letters from Ted Cox_ba12
letters from Ted Pixel
by GallopingGhostler Today at 8:51 pm
by LooseSpinner99 Today at 4:38 pm
by Kim Today at 3:28 pm
by rdw777 Today at 11:24 am
» Pathé Modeling Videos
letters from Ted Empty
letters from Ted
letters from Ted Empty letters from Ted
Post  Mark Boesen Wed May 17, 2017 6:02 pm
Hey Everbody, the post on 'compression' and glowplugs made me think of this email exchange from Ted Fancher (Stuka Stunt 2003) and thought it was worth passing on:
RE: hot plug vs cold
Date: May 29th 2003
>Mark,
I'm very reluctant to make specific recommendations on engines I've never personally run. Please take this response with that in mind.
My feeling is that most any engine that is generally intended for RC use is going to be timed to run at higher revs than are appropriate for stunt use with the "traditional" six pitch props. I would expect to try and run the LA in a constant speed mode, preferably a steady four stroke. I would expect to run a four pitch prop around 10-11K, most likely either an 11 or perhaps a 12 inch diameter...start with elevens. I use 10% nitro fuel as the standard from which I make any changes depending on the given engine and conditions.
The engine should be able to spin an 11 X 4 prop at a steady four cycle at the desired revs to fly the plane at a speed with which you are comfortable (don't get sucked in to assuming max length lines are necessary. Line length is another good trimming mechanism. Don't be afraid to shorten lines to regain desired tension if the engine is happy at a speed which doesn't suit the longer lines). If the engine breaks into a two cycle during maneuvers but doesn't run away you can live with it. If it breaks and the plane surges forward too much for comfort either increase the nitro (thus requiring a richer mixture) or consider adding one additional head shim at a time...the nitro will provide more torque at the same RPM and run richer, the head shim will reduce torque and power a tiny amount but will also run richer. Both options will get you closer to the steady four stroke if that is your desire. Someplace in between will result in a break at different load levels...which is what you were originally asking about. Hope this helps.
Ted >
>Thanks! it points me out of the woods, but one last
>question: your guess: LA46 2-4-2 or hot plug, mostly 4
>cycle? For better line tension
>Thanks! You'e been a big help, I used to read your Twister
>article over and over.
>Mark Boesen
>Hi Ted,
>>>So would a earlier break say 10:00 area on a loop, be better
>>>than a constant four cycle with a hotter plug? Better as in
>>>more power, more line tension?
>>>Thanks, Mark
>>Hi Mark,
>>Well, as always in this game, it's never quite that simple.
>>It depends on the engine (low timed Fox .35 versus the
>>modern schnerle ported engines we try to tame for stunt),
>>the airplane and the way the pilot likes to fly.
>>With a stock Fox you're probably better off doing the
>>classic 4-2-4 thing. The modern engines are ported to
>>deliver their power at much higher revs and allowing them to
>>break makes way too much power compared to the four cycle
>>mode. As a result we find we need to run them in a constant
>>RPM mode with props pitched appropriate to the revs.
>>One of the reasons for the current love affair with four
>>strokes is the consistency of power delivered by an engine
>>which "can't" break. With enough power to weight the things
>>fly just like they've got an electric engine on
>>them...constant torque and RPM...thus, constant speed. Very
>>few drawbacks once the right mixture is found.
>>My personal preference for tuning a two stroke run is to use
>>nitro content or head shims to adjust the break (if any). I
>>think you can safely run any hot range plug and the stock
>>engine won't suffer any RPM loss when you disconnect the
>>battery. This test gets you in the "workable" range of the
>>engine. You can then adjust the break by playing the head
>>shim/nitro game. More nitro or less compression ratio (more
>>shims) will result in a later break when launched at the
>>desired lap time RPM, and vice versa.
>>Hope this answers your question.
>>Ted Fancher
>Mark,
Ted
letters from Ted Empty Re: letters from Ted
Post  Cribbs74 Thu May 18, 2017 8:51 am
I've never met Ted, from what I have read here and elsewhere he sounded like a real stand up guy.
Thanks for sharing Mark.
Post  getback Thu May 18, 2017 9:09 am
Even though i have never flown a plane with a large enough engine or old to have the 4-2-4 break it makes a lot of sense the way he explains it , Good read , Thanks ! RC Plane
Post  roddie Thu May 18, 2017 10:28 pm
getback wrote:Even though i have never flown a plane with a large enough engine or old to have the 4-2-4 break it makes a lot of sense the way he explains it , Good read , Thanks ! RC Plane
Ditto Eric.. Smile Thanks Mark.. Very interesting reading. It made me want to tinker.. but most tinkering-results are realized through flying the model. Although I'm a novice.. C/L Stunt flying is in my heritage.. and I wish to take my experience to a higher level. Engine-tuning tips; I consider priceless. I frequently note other modelers experience and save the text to a .doc-file in the appropriate folder in my modeling library on my laptop. OCD..
Mark, In your initial letter to Ted, it seems that you were looking to run an RC engine in a C/L application? Ted's comments would indicate that.. but get much more interesting with prop-considerations.. as well as using different nitro-content in the fuel.. head-gasket thickness.. and resultant needle-settings for the engine to govern power when it's needed. Recipes for enhanced-performance are like "pearls"... We can choose to apply them or not.  If "not"... we will never know "first-hand".. what might-have made a difference in a flight.
Some modelers will think about these things.. some will apply certain facets to their models. Others will be content with what works. I've always been a proponent of the "how can it work better" approach.
Post  Cribbs74 Fri May 19, 2017 10:23 pm
Shoot Roddie, if I had a day with you...
