Shrike X3 Experimental - Page 2 Cox_ba12
Shrike X3 Experimental - Page 2 Pixel
by getback Today at 7:24 am
by rsv1cox Today at 7:05 am
Shrike X3 Experimental - Page 2 Empty
Page 2 of 2 Previous  1, 2
Shrike X3 Experimental - Page 2 Empty Re: Shrike X3 Experimental
Post  Davenz13 Fri May 24, 2019 5:07 pm
Thanks Roddie.
That design of yours should cut a good turn of speed, not a lot of frontal resistance there. I guess you can make the wheel diameter bigger to get more speed if you need it. I'm looking forward to see it turning circles.
I was going to have the twin engine mount anodised but the nearest anodiser is 2hrs drive away and I was worried that they might not be able to get it back to me within the week.
So Friday (Saturday here as I'm writing this) I went to see a mate who does powder coating (we get a lot of our bike stuff done there). After some discussion we settled on satin black anti-graffiti with clearcoat which apparently is resistant to a lot of solvents.
It will be interesting to see how it handles glow fuel.
The other deciding factor was he is doing a run of black on Monday so decision made.
I spent the rest of Friday polishing.
Shrike X3 Experimental - Page 2 X3_exp29
Davenz13
Davenz13
Post  Davenz13 Sat May 25, 2019 2:44 am
The cox nacelles for the other two engines arrived from Red Venom Repro’s this morning so I got them straight into the lathe for modifying.
Shrike X3 Experimental - Page 2 X3_exp31
The two front facing engines are engines propped 5 x 4 and ready for fitting.
Chassis assembled as far as I can go until I get the twin engine mount back from the painters.
Shrike X3 Experimental - Page 2 X3_exp30
I need eight 2.5mm x 12.5mm screws so I had to cut them down from 20mm long ones.
Easy enough to cut the surplus off but no easy feat for my big fingers to hold onto them while dressing the ends on the linisher.
There was more than one that flicked out of my grip and disappeared into those places where disappearing things go but, I managed to hang onto eight
eventually. lol!
Davenz13
Davenz13
Post  Frizzen Sat May 25, 2019 3:15 am
Wow That is a really slick setup!
Frizzen
Frizzen
Moderate Poster
Moderate Poster
Post  David S Sat May 25, 2019 6:11 am
Looking good my friend! I too have lost screws while either cutting them shorter on the band saw or having them bounce off the floor never to be seen again! I know that they are some place on my basement floor,but where?
David S
David S
Post  getback Sun May 26, 2019 9:17 am
Daven that is looking Fantastic my friend you have put the fun in the work you do !! As the other racer you built it will look fast just sitting there Cool The bumble bee are nice and will bee quit fawst i am sure , have you broken in the engines yet ? Huh... This Site Rocks!
Post  Davenz13 Sun May 26, 2019 2:33 pm
Hi Eric
No they're not broken in yet but after the competition I'll break them in.
I finished my engine dyno a while back but haven't used it yet so I'll try them on that once the engines have had their break in runs.
Then the car will get a run to see how it goes.
Davenz13
Davenz13
Post  Davenz13 Tue May 28, 2019 3:30 am
Got the engine mount back from the painters. Very happy with how it turned out.
Shrike X3 Experimental - Page 2 X3_exp33
With the engines mounted.
Shrike X3 Experimental - Page 2 X3_exp32
Mounted on the chassis.
Just waiting for the black button head screws that hold the body on to arrive. If they don’t get here in time, I’ll use silver ones and paint the heads black.
Otherwise finished!
Shrike X3 Experimental - Page 2 X3_exp34
Davenz13
Davenz13
Post  OVERLORD Tue May 28, 2019 3:35 am
Great job, I like the hidden nuts in both cones. Babe Bee .049 Babe Bee .049
Post  David S Wed May 29, 2019 6:20 pm
Wow! Looking good! I am waiting to see the body mounted to the chassie.You did an excellent job on your modified Shrike!
David S
David S
Post  getback Thu May 30, 2019 8:13 am
Hot Damn now thats a Racer , Powder coat does looks good and those skinny wheels are going to Scream!! Affraid or WOW!
Post  rsv1cox Thu May 30, 2019 10:37 am
As usual, I'm blown away by your work.
Fantastic!
Post  Davenz13 Thu May 30, 2019 3:57 pm
Thank you all for compliments.
There is such a wealth of talent in the forum I am pleased to be in such company.
It makes me try harder too.
Well the last job is to screw the body to the belly pan but, as the black socket button head screws have not arrived, I had to go to plan B.
Not having much luck with mail at the moment and as the first of June is less than sixteen hours away for me, I need to finish up.
Because it’s not a flat surface where the rear mounting screws now go completely through the body, I bent the heads of the screws to follow the contour. Not exactly best engineering practice but as my old engineering tutor has long since left this world he will never know.
Shrike X3 Experimental - Page 2 X3_exp36
I painted the heads black and with a fat little o-ring underneath I think I might get away with it.
Just noticed I had the wrong picture here. This is what it should have been.
Shrike X3 Experimental - Page 2 X3_exp37
Finally, all finished. I’ll get a picture posted as soon as I can.
Davenz13
Davenz13
Post  Davenz13 Thu May 30, 2019 7:07 pm
Well it’s finally finished with hours to spare.
I mentioned earlier that there was a theme to this build, which I like to do with blank canvas builds. I find it keeps me focused on the outcome.
I thought someone might have picked up on the theme as the engine name is a bit of a clue along with the yellow and black colour scheme.
My grandson is to blame as he took me to see the movie of the same name.
And yes I know a Z/28 is not a Mopar Bumble Bee but in the movie, BumbleBee (the transformer) changes from a VW to a 77 Camaro.
Why they choose a 77 model I don't know, I think the 70 would have been a much better choice but that's just me.
Shrike X3 Experimental - Page 2 Bumble11
Davenz13
Davenz13
Post  roddie Thu May 30, 2019 7:16 pm
Schweeeeet Dave!!!!! Thumbs Up Small Cox Logo
Post  akjgardner Thu May 30, 2019 9:34 pm
NICE
Post  getback Fri May 31, 2019 8:31 am
You WIN !!!Very nice and inventive , you have made the magic come to the screen now for the road . Can't wait to see this baby in ACTION !! Popcorn
Post  David S Fri May 31, 2019 4:29 pm
Looking good! It sure looks fast just sitting there! It will be interesting too see what it's top speed will be on the tether!
David S
David S
Post  Davenz13 Fri May 31, 2019 7:52 pm
I'm not completely happy with the twin engine mount, the engines are too high. I'll make another which has the engines a bit lower.
I reckon they could come down by two inches which would still give the props an inch and a half ground clearance and make the car look sleeker too.
Davenz13
Davenz13
