Follow Rusty's Memorial Traveling Engines! - Page 2 Cox_ba12
Follow Rusty's Memorial Traveling Engines! - Page 2 Pixel
Follow Rusty's Memorial Traveling Engines! - Page 2 Empty
Page 2 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
020 Engine Re: Follow Rusty's Memorial Traveling Engines!
Post  Cribbs74 Sat Mar 27, 2021 7:58 pm
Ok,
I am going to send off the Engines this week. I was able to take the Fox .35 Super Clown and the Li’l Jumpin Bean out to the field this morning. The Fox definitely needs to be broken in more. Hopefully by the end of the list it will be! It kept going lean and cutting out on me, I finally got one half decent flight with it and even at that it didn’t like inverted flight. It’s a shaker too which compounds the issue.
The RR1 ran better, but I really wanted to use Rusty’s handle to fly it and it was set up for 40’ lines. Too much, it too didn’t like inverted.
However, I flew them. The cool little .020 will have to wait for the next guy to do something with it. Here are a couple pictures and a couple videos. No need to watch the whole 7 minutes of the Super Clown. It gets pretty boring as it wouldn’t do transitions and it was lean so I kind of just flew the tank out. Some stunts, but not many.
Follow Rusty's Memorial Traveling Engines! - Page 2 9b8a4110
Follow Rusty's Memorial Traveling Engines! - Page 2 Cd229310
Follow Rusty's Memorial Traveling Engines! - Page 2 1a64f210
Follow Rusty's Memorial Traveling Engines! - Page 2 5c8d0710
Follow Rusty's Memorial Traveling Engines! - Page 2 C7669d10
If anyone was a member from the beginning they will understand the significance of these two planes selected for Rusty’s memorial. Also if you look closely at the handle you can see why it can only be Rusty’s. Tight lines brother.
Edit: Forgot to mention, that’s Rusty’s prop on that Bean.
Post  Ken Cook Sun Mar 28, 2021 7:26 am
Nothing like a well seasoned Bean. My dad built his in 66 and I'm still flying it to this day even though pieces fall off of it now and then.
Post  getback Sun Mar 28, 2021 7:53 am
Clapping Clapping Clapping Not to bad of flights other than the cutting out/off .. Hate the Bean cut off so early . Paranoid
Post  rsv1cox Sun Mar 28, 2021 10:28 am
Heart stopping moment when the Fox cut out during a loop early in the flight. Amazed that it caught and continued on. Rusty would be proud. Nice flying Ron.
Post  Cribbs74 Sun Mar 28, 2021 2:48 pm
Yeah, both engines needed some fiddling. Nothing wrong with them though. If I had more time I could have made them run perfectly. I always harp about bench running and running in the air are two completely different things. This is a good example of that. Totally my fault though for not checking things out first. I bolted on and flew. You get out of it what you put into it!
Post  Admin Sun Mar 28, 2021 11:04 pm
I couldn't think of a better way to honor Rusty than putting a Clown and Bean in the air with his memorial traveling engines!   Great work Ron. Hand Shake
Post  Kim Sun Mar 28, 2021 11:42 pm
Yes, a good and fitting tribute to our great friend.  Rusty would approve.
Post  OVERLORD Mon Mar 29, 2021 1:12 am
Cribbs74 wrote:Yeah, both engines needed some fiddling. Nothing wrong with them though. If I had more time I could have made them run perfectly. I always harp about bench running and running in the air are two completely different things. This is a good example of that. Totally my fault though for not checking things out first. I bolted on and flew. You get out of it what you put into it!
Don't feel guilty. It's a great project!!
Post  Cribbs74 Fri Apr 16, 2021 11:08 pm
Engines left Oklahoma today on their way to Jacob. Thanks for the patience everyone.
Follow Rusty's Memorial Traveling Engines! - Page 2 36345a10
Post  Admin Tue Apr 20, 2021 1:55 am
The engines are here! cheers
Post  Admin Fri May 07, 2021 11:50 pm
I'm breaking my own rule by hanging onto these engines longer an a week. Sorry Kim. I got a chance to mount and run the RR-1 today after putting a piece of fuel tubing on the needle to help seal any air leaks. Initially, when I ran it last weekend, it was difficult to start and the needle was very touchy. It ran better this time, but still not as smooth as I would like. I'm sure Kim will get it to be perfect.
Post  Jason_WI Sat May 08, 2021 12:08 am
Seems strange. One drilled out backplate and one OEM RR-1 backplate and they both run like hammered crap. I never looked at the tip of the needle. Is it bent or broke off?
Jason_WI
Jason_WI
Post  Admin Sat May 08, 2021 2:02 am
Jason_WI wrote:Seems strange. One drilled out backplate and one OEM RR-1 backplate and they both run like hammered crap. I never looked at the tip of the needle. Is it bent or broke off?
No, the tip looks perfect. However, the needle seems excessively loose in the insert, the reason why I thought it could've been leaking air. I'll try a few different needles and see if the fit is better.
Post  getback Sat May 08, 2021 4:59 am
What? It was running a little funky when Ron had it too , but not that bad ? No Went back and looked at the vid. and mainly when inverted . Maybe it picked up a piece of dead grass ?
