» WILLY NILLYby MANDALAY Yesterday at 7:28 pm
by MANDALAY Yesterday at 7:24 pm
by rsv1cox Yesterday at 6:54 pm
by rsv1cox Yesterday at 5:59 pm
by rsv1cox Yesterday at 4:58 pm
» COX .020 RC PROJECT
by TD ABUSER Yesterday at 10:11 am
» Thrust Washer
by davidll1984 Yesterday at 8:25 am
» some pics....
by balogh Yesterday at 6:18 am
» Peewee power
by Coxfledgling Yesterday at 3:46 am
by GallopingGhostler Sat Sep 14, 2024 7:51 pm
» Ode to a dead cat
by GallopingGhostler Sat Sep 14, 2024 7:11 pm
by getback Sat Sep 14, 2024 5:25 pm
Engine choice
Engine choice
Hi gang, I'm going to be off work next week.i want to complete my swordsman 18 project.need help with engine choice.pee wee ,cub .024,cub .039,cub .049,attwood ..049 sbj .049,or good old reliable baby bee .thanks.sam
049kid- Moderate Poster
Re: Engine choice
Hey kid.. the Cox .020 Pee Wee would be my choice.. although my "two" both had Cox .049 Babe Bee's. The smaller Pee Wee would be a better choice though.
Re: Engine choice
Awesome I was thinking along those lines, thanks
Re: Engine choice
I would try and use the one that would better balance the model without adding ballast weight .
akjgardner- Diamond Member
Engine choice
I have a extended tank for pee wee,if it will run properly.mabye tee dee .020 spinner and no tail wheel
Re: Engine choice
I don't know if Kavan made a tank extension for the Pee Wee, but it would be a worthy upgrade as the run time is rather short on a stock Pee Wee.
Some time back I drilled a hole in a Pee Wee tank so I extended a fuel line from venturi nipple inside the tank to an external larger capacity Perfect tank. This was on my Ace R/C Littlest Stick. However, then one basically "ruins" the stock tank for restoration back to original form.
For someone who has a printing machine, could template and make such parts.
Going back to the Swordsman 18, nice thing about the ply firewall is someone could drill 8 holes, 4 to fit the Pee Wee, 4 to fit the Babe Bee. Then, one could choose one or the other.
About only drawback to Pee Wee power is being slightly reduced over the Babe Bee, one would resort to slightly shorter C/L line lengths, so to have adequate line tension in a light breeze. Otherwise IMO, one would need to fly in only calm weather.
Re: Engine choice
The historic way to extending a PeeWee run was to drill a hole in the side of the tank bell and plumb in an external tank. Joe Klause when he had Kustom Kraftsmanship used to sell PeeWee tanks ready drilled for the purpose. Apparently this worked better than blocking off one of the existing backplate vents and attaching the external tank's fuel line to the other vent.... in any case this approach only worked if you had TWO vent spigots on your backplate.....the later versions of the PeeWee only had one-plus a drilled hole.....though I suppose it would not have taken a lot of work to have drilled and tapped this hole to take a miniature pressure nipple to serve as a fuel inlet....
Someone in the past has apparently done this (drilled holes in the tank bell) to my recently acquired RR-1....so at some stage I will have to rectify this and plug the holes-probably with a custom alloy rivet....a little bit of care with a lathe external threading tool on the outer tank surface followed by a re-anodise, and the repair will be reasonably unobstrusive....though not invisible
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
ffkiwi- Gold Member
Swordsman 18 with Pee Wee 0.020
Well don't make the same mistake I did over 60 years ago. I built the Swordsman and powered it with the Pee Wee but did NOT add the recommended solder ballast wrapped around the crankcase nose as recommended by Carl Goldberg. End result: Tail heavy airplane and an instant loop and crash.
BTW, the cylinder on my Pee Wee got bent when it hit the only bit of pavement in the schoolyard where I was attempting to fly my new plane.
My father brought the cylinder into his workplace and somebody there was able to straighten it at least to the point of the engine would run on its prime. (I figure the needle valve may have been broken off in its seat thereby strangling the engine for fuel.)
