Length Of Control Line
Curious
I have not ever used longer than 60 feet (30 foot diameter) line on a control plane. It is working good. Does anyone ever have experience using longer lines and if so how long? I almost always have my wife hand launch my planes so not taking off from pavement.
The hand launch take off speed is important but if the CL was say 45 feet diameter would that still work well? I'm just too chicken to try and have an unfortunate........ meeting with the ground Work too hard on my planes to have them damaged unnecessarily.
Thanks
Iceberg
Thanks
Iceberg
Iceberg- Gold Member
Re: Length Of Control Line
This is all dependent upon the plane. Cox engines are not as powerful as modern equivalents such as Norvel equipment. Hand launching with longer length lines could result in a unwanted crash. I have to ask why you want to do this? Essentially, there's two reasons for going out longer, one being to slow the speed down and two is to allow more room for maneuvering. If your engine doesn't have any reserve of power left flying on the line length your currently using then your expecting too much from your model.
When I was using Tee Dee's for combat, they were starting to become handicapped on 42' lines. TD's originally flew AMA combat on 35' lines, they changed the rules when modern powerplants were introduced to go out to 42' to slow things down. This essentially put a end to using Cox equipment. Not only is it hard to start when hot, they flew poorly on this line length.
In addition, the line material is also a factor. Steels vs braided Spectra, Dacron, etc. Drag is everything, therefore the style and weight of the plane dictates the length. My flying field is 16' above sea level. I'm making top power compared to those in higher elevations. Some planes need to fly fast and going out on longer lines defeats this. I was flying a twin Mustang using Black Widows on .008" 52' steel lines ( A major pain in the you know what to take care of). I now have another twin I'm flying on 42' Spectra lines. A Norvel .061 for instance by itself can certainly muster up enough oomph to fly out to 50' on some models. If I was in need of going out longer flying integral tanked Bees, I wouldn't be pushing the envelope too far. I had many line sets that were made up to 37'-9". I don't recall my reasoning for this but I have about a dozen line sets made to this length. Your obviously going to reach a point where drag and power become a issue and this is usually around the 42' mark using Bees.
Hey Ice, Good points from Ken. Think about this; The 1st CEF C/L 1/2A Proto Reed Speed contest (2014) mandated a 42 foot line-set be used. That's an 84 foot diameter flight-circle. This length was later reduced to 35 feet in successive contests a few years later.. because contestants were having difficulty launching their airplanes. Models were required to have landing-gear and to rise-off-ground (R.O.G.) launch. The smaller diameter circle allowed the models to gain more line-tension sooner. This enabled more controlled taxiing.. until enough speed was gained to achieve "lift-off". It was a fly as fast and level as you can.. for X amount of laps contest. A qualifying run was submitted via video-recording the flight. Fun stuff!
You can, of course try whatever you want. We establish our own standards in this way.
While I have not tried it, I just want to bring this up. The Goldberg Lil Wizard was advertised to use 52' lines with a Cox Bee type engine. I have one with a different .049 and I believe I had tried 42', but it did not like it, so I could not imagine using longer lines. With that said, maybe it is possible for flight if built as light as possible.
Hi Ken & Roddie
I hear you guys. Thanks so much. I get great flights with the 30 foot radius No shortage of speed. I average about 55 MPH with some of my motors. There is not problem with maneuvers or anything really. Just was wondering if maybe the longer lines might be an idea.
I'll stick with my proven 30 foot radius lines. I get about 45 to 65 rounds per tank. I average the distance out at 206 foot per turn so 9270 feet to 13,390 feet per tank. I did the math I think in the neighborhood of 1250 M/P/G gallon. Although with no passengers or cargo I guess still an expensive and very dizzy trip!
Thanks again!!
Ice
Thanks again!!
Ice
Hey Ice, More than happy to help a fellow modeller. Trying different length lines (within a few feet) can be a good idea. A jump from 30 footers to 42 footers is too much of a jump.
I learned to fly my 1/2A C/L models on 25 foot lines.. because my yard at that time had just enough clearance for a 52 foot diameter circle. I'll tell you that a Cox PT19 Flight-Trainer fly's pretty good on 25 foot lines..!
It's great that your wife hand-launches for you. Now.. you need to teach her how to fuel, start and tune the engine.
Just kidding.. but have you looked into stooge-launching your models? A launching-stooge allows the pilot to release the model for flight from their control-position center-circle.
A model having a landing-gear can "taxi" upon release... until it gains enough speed to generate lift. A lightweight/well-balanced model will have a short roll-out.. and might be airborne in just a few feet. There are also stooges for models having no landing gear.. but the model needs to be "nimble" and the pilot skilled to achieve a successful launch.
Stooge-launching would open-up the opportunity for the wife to capture a video of the flight, along with the pre-flight activities if desired.
Ground-launch stooge:
https://youtu.be/9hfwlV3a9UY
Camera: my Android Moto-G
Ground-launch stooge in action:
https://youtu.be/osxQfIvjS3E
Camera: my $50 Canon Point and Shoot on a tripod
No wives were hurt or abused during the video recording sessions. I did clip off the very beginning trying to dial in the needle.
Oh, how I miss that plane! This is on 38' lines.
Hey Roddie I like the idea of having my wife fuel and start the planes. However sadly when I mentioned that to her she said "don't push it". And then she said I was calling her a stooge. I said NO NO that is the name of the launching device. Naturally no wife was hurt or abused.
I will keep working on the fueling and starting though!!
Iceberg
Iceberg
944_Jim wrote:Ground-launch stooge:
way-cool vids Jim!
Hi Jim ,
Nice video and a good set on the needle . Engine will last a long time on a good set . Thought that you were going to hit that pole on the right . Thanks for sharing .
Mike1484
Mike1484
Mike1484- Gold Member
Hi Mike,
I appreciate the encouragement! I hope someday soon to contact DPCModels for a reproduction in order to revisit this plane (he digitized it when I first bought it....just in case).
The light poles are farther apart than you may think. They are arranged in a square with about 140' per side. I sight the middle in between the diagonals, so that puts the distance from center to pole at about 90 feet (give or take...(70'x√2)). I did have to stay fairly close to center and remind myself that the Mossie flew on 50' lines, and had room for wandering quite a bit from center. Those poles looked a lot closer closer with that plane. This is the same facility:
Nice! CoOoOol vid! That Mossie was haulin' w/both engines on-song. Was it the outboard-engine that quit 1st at 00:1:13? No control issues and nice landing! I can only hope for as much with my P38.
Roddie,
I believe outboard died first. While flights were short, when it flew it WAS quite exciting! Mike Londke and I talked about the build just before I started it, specifically because I saw HIS BHM Mossie video. You HAVE to find that one!
Those Norvels spent more time on a test jig than in the air. Alas, that plane met the final war with concrete last December, damaging one engine for sure. I miss that plane!
I thought I posted the carnage here.
A Frog Mosquito reproduction kit is in the build room waiting for bench time. That one will be 36" with a built-up wing, profile fuselage, and a pair or Cox Medallions (so I could do the build log here). I had the short kit cut from plans on Outerzone by Mark Winstanley in Canada several weeks back.
» Fuel supply to baby bee
» fishing line to use for control line
» Control line hints and tips for beginners.
» Instant Control Line Flying! T-38 Talon Whip-Line from 2/70 M.A.N.
» Engine choice
» Engine choice
