add the vertical stab though
Looking good. How much tip weigh did you use ? Again looking great nice job
Onelife- Gold Member
thanks , can’t remember the tip weight , this was built a a few years ago .Onelife wrote:Looking good. How much tip weigh did you use ? Again looking great nice job
For a model this size, 5/8 oz. is more than adequate with steel lines. If your flying Spectra, you can reduce your weight to a 1/2 oz. I'm not a advocate of tip weight boxes. I find them to be more harmful then helpful in sport planes like these. In a mishap, the entire box can eject out of the wing doing some damage. I glue the tip weight generally nestles in between two intersecting areas and surround it with additional balsa. I take lead weights and flatten them paper thin and trim with scissors. I don't take a hunk of lead and just glue it in. I keep golfers lead ribbon with me which is a roll of thin lead. If I need more, I trim it, bend it in a U and install it on the outboard tip. Later on, I can weigh it and install into the tip if needed. To insure it stays in place, I bring packing tape with me and place a clean strip over it with the surface prepped with alcohol prior.
Hi Ken yea I never used the weight box either this is a old thread I just ran across I didn’t notice the date back the old shoestring didn’t have a weight box and even in the planes with it I generally do the same just glue weight on outboard wing. What caught my eye was the picture of the shoestring and the silkspan job It l don’t know if it’s the quality of picture or what but it almost looks like it’s Shellac and on nice and thick.
I know my shoestring never got flown the first thing was the Enya .29 ! , i don't know if its completely broken in but it was a PIA for a 13-15 yr. old without a elect. starter then I silked it and all done , then the control arm inside the wing came loose / off ?? So good thing i didn't fly it now its been sitting for years and if i do get around to fixing it i Will monacote it LOL Joe you get this project done ??
Lol Bummer
I haven’t flown it yet . It has some hanger rash from the move. I also wish I used monicote . The dope I used was old and gave it the dark look. I ended up painting it yellow . I’ve sense squired another one and will do a better job on it . I am planning on flying it this summer though.getback wrote:I know my shoestring never got flown the first thing was the Enya .29 ! , i don't know if its completely broken in but it was a PIA for a 13-15 yr. old without a elect. starter then I silked it and all done , then the control arm inside the wing came loose / off ?? So good thing i didn't fly it now its been sitting for years and if i do get around to fixing it i Will monacote it LOL Joe you get this project done ??
Sounds like a plan good deal. Do you have a engine for it
yes Kim was good enough to donate a McCoy 35. . I’ve never flown anything but 1/2 . But I’m looking forward to it .Onelife wrote:Sounds like a plan good deal. Do you have an engine for it ?
Good I was just going to offer you a Fox 35 I have some older ones but with very little run time I was going to do the same. You might find with the longer lines the bigger plane is easier to fly, more time for corrections.
I have a sig 1 2 a shoestring with a cox 049, that flies, but barely
amurphy6812- New Member
amurphy6812 wrote:I have a sig 1 2 a shoestring with a cox 049, that flies, but barely
What are you experiencing?
I'm only aware of one size Shoestring that SIG kits, and it's not 1/2A. SIG website says it should run a .15. That Reedie on the nose looks way too small.
Page 2 of 2 • 1, 2
» Back to the Yak - Yak-9 Build, Part II
» Tribute to 1505 East Warner Avenue
» Tribute to Mom (Cox employee in the early sixties)
» A tribute to John Brodak
Page 2 of 2
