by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Engine Choice
Engine Choice
Hi all
Newbie returning to the cockpit after 40 years behind a desk! No experience with Cox engines but considering purchasing a Medallion .049 or Cox Tee Dee .09 to power either a Phantom or Phantom Mite. I understand that TD’s can be temperamental but extra power would give me more choice for future build. Am I also better to push the boat out and buy new out of box rather than used?
Any advice appreciated
Prowd- Moderate Poster
Re: Engine Choice
The .049 the tee dee is the easiest to obtain and maintain. And the parts easy to get plentiful And that's what I'll personally choose First if that's an option
davidll1984- Diamond Member
Re: Engine Choice
Prowd wrote:Hi all
I am not sure about the size difference between the Phantom and Phantom Mite, but a Medallion 049 and TeeDee09 play in very different leagues. If you are lucky though, you can get a new 049 TeeDee for 70...80 bucks on feebay, and this is a good median between a 049 Medallion and 09 TeeDee..I mean this will power both planes, will be a brute force on the smaller, and dependable beast of burden on the larger plane.
Re: Engine Choice
Are you talking the Keil Kraft Phantoms ? https://outerzone.co.uk/plan_details.asp?ID=2806 https://outerzone.co.uk/search/results.asp?keyword=Phantom+Mite If you have not flown in a while they may bee a little strong to start off with ... But if so I think the TD .49 or .51 will get you were you want to bee . With the change of props you can get 18K to 24K RPM out of one there going to bee fast on this small of plane .
Re: Engine Choice
I tink Wen u say I also better to push the boat out and buy new out of box rather than used?
I think it confused me I thought you wanted to build a boat To me the words mite I associate it with boats ??
Re: Engine Choice
It will be good to buy a .09 engine for these planes:
https://www.vintagemodelcompany.com/16-kk-phantom-mite.html
https://www.vintagemodelcompany.com/20-kk-phantom.html
Read the review in Phantom Mite page, it is underpowered with 1 cc diesel engine.
If you want to purchase used one then choose an engine in good condition. A new engine is better I think, but need the push boat out
PS: I learn a new idiom, push the boat out. Thanks.
Levent Suberk- Diamond Member
Re: Engine Choice
bernie has some for sale, old stock, new in box, decent prices
TD 049 - https://coxengines.ca/oem-cox-boxed-engines/-29-cox-049-tee-dee-engine-cox-box-.html
i'd give a look at his other offerings, and bookmark his page, thats where ya can get lots of stuff:
Also Matt at EX Engines, has a refurb TD 09 - and is a supplier also ...
- http://www.exmodelengines.com/product.php?productid=18021&cat=280&page=1
cstatman- Platinum Member
Re: Engine Choice
Thanks for the links
I have already purchased items from Cox Engines. Great service so will keep an eye open for TD engine
Re: Engine Choice
The KK Phantom was pretty much built around the use of a 1.5cc (.09) diesel so the Cox .09 may be a little overkill for what appears to be a fairly slick airframe. It looks like the Phantom Mite has been designed around a .75cc-1cc diesel, so an .049 Medallion may be a good choice, although with only a 16" wing span, it'll certainly perform. The Phantoms were only really designed for the roundy roundy of team racing and were not stunters. Small wing areas mean they need to keep moving fairly briskly or they'll drop like a rock.
Re: Engine Choice
I was figuring that I could use the .09 in the Phantom to reacquaint myself with build and flying then progress to stunter using the same engine. Is this practical?
Re: Engine Choice
As others mentioned, the Phantom with only 21" wingspan was intended to be a speedster with the then available engines, which were not even as powerful as the ones available in the 1960's. If you want a trainer, it will fly much too fast for a learner.
I saw an instance somewhere else that someone used a 1963 A.C. Gilbert .11 sideport engine with mufflers (piston skirt acts as the valve to pressurize the crankcase to move fuel through the transfer port to the top of the piston for combustion). It's power was similar to the Fox .09 Rocket sideport, early 1950's Duromatic McCoy .09, etc.
If you want to a Phantom powered by Tee Dee .09, I would consider using the 32" R/C version, which is essentially a scaled up version of the 21" one. Make wing flaps non-moveable, install a suitable bellcrank system to elevator.
https://outerzone.co.uk/plan_details.asp?ID=11720
Re: Engine Choice
This would be the one George. This picture came up on the old Blackhawk Models website (now defunct) and being the owner of a number of Gilberts I thought it looked so cool. Always hoped to get one of their kits but sadly not to be. It will need to be scratch-built now.
