 Carb body repair Cox_ba12
 Carb body repair Pixel
by 706jim Today at 9:32 pm
by roddie Today at 8:48 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by rdw777 Today at 10:28 am
» Octura engines?
» Tatone EM-7
 Carb body repair Empty
Carb body repair
Page 1 of 3 1, 2, 3  Next
 Carb body repair Empty Carb body repair
Post  Cribbs74 Thu Feb 09, 2012 7:35 am
I received my Sportsman and Special .15 yesterday, both engines externally look really good and should be fine runners once cleaned. I have tools coming so I can't open them up just yet. The special has a crack in the carb body along the venturi hole seam. Has anyone ever attempted to repair a carb body and if so what type of adhesive did you use. I imagine some sort or epoxy that is fuel safe would work. I plan to purchase a new carb body but, I don't want to throw this one away so I thought I would take a whack at fixing it.
 Carb body repair Empty Re: Carb body repair
Post  microflitedude Thu Feb 09, 2012 8:11 am
JB Weld?
microflitedude
microflitedude
Post  Cribbs74 Thu Feb 09, 2012 8:20 am
microflitedude wrote:JB Weld?
Matt,
In my experience JB weld and plastic do not play nicely together. It doesn't want to adhere well. JB weld is fuel resistant though as I have used it to repair pin holes in steel gas tanks.
Post  microflitedude Thu Feb 09, 2012 8:24 am
Matt,
Hmm.. We once used it to repair a broken plastic governor/throttle arm on a gasoline Go Kart. Very stressed part, held up great. (pedal punches and offroading) Maybe some light sanding would help it bond.
microflitedude
microflitedude
Post  Cribbs74 Thu Feb 09, 2012 8:29 am
Matt,
It's worth a shot, can't break it any further. I can make it uglier!
Post  RknRusty Thu Feb 09, 2012 8:31 am
Once I got a new Killer Bee backplate with a loose spraybar that would spin when I turned the needle. It had never been run, so there was no chance of oil on it. I pulled it out and put JB Weld on both parts and pressed it together. A week later I built an engine with it and flew it a couple of times. When I was cleaning it, I checked and the spraybar had come loose again. Maybe I should have roughed up the plastic some before I pressed it back together.
Maybe you could use a plastic welding kit to seal it up. http://www.eastwood.com/steinel-heat-gun-how-to-plastic-weld-plastic-welding-tool
Post  Cribbs74 Thu Feb 09, 2012 8:45 am
Good to know Rusty,
This thing is covered in 40yr old castor so I will have to clean in first. Roughing it up inside the split will be hard. Plastic welding kit is a good suggestion but it would cost me more than a new carb body.
Post  Ivanhoe Thu Feb 09, 2012 10:41 am
Personally, and I have done similar repairs, I'd use the thinnest grade of Cyano,(Superglue) it penetrates right into the crack and I've never had a repair crack again. Use a needle-type applicator, and try not to get to much of the cyano on the outside, it can attack some plastics, I used it once to fix an acetate cockpit canopy and the fumes turned the acetate white.
Ivanhoe
Ivanhoe
Post  John Goddard Thu Feb 09, 2012 11:44 am
For future reference you need 'foam safe' cyano Wilf, it doesn't whiten.
Wink
FMK/5Star do allsorts of cyano and plastic fixing stuff including those microwavable plastic
pellets, which thinking about it may be the solution to the above.
J
John Goddard
John Goddard
Post  PV Pilot Thu Feb 09, 2012 11:50 am
I dont know how well it would work with Cox plastic, but in the past I have used a pencil type soldering iron and basically hot smeared a leaking plastic crack shut on a nitro fuel tank.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Ivanhoe Thu Feb 09, 2012 1:09 pm
John Goddard wrote:For future reference you need 'foam safe' cyano Wilf, it doesn't whiten.
Wink
J
Right, thanks John, I'll bear that in mind next time I need it.
Wilf
Ivanhoe
Ivanhoe
Post  Cribbs74 Thu Feb 09, 2012 2:09 pm
I'll try the Foam safe CA first as I have some laying around. Should that fail then I can try the other options suggested. Or I can buy a new one................Thanks all!
