PT 19 Build Cox_ba12
PT 19 Build Pixel
by sosam117 Today at 10:25 am
by rdw777 Today at 9:17 am
PT 19 Build Empty
PT 19 Build
PT 19 Build Empty PT 19 Build
Post  SteveM Fri Jan 11, 2019 8:35 pm
I recently purchased the 'Front End' of a PT 19, ebay. I had the idea to build from parts found on ebay. Fuselage, wing, and honestly not sure what else.
I'm sure I could locate a parts list...
Had a question,
Can this assembly be dated, red backplate, slotted screws, copper(?) reed.
Prop,6D2P (left hand?)
Would like t hear what you think?
PT 19 Build Img_1118
SteveM
SteveM
Bronze Member
Bronze Member
PT 19 Build Empty Re: PT 19 Build
Post  getback Sat Jan 12, 2019 6:46 am
Hey Steve a wild but educated guess would bee from 1973 i am not sure about the needle valve that is in it ,but as we have found out sometimes Cox would use what was on hand or until that run ran out . Are you going to build a Balsa model or acquire parts to build a PT-19 ? Here is some data .. https://www.mh-aerotools.de/airfoils/cox_frameset.htm Small Cox Logo
Post  SteveM Sat Jan 12, 2019 8:52 am
getback wrote:Hey Steve a wild but educated guess would bee from 1973 i am not sure about the needle valve that is in it ,but as we have found out sometimes Cox would use what was on hand or until that run ran out . Are you going to build a Balsa model or acquire parts to build a PT-19 ?  Here is some data ..  https://www.mh-aerotools.de/airfoils/cox_frameset.htm  Small Cox Logo
I want to build a PT-19, thanks for the link, I now have an idea of what parts to look for.
SteveM
SteveM
Bronze Member
Bronze Member
Post  getback Sat Jan 12, 2019 9:24 am
I have built a Balsa one if i can find a pic , do you have any scale to go with ? PT 19 Build Pt-19_13
PT 19 Build Pt-19_12
PT 19 Build Pt-19_11 PT 19 Build Justin14
It flys Great , i did get crazy any thought it would do an outside loop > NO it want !!
Post  SteveM Sat Jan 12, 2019 9:41 am
getback wrote:I have built a Balsa one if i can find a pic , do you have any scale to go with ? PT 19 Build Pt-19_13
Wow, that is cool.
I don't (as of yet) have the skill set to build a model such as that.
I want to build a Cox model as issued in 73-75. this is the time frame I was most active with Cox models.
I never flew a plane, always had cars...
SteveM
SteveM
Bronze Member
Bronze Member
Post  getback Sat Jan 12, 2019 9:44 am
Here is my son fling it .
Post  getback Sat Jan 12, 2019 9:47 am
Well there all over ebay for the plastic PT-19 's If i were you i would buy one complete the parts can get expensive $$$ Airplane
Post  SteveM Sat Jan 12, 2019 9:51 am
getback wrote:Well there all over ebay for the plastic PT-19 's  If i were you i would buy one complete the parts can get expensive $$$  Airplane
I agree, I will keep an eye open for a complete model.
SteveM
SteveM
Bronze Member
Bronze Member
Post  SteveM Mon Feb 04, 2019 7:29 pm
Found the Fuselage and Tail Section,
PT 19 Build Pt-19a10
SteveM
SteveM
Bronze Member
Bronze Member
Post  roddie Mon Feb 04, 2019 8:25 pm
That looks to be the fuse/tail-version that I have. Mine is 1987 vintage. Your engine-parts are earlier.. (Eric is likely correct on the year) The "first-issue" model had an integrally-tanked "Babe Bee" engine. This was before Cox fully-developed their .049 reed-valve "Product-Engine" which utilized an external fuel tank. The first .049 reed-valve "product-engines" had what's known as the "postage-stamp" backplate/carb.
photo-example below
PT 19 Build Postag10
The plastic model was "molded" for this backplate/engine-mount to fit... but there were no provisions for mounting to the model with screws. These engines were often thrown-away, when the airplane was no longer flyable.
