by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Nead info on diesel engine irvine .40 and other stuf
davidll1984- Diamond Member
Re: Nead info on diesel engine irvine .40 and other stuf
Just want To warmly thank the kind person ho giving me is old stuf y have no words al that stuf wort Somting y wil take Good care of al is Nice gift To me Nice models engines very old in exceptionnel condition al working fine did Not try the diesel engine wil have To mix hihi smel like ether smel in the air
Just want convertion head for the irvine engine To run nitro ??? Is the le .40 head fit is wat y have in stock
The irvine engine is must be worth somting is new just by its look y new its Somting Good like the desing carburateur look very acurate stuf now now old is ????
Dont Find the webra engines info is it possible To converting head To nitro ??
The new cox engine is a runer dont have To fix befor its first start just aded fuel and is runing Perfect
Spectreflight carries a test report on the .20:
http://www.sceptreflight.com/Model%20Engine%20Tests/Irvine%2020%20ABC%20Diesel.html
The way I see the diesel and glow heads maybe interchangeable at least on the .20
K&B Torpedo .40 is practically indestructible. It's a Dykes ringed engine and many times the ring can get stuck. I use 50/50 castor synthetic to avoid that problem. Old school engine with plenty of power. The rear rotor version is a pretty hot engine and stronger yet as the crankshaft is solid.
Ken Cook wrote:K&B Torpedo .40 is practically indestructible. It's a Dykes ringed engine and many times the ring can get stuck. I use 50/50 castor synthetic to avoid that problem. Old school engine with plenty of power. The rear rotor version is a pretty hot engine and stronger yet as the crankshaft is solid.
Plus pretty much everything is still available for the Torp .40. The Dykes ring is pretty disconcerting. You turn the engine over and you think is has no compression, but give it a hard flick or hit it with a starter and they start & run great
Torpedo.40 is now redy internal parts ok ring is Not pointing in the same direction tink ring Not stuck on the first rotations it was ok now after bath in fuel and light runing in oil without the plug is lot of compression wit its plug is hard wit hand y Feel the ring turn slow To rotate 360" no prop on engine its mising its needle canot test y have parts from .40 os tink it can fit ?? Y have To Find it is deap in m'y junk stuf
Try To Find info video run of the webra mach || 2 if posible To convertir To nitro ?? Rare engine my is in Good chape Good compression no mising part next for clean up
Tink its cylinder is new look like new wit 1wrong Bolt tink after casing leak fix it wil run juste like new very strong compression wil buy componant for diesel model engines fuel
Have you used model diesel fuel before David? The biggest issue is going to be getting hold of some ether. If you can't find any, try your nearest John Deere dealer. They apparently have starting fluid which is almost straight ether. Other than that it's just kerosene and castor oil. equal parts.
The Webra is a Mach II. It's not easily converted to glow.
http://sceptreflight.com/Model%20Engine%20Tests/Webra%20Mach%20II%20%282%29.html
http://sceptreflight.com/Model%20Engine%20Tests/Webra%20Mach%20II.html
I think the Irvine 40 diesel was based on the Q40 glow. Some research on RCU should turn up the details.
Either would sell pretty quick if you didn't want them.
gkamysz- Gold Member
If canadien tire dont have it y be surprise ether is Not hard To Find y did try cox convertion head bent 1 piston con rod now wit webra tink wil have To try never fly on diesel just run couple minut cox .049 for the fun of runing witout glow plug tink of build plane for webra is like .15 ???? Nitro ???
Deere is the only starting ether that is virtually all ether. Others will contain as little as 30% ether with the balance heptane. You end up with much lass ether than you expect making for difficult to impossible starts.
The Webra is a strong running engine . It is 2.5 cc ( .15 cu. inches ) and was used for F.A.I. events like free flight , team racing and combat . It would be a sin to try and convert it to glow and is worth more as a diesel . I would like to have it if you want to sell or trade it .
Mike1484
Mike1484
Mike1484- Gold Member
dint no that is the ether in presurised can wit jon deere ?? I was using a bronwn can Not sur wat brand from carquest was tinking ether was pure its wy it was so hard To get it run haaaaa and for the other component want the best for best result ???
» Irvine 20 ABC Diesel/Glow special
» Engine trade --- A Cox diesel engine for an Enya .049 custom built?
» Does anyone have info about this engine?
» .020 engine info
» .020 engine info