Post  Jason_WI Thu Feb 09, 2012 7:30 pm
How about an aluminum ring turned and then slip fit over the carb throat. It would be cut to fit. It can then be JB welded in place.
Jason
Jason_WI
Jason_WI
Post  Cribbs74 Thu Feb 09, 2012 8:17 pm
Jason_WI wrote:How about an aluminum ring turned and then slip fit over the carb throat. It would be cut to fit. It can then be JB welded in place.
Jason
Another swell idea! Actually I think I have seen that somewhere. Can't remember
Care to turn one for me on your lathe? Just kidding, thanks for the suggestion.
 Carb body repair Empty JB weld.......
Post  Jaspur_x Thu Feb 09, 2012 9:45 pm
JB weld always worked on mine,have done a few,not just one,the oldest is over 20 years old now and still holding up. Getting the parts seriosly clean and a slight roughing up of the surface is the key.
Jaspur_x
Jaspur_x
Banned
Post  Jason_WI Fri Feb 10, 2012 12:36 am
Whats the OD of the of the carb neck? Do you have a caliper?
The pic of the olympic rear drum valve on Martin's site has this type of repair.
Jason_WI
Jason_WI
 Carb body repair Empty JB Weld
Post  Big Al Fri Feb 10, 2012 2:09 am
Guys, my experience with JB Weld wasn’t that great. I repaired a carb with it and thought it came out fine. But about half way thru the first flight the motor started to run rough. I landed and saw that the carb repair had turned to doo-doo. The JB had turned into a bright GREEN gooey mess. Never used it since (around nitro) but I see lots of folks have good results.
Any ideas what I did wrong? It could have been a sloppy mix proportion or maybe it had exceeded its shelf life? Maybe whatever I used to clean the parts (don’t remember) wasn’t compatible?
Anyone else seen this?
Al
Big Al
Big Al
Post  Jason_WI Fri Feb 10, 2012 7:43 am
Did you use JB Kwik or the standard JB weld? I have used JB weld on the exhaust repair of a crashed Evo 52 engine. No problems with it whatsoever.
Jason
Jason_WI
Jason_WI
Post  Cribbs74 Fri Feb 10, 2012 8:22 am
Jason_WI wrote:Whats the OD of the of the carb neck? Do you have a caliper?
I do have calipers and a micrometer. I will take a measurement tonight.
I'll go check on Martin's site.
Post  PV Pilot Fri Feb 10, 2012 8:38 am
I have had the regular JB Weld darken in color around nitro, but not goo up and slide off. You might have had a bad mix or some contamintation of some sort Al.
The Quik is a 10 minute set, 24 hr cure and is more heat sensitive and brittle. I let the regular JB weld cure for 48+ hrs. under a 100 watt placed close to the part.
PV Pilot
PV Pilot
Post  Cribbs74 Fri Feb 10, 2012 9:14 am
Big Al wrote:Guys, my experience with JB Weld wasn’t that great. I repaired a carb with it and thought it came out fine. But about half way thru the first flight the motor started to run rough. I landed and saw that the carb repair had turned to doo-doo. The JB had turned into a bright GREEN gooey mess. Never used it since (around nitro) but I see lots of folks have good results.
Al
Al,
I have seen the "green goo" I used JB weld to repair a sending unit inside a gas tank on my truck. I was in a time crunch and needed to make a road trip the next day and I didn't have time to let the JB fully cure. The gasoline reacted with the JB and it never fully cured.
I am not sure if that was the case in your experience. I have noticed that temp and humidity sometimes lengthen the cure time.
Post  Big Al Fri Feb 10, 2012 12:53 pm
Al
Al,
Hi Ron, I bet that was the problem. I don’t remember the details but probably did the repair one day and flew the next.
Thanks for the reply.
Al
Big Al
Big Al
Post  Cribbs74 Fri Feb 10, 2012 9:16 pm
Jason,
The OD is 15/32. I wonder if they make aluminum tubing with a 15/32 ID?
Post  Jason_WI Sat Feb 11, 2012 2:40 pm
Not sure on the tubing. I could turn you one. Problem is I dont have a TD 15 yet to test fit it.
Jason
Jason_WI
Jason_WI
Post  Cribbs74 Sat Feb 11, 2012 2:49 pm
Jason,
Sending you a PM now