What "you have" is known as the horseshoe-backplate.. which is the next generation product engine carb/back-end. This "can" be mounted to a conventional firewall with #4 x 1/2" wood-screws.
Most PT-19's that I know of, came with a 6"D X 2"P left-hand propeller. This was because a left-hand propeller will "torque-roll" the airplane to the "right".. which increases line-tension when flying conventionally in a CCW rotation.
Post  roddie Mon Feb 04, 2019 8:35 pm
I should mention... that it appears that your engine-mount (firewall) should be compatible with the fuse that you have. Your fuse has a beginner/expert setting for the engine. This is a pitch up/down adjustment. The top of your firewall should fit-into a series of "grooves" under the fuses' nose.. to set the thrust-angle. There is a "view-slot" on top of the fuse, which shows the chosen position.
Post  Ken Cook Mon Feb 04, 2019 8:47 pm
In 73, Cox was offering the stepped wall cylinders. Your engine depicts a thick walled cylinder that would've been available later.
Post  Mark Boesen Mon Feb 04, 2019 9:47 pm
Ken Cook wrote:        In 73, Cox was offering the stepped wall cylinders. Your engine depicts a thick walled cylinder that would've been available later.
Ken's correct, it's later than '73, the stepped cylinder came out about '69-'70 for throttle, and thick cylinder '75-'79,  the dual slot exhaust cylinder came out in 1977 or '79 depending on info source. The Tee Dee used the thick cyl. w/ open port.
Here's a breakdown of most of the PT-19 thru the years with a nice video by Kim
PT 19 Build 56374610
Post  SteveM Tue Feb 05, 2019 8:54 am
Thanks for all the replies, much appreciated!
Won the fuse on ebay, listed as new replacement part. It is a later version than I wanted, but I couldn't pass up the listing as 'New'.
I'm quite sure I will build more than one, and this is the fun part, building from parts. I don't know why, but I find the most enjoyment doing in this manner.
https://www.ebay.com/itm/PT-19-FUSELAGE-AND-TAIL-SECTION-RUDDER-amp-ELEVATOR-NEW-NEVER-BEEN-USED-/173767111560?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=nvDl0JN0UEEigKgPao%252FAxCdQzdQ%253D&orig_cvip=true&nordt=true&rt=nc
SteveM
SteveM
Bronze Member
Bronze Member
Post  Oldenginerod Tue Feb 05, 2019 3:26 pm
Here's a box 'o bits that might be handy.
https://www.ebay.com/itm/COX-PT-19-FLIGHT-TRAINER-049-Control-line-Airplane-Box-Accessories-spitfire/273684547240?hash=item3fb8dec6a8:g:5CgAAOSwXINcV2LQ:rk:6🇵🇫0
Post  roddie Tue Feb 05, 2019 5:49 pm
Oldenginerod wrote:Here's a box 'o bits that might be handy.
It would be worthwhile to bid on that auction Steve. You need a wing.. and there are "two" in that lot. There are also three engines.. all of which have glow-heads that are likely still good. Spare rudders/stabilators.. Shocked
Depending on the condition of the fuse(s).. you might be able to build a 2nd airplane.
Post  SteveM Wed Feb 06, 2019 8:14 am
Thanks for the heads up!
On my watch list...
SteveM
SteveM
Bronze Member
Bronze Member
Post  Mark Boesen Wed Feb 06, 2019 8:04 pm
SteveM wrote:Thanks for the heads up!
On my watch list...
Hi Steve,
What is your avatar photo of? lol, no offence i hope, i look at it and can't figure it out? Thanks
Post  SteveM Thu Feb 07, 2019 3:34 am
On my watch list...
Hi Steve,
It is the cover of the Pink Floyd album 'Meddle', one of my favorite albums.
I have a love for music as well...
SteveM
SteveM
Bronze Member
Bronze Member
Post  Oldenginerod Thu Feb 07, 2019 5:15 am
SteveM wrote:
On my watch list...
Hi Steve,
Yes, it is an ear!
(Another Floyd fan).
My favorite is "Wish you were here", but I digress.  There's another thread for this discussion. Embarassed