Post  Kim Sat May 08, 2021 6:18 am
Admin wrote:I'm breaking my own rule by hanging onto these engines longer an a week. Sorry Kim. I got a chance to mount and run the RR-1 today after putting a piece of fuel tubing on the needle to help seal any air leaks. Initially, when I ran it last weekend, it was difficult to start and the needle was very touchy. It ran better this time, but still not as smooth as I would like. I'm sure Kim will get it to be perfect.
Hey Jacob,
Take your time. I've got the planes picked out for the engines, and may pack them to Summer S.M.A.L.L. if the time frame works out.
Hope the RR-1 is feeling OK when it gets here...my trouble shooting will probably be limited to flushing and a few Voo Doo incantations!
Post  Cribbs74 Sat May 08, 2021 7:08 am
I never ran the drilled out backplate. Just the OEM one you sent after the fact. There is nothing to stress over and I wish I would have taken the time to look it over. Just too darn busy these days. Along the way it will get sorted out. In the air it flew well for several laps, inverted not so great, but kept running . When I did a tight loop it cut out. Too soon, yep, that has always been my experience with tanked bees. I have spent the time to make hard pickup lines, pressure testing, NV sealing and tank sealing. Even the best running ones seem to falter in the air. They run like a dream on level runs. Stunting has always been a pain for me with an integral tank.
I know it can be done, just haven’t mastered that yet. Ken seems to be able to make it happen. Again, the engine may need a couple tweaks. I can’t remember if I replaced the venturi seal or if I re-used what was in it or even looked to see if one was there at all. It may be a good starting point.
Post  Ken Cook Sat May 08, 2021 1:24 pm
Ron, it's been a painful journey. When you achieve Nirvana, it all goes south again.
Post  Admin Mon May 24, 2021 9:44 pm
Rusty's Traveling Engines are wrapping up their visit to Roseville. As probably the same for most of you, the RR-1 was the center of attention here. Mostly trying to iron out the kinks. Although I did have the .020 running for awhile. I would've ran the Fox if I could've gotten myself up to the task of rolling out my took cart that has all the larger engine mounts on it.
Follow Rusty's Memorial Traveling Engines! - Page 2 Img_4111
Follow Rusty's Memorial Traveling Engines! - Page 2 Travel11
Follow Rusty's Memorial Traveling Engines! - Page 2 Rusty_14
Here's Rusty's Traveling Engines with the original Traveling Propeller. Dead center on the signature card is Rusty's signature.
Post  Cribbs74 Tue May 25, 2021 9:54 am
I really wish I had something built for the .020.
I still have the Scarinzi Queen Bee and the little combat airframe, but both would need too much time to have made airworthy.
Glad you were able to have some fun Jacob.
Post  Kim Thu May 27, 2021 4:47 pm
Rusty's Engines and their support equipment arrived safely this afternoon!
I plan to take them to Summer S.M.A.L.L. this coming Tuesday, flying them at that wonderful event, and then get them on the road the following Monday.
My Plane List, at this point, is to fly the Fox on my Uncle Wayne's restored Goldberg Wittman "Buster":
Follow Rusty's Memorial Traveling Engines! - Page 2 000_9510
The .020 will fly in the Scientific "Kingpin" built and given to me by Breezy Hill Flyer Billy Lang:
Follow Rusty's Memorial Traveling Engines! - Page 2 Img_2310
The RR-1 will probably go on the Q-Tee...the second time the little parasol has been hauled aloft by such a cool engine:
Follow Rusty's Memorial Traveling Engines! - Page 2 2_169
And that's the PLAN at the moment!
Post  Cribbs74 Thu May 27, 2021 10:23 pm
Rock on with your bad self!
Post  Admin Thu May 27, 2021 11:42 pm
Good to hear they're safe and sound.
I can't wait to see what you do with them, your plan sounds good!
Post  Kim Sun Jun 06, 2021 7:17 pm
Just a check-in with Rusty's Engines.
Gonna need s few extra days. They all went with me to Summer S.M.A.L.L. All got a bench run on their respective planes, but only 2 actually flew...which I intend to remedy this week!
I want to do the whole thing in one post (which can be difficult for me and my need for rambling), and will the final flights and note writing in this week.
020 Engine Rusty's Traveling Engines
Post  Kim Mon Jun 14, 2021 10:49 am
So,
I'm on the verge of packing Rusty's Engines out to batjac Mark in Oregon, and STILL sifting through the footage and photos of their two-week+ visit with me.  They ALL got some flying time, and I'm very honored for the privilege of being part of this tribute.
I put in three last flights with the Fox .35 late yesterday, and am cleaning them a bit before they hit the road.
Got to write a few notes in the Log Book, and they'll be heading west.
My full set of notes will follow.
Thanks again to Jason, Jacob, and everybody participating in this salute to our bud!
Rusty's Fox .35 and Uncle Wayne's Goldberg "Buster" make some final laps at the end of the day:
Follow Rusty's Memorial Traveling Engines! - Page 2 41_16
Post  Marleysky Mon Jun 14, 2021 11:28 am
Perfect Photo!!
RC Plane