And some 60 years later, I was able to straighten a bent Pee Wee cylinder just like some unknown machinist did for me back in 1960!
706jim- Gold Member
Re: Engine choice
Jim, Scientific had a spacer block for the Pee Wee, which extended it out another 1/2 to 3/4 of an inch forward, so it could match up with the propeller line of the cowling. It would also move the weight of the engine forward. If I were scratch building a Swordsman for a Pee Wee, I'd probably lengthen the nose of it so the engine could bring it into balance, also select lighter wood for the tail surfaces and thin out the fuselage a touch toward the tail, which would make the tail lighter for balancing. (One could also cut the fuselage wing slot so the wing was moved backward a little to make balance.)
But as kids, we weren't quite as privvy on this. But, I even later on made the mistake of not ensuring my Q-Tee was better balanced with a lighter Norvel .061 Big Mig, had an awefully squirrely flight. It is always better to have a plane nose heavy than tail heavy, because it is still controllable.
On my Minnie Mambo, because the Ace R/C single channel pulse battery pack was half the weight of a standard digital servo battery pack, I added a Harry Higley Heavy Hub as the prop nut on my .049 R/C Bee, to balance the plane out. That extra half ounce of weight did the trick.
Re: Engine choice
706jim wrote:And some 60 years later, I was able to straighten a bent Pee Wee cylinder just like some unknown machinist did for me back in 1960!
Still running strong a couple of years later …. Runs out its full tank just fine
rdw777- Diamond Member
Re: Engine choice
I'm so pleased to hear that. Your Stuntman kit is still waiting to be built but hopefully will be completed this winter.
706jim- Gold Member
Re: Engine choice
Engine choice .I might extend fire wall if needed.extented tank pee wee needs further investigation.
Re: Engine choice
Engine choice, sorry guys, trying to figure out how to send pic of engine
Re: Engine choice
https://www.coxengineforum.com/t15567-how-to-post-an-image-in-a-topic049kid wrote:Engine choice, sorry guys, trying to figure out how to send pic of engine
Re: Engine choice
Good photo, glad to see that someone (Kavan?) made a custom tank extension. The small tank only ever gave me about 1.5 minutes on a Cox 4x2 prop, about a minute more on a Top Flite white nylon 5.25x3 prop. Getting 4 or more minutes would be the cat's meow.
Would be interesting if someone could "print" a tank extension matched with the right length and type ANSI 2-56 tank screws and printed venturi extension. It wouldn't be a high volume item as demand is not there, but might be a few here who would opt for it.
Also a good start on the Swordsman kit, I enjoyed making one for my son. From 5 years ago:
https://www.coxengineforum.com/t12473-testors-8000#159939
Swordsman 18 CG and line length
I have an old Swordsman 18 profile plane that I m in process of restoring/repair and attaching .049 Baby Bee to.
Does anybody have any data on where the CG is supposed to be so I can get my optimal thrust angle?
With a .049 Bay Bee what would be a good line length for a 5-6 second rotation?
1975 control line guy- Moderate Poster
Re: Engine choice
5-6 seconds laps are gonna be tuff...
I'd start with 30' (8-10# Spyder) and pretty good engine offset, at least a couple washers, if tension is good maybe 32-33' lines.
CG as long as its not tail heavy is not critical, 20-25% back of leading edge.
Re: Engine choice
Thanks Mark.
I have it set up with two washers deep top and bottom side thrust outward and my CG is just about where you said it should be.
Probably will go with the Spyder wire fishing line or old school high visible Dacron 10 lb test.
With a Thimble Drome 6D 3P prop it should work.
Re: Engine choice
Hey guys,don't think my message got sent.on my original plans it shows cg 1 1/8" back from firewall.pee wee 25' lines,babe bee 35' lines
Baby Bee and Swordsman 18
Great info.
I was able to see a YouTube showing a Swordsman 18 with a .020 PeeWee on what looked like about 28 foot lines and it was about a 5.5 rotation. I think I am in the zone on this.
» Engine Choice
» .074 lil swamp buggy prop choice
» A simpler / cheaper .049 Tee Dee Engine suggestion
» This engine collecting lark is getting out of hand!
» Fuel choice
» Fuel choice
