» Jim Walker Bonanza etc.
by Ken Cook Today at 5:03 pm
by rdw777 Today at 2:52 pm
by rsv1cox Today at 10:52 am
by roddie Today at 10:30 am
by roddie Today at 10:02 am
by TD ABUSER Today at 9:25 am
» 1940's?...............
by rsv1cox Today at 7:46 am
» Lesson learned
August-2024
Cox Engine Test Stand
Hi, I have this stand I made myself, it has been sanded, sealed, and has been covored with a thick coat of lacquer to make it hot fuel proof. My only issue now is that I cannot figure out how to mount my cox .49 and .20. I want to be able to remove the engines often and be able to put them back on. So I would not want to drill one hole because after a few uses the wood will get boared out. Any ideas?
![Cox Engine Test Stand Img_0310](https://i.servimg.com/u/f11/19/76/59/25/img_0310.jpg)
![Cox Engine Test Stand Img_0311](https://i.servimg.com/u/f11/19/76/59/25/img_0311.jpg)
![Cox Engine Test Stand Img_0312](https://i.servimg.com/u/f11/19/76/59/25/img_0312.jpg)
Dstradt- Moderate Poster
Re: Cox Engine Test Stand
Here's a 5 second recap of the last 30 minutes of my typing and loosing all of it cause I touched the wrong button.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD966&P=7
Later that evening:
Thanks guys, for the reminder to "save" my work. I should know better.
Anyway my response was to use Brass Threaded inserts where each engine mounting hole would be. Than I found those steel blind nuts, which could be installed from the rear of the motor mount, and would not strip out like bare wood would after repeated used.
If you are only going to use the stand for 049 and 020 tank mounted motors you would only need to drill eight holes, seal with epoxy or CA and use the blind nuts.
Later that evening:
Last edited by Marleysky on Sun Oct 01, 2017 10:17 pm; edited 1 time in total (Reason for editing : Recap lost response.)
Marleysky wrote:Here's a 5 second recap of the last 30 minutes of my typing and loosing all of it cause I touched the wrong button.
If you're going to type something big, do it in a word processor or highlight and copy your text every so often.
Well, at least I am not the only one with this problem....
![Rolling Eyes](https://2img.net/i/fa/i/smiles/icon_rolleyes.gif)
Testify Brother.....
..........................Lost to the Ether Kim
There's a couple of different ways to approach this. It's best to have dedicated mounts for each engine size and type. Some engines mount "radially" to a firewall.. and some mount on "beams".
Let's say that you have Cox "reed-valve" engines with integral fuel-tanks. The "Bee"/.049's mounting-pattern is slightly larger than the "Pee Wee" .020's. I would personally make separate mounts. You can choose to mount the engines with machine-screws with captive "blind-nuts" installed behind the firewall to accept them. This would be a good method.. and would handle "repeated" mountings and dis-mountings.
Using small wood-screws is also an option.. but as you mentioned; they will strip-out with repeated mountings/dis-mountings. You can extend the service-life of the mount by sticking wooden toothpicks (cut-short) in the mounting-holes with a drop of super-glue. This will give the wood-screws "new-wood" to bite-into. I've done this with small (1/2A size) airplanes having a radial firewall.. and it holds the engine tight.
Not sure how thick the main board is, but you can get 2-56 blind nuts and long 2-56 machine screws from Micro Fasteners.
https://www.microfasteners.com/
You might also a square of hardwood on each side of the vertical support to take some long #2 socket head wood screws, also sold by Micro Fasteners. I use blocks of hardwood---got them for free from a local cabinet shop---with the test stands that Matt and Bernie offer, and have yet to wear out any.
![Cox Engine Test Stand 1_26](https://i.servimg.com/u/f11/16/84/28/46/1_26.jpg)
Maybe you could mount a "sacrificial" strip of wood on the front surface, and replace it when it wears out and/or gets soaked? It would be the most flexible solution, you could install engine mounts with different patterns and would not need to worry about extra holes.
Something like this:
![Cox Engine Test Stand Mootto10](https://i.servimg.com/u/f11/19/04/97/47/mootto10.jpg)
If you are going to run only 2-3 different engines on the mount, then it might be easiest to use blind nuts as Marleysky suggests.
» UK sourced engine test stand
» Ran the first engine of the year!
» My new test stand
» How's that engine test stand thing going?
» Reedy test stand
» My new test stand
» Reedy test stand