Re: Engine Choice
So impressed with help from everyone but still trying to figure out how to post in quotes so apologies did not replying to all comments! Nervous about building from scratch from so will probably go for Phantom Mite with Medallion .049 (after looking at YouTube link!) Blackhawk model looks impressive in silver with decals
Re: Engine Choice
Thanks, Rod, yes that is the one. There was another one also, but yellow in color. Both were very fine examples of craftsmanship. I see the builder used 2 right mufflers for symmetry. One of the engines I bought from Tower Hobbies in the early 2000's had the same, too.
My Gilbert .11 with both right mufflers
My other one has both left and right mufflers, they are angled to provide out thrust with them pointing straight back.
The good thing though, is this kit is easily scratch built.Oldenginerod wrote:Always hoped to get one of their kits but sadly not to be. It will need to be scratch-built now.
About 5 years ago when Ron Cribbs, a forum moderator here came here visiting, I saw Ron fly his 26" Clown with the same wing area as my 30" Sterling Ringmaster Jr. (200 sq. in.) on a hopped up Medallion .049, and its stunt capability was superb on 42' lines. (By hopped up I think he was using a Tee Dee double bypass boost ported cylinder and Tee Dee head.) The Medallion is more powerful than the Bee's if unmuffled, a decent sport engine.Prowd wrote:So impressed with help from everyone but still trying to figure out how to post in quotes so apologies did not replying to all comments! Nervous about building from scratch from so will probably go for Phantom Mite with Medallion .049 (after looking at YouTube link!) Blackhawk model looks impressive in silver with decals
Quoting text is not difficult. This forum uses BB (Bulletin Board) code for html (web page) formatting. Above the editing box, one of the icons looks like a quote, hover your mouse over it and you will see the word, 'Quote'. Click on it. You can type an author or paragraph title to reference who quote is from in the dialogue box. Click on 'Insert'.
You will see:
- Code:
[quote="Joe Modeler"][/quote]
Between the
- Code:
To quote someone in reply, you simply click on "Quote" in the upper right hand corner of his discussion box. The system automatically adds the BB Code for quote surrounding that person's post. You can then delete what you don't want quoted, in your reply.
Re: Engine Choice
All I know is that those cats were STINKIN!! after playing with those diesels. ACCCKKK!!!!!, I know I wouldn't let them in my car. I tell my son all the time, you can walk home, your not getting in the truck. He loves them, he's acquired quite a collection and has become quite good at using them.
Medallion .049
Would Tee Dee.049 be too much of a handful in Phantom or is Medallion still most appropriate optionOldenginerod wrote:The Medallion is more powerful than the Bee's if unmuffled
Re: Engine Choice
Seeing this is a full bodied plane, it increases your chances of success using a TD. It places the tank directly behind the engine which keeps the fuel line length short. It's also imperative to maintain proper height in this model which may or may not require some replumbing of the tank. The tank is very important on the reliability of using the TD. While a standard vent tank will work, a uniflow tank setup would assist the engine run considerably. The problem is that a commercially available setup is more than likely non existent. The medallion would work better in this application if your not familiar with how to accommodate the tank situation. What I've discovered is that when your using a TD, the fuel delivery can be a bit of a challenge. Bladder pressure really fixes this problem. This also requires additional parts such as a finer threaded needle valve which is becoming more difficult to source. Running bladder pressure also has it's challenges whereas the medallion seems to manage these issues easier. The medallion can also be hopped up by installing a dual bypass cylinder and a high comp glow head.
Re: Engine Choice
Ken Cook wrote: The medallion would work better in this application if your not familiar with how to accommodate the tank situation. What I've discovered is that when your using a TD, the fuel delivery can be a bit of a challenge. Running bladder pressure also has it's challenges whereas the medallion seems to manage these issues easier.
Thanks Ken for pointing out the advantages and problems with the TD v Medallion. As this is my first attempt to reacquaint myself with both flying and build skills the less problems I encounter at this stage the better!
» Help with Fuel Tank Choice .051
» Question on 049 engine choice
» A simpler / cheaper .049 Tee Dee Engine suggestion
» This engine collecting lark is getting out of hand!
» Fuel choice
» Fuel choice
