Running some marine engines: OS MAX-S 30 RC Cox_ba12
Running some marine engines: OS MAX-S 30 RC Pixel
by roddie Today at 8:48 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by rdw777 Today at 10:28 am
» Octura engines?
» Tatone EM-7
Running some marine engines: OS MAX-S 30 RC Empty
Running some marine engines: OS MAX-S 30 RC Empty Running some marine engines: OS MAX-S 30 RC
Post  OVERLORD Mon Apr 24, 2017 4:00 am
This is a short test run of an early 60’s OS Marine engine. It’s a .19 engine with steel cylinder similar to the OS max 15 III. The engine is equipped with a water jacket on the head and a brass flywheel.
Running some marine engines: OS MAX-S 30 RC Imgp3417
It is this engine that Vic Smeed fitted in the prototype of his 30” speedboat REMORA.
Running some marine engines: OS MAX-S 30 RC 69283611
Running some marine engines: OS MAX-S 30 RC 69283610
On the engine test stand, I fitted a bottle with water to cool the engine by thermosyphon but during running I noticed that the water level was not at the good height. For cooling, it is more easy to install a water reservoir above the engine and let the water flow through the water jacket to a bottle below the engine.
A picture of the set up:
Running some marine engines: OS MAX-S 30 RC Imgp3710
I made this video while the engine was running:
https://www.youtube.com/watch?v=279yfgzv9a4
Lieven
Running some marine engines: OS MAX-S 30 RC Empty Re: Running some marine engines: OS MAX-S 30 RC
Post  getback Mon Apr 24, 2017 9:40 am
COOL !! Sounds good and throttles well , it will make a good runner in the water . It appears the water was not flowing very well in the video ? but am sure you will get that worked out with the installation. Thanks for the fun !! Popcorn
Post  OVERLORD Tue Apr 25, 2017 3:59 am
getback wrote:COOL !! Sounds good and throttles well , it will make a good runner in the water . It appears the water was not flowing very well in the video ? but am sure you will get that worked out with the installation. Thanks for the fun !! Popcorn
Eric, as said above, the thermosyphon didn't work because the water level in the tank was not high enough. It's less complicated to let the water flow in and out of the engine by gravity during running. The diameter of the silicon tube and the brass fittings of the water jacket restrict the flow to give plenty of time before the bottle empties.
I'd like to find a coupler for this engine, universal joint or for a cable, but the thread is uncommon. I measured a pitch of 32 TPI and the diameter is about 5,6 mm or 7/32. I've read on the web that a .15 FP has such a thread. Is that so?
Edit: that's the thread. I found this data sheet on the OS site:
http://www.osengines.com/parts/engine-specs-discontinued.html
Post  KariFS Tue Apr 25, 2017 4:38 am
Thermosyphon would also work better if the water inlet of the engine were at a lower level than the outlet.
Interesting engine again, I am curious to see what kind of a boat project you have in mind Smile
I also have been looking at a "local" for sale ad of a marine Enya Fuji 35 for a few months, contemplating if I should make an offer or not Huh... It must be quite old, as there is no R/C throttle on it.
Post  Oldenginerod Tue Apr 25, 2017 7:05 am
KariFS wrote:Thermosyphon would also work better if the water inlet of the engine were at a lower level than the outlet.
Agreed. Being an antique stationary engine restorer, I can tell you that thermosyphon will only work if one water fitting is higher on the engine than the other. Some early cars and tractors didn't have water pumps and only relied on thermosyphoning to circulate the coolant. It's surprising how high a well set up thermosyphon cooling system will actually pump the heated water.
Running a "total loss" cooling system as suggested is not actually very good for an engine because it continuously introduces cold water into the water jacket, not allowing it to reach an efficient engine temperature. The thermosyphon sytem is self regulating- the hotter the water gets, the quicker it flows from the upper engine outlet, drawing cooler water into the lower inlet. As the engine cools, the flow slows, allowing it to heat up further.
Post  OVERLORD Wed Apr 26, 2017 12:55 am
I wouldn't mind making the Remora. It reminds me of the Graupner Taifun. But that will not be for the near future. On the Fuji35, there wasn't an exhaust throttle?
The thermosyphon was just an idea. I thought by positioning the inlet water tube lower than the engine that this would help. I just let the water flow through now for easiness. That's how it's done on model boats as well.
Post  getback Wed Apr 26, 2017 9:10 am
Running some marine engines: OS MAX-S 30 RC Remora10
now thats a cool looking boat also by Vic Sneed .
Post  OVERLORD Wed Apr 26, 2017 11:24 am
Eric, I think it is too. When on the water, it seems to cut the waves well, even when the surface is a bit rough. But before building, I need to find a coupling first.
This video is on Youtube: a Remora powered by a slightly more powerful 28 MDS engine.
https://www.youtube.com/watch?v=ZuuemMGvRmw&t=172s
Post  706jim Wed Apr 26, 2017 2:12 pm
What engine is in the cruiser? Sounds like a 4 stroke.
706jim
706jim
Post  OVERLORD Wed Apr 26, 2017 2:50 pm
706jim wrote:What engine is in the cruiser? Sounds like a 4 stroke.
The Sea Queen is powered by an OS 61 FS.
https://www.youtube.com/watch?v=xTwiUs5Q7B4
Post  roddie Wed Apr 26, 2017 8:28 pm
I've found this conversation on "thermo-syphoning" to be very interesting. The engine does need to "heat-up" to operate efficiently. How could it be done, running on the water? The conventional way of feeding cooling-water to the engine is via a pick-up tube, positioned into the prop-wash.. but as mentioned; it feeds "cold water" to the head via a conventional water-jacket. Granted; it's not "pumped-in" at a high-volume.. but it's still cold-water being fed directly to the cylinder-head. Maybe a simple restrictor-fitting in the line (or an adjustable valve) would meter less cooling-water to the engine? Tube-coils have been tried; wrapped around the engine-cylinder.. but they're intrusive. Most of the heat is right up top.. at the head. That's where the control needs to be IMO. Maybe trying different-size coupling-tubes would produce favorable results?
Post  roddie Wed Apr 26, 2017 8:55 pm
Regarding Vic Sneed's "Remora" design.. I love that look. Dumas "had" a little 1/2A runabout-design called the "Half-Pint Cabin-Cruiser".. that I tried to buy in the mid 1990's.. but was discontinued.
Running some marine engines: OS MAX-S 30 RC Di991411
I wanted that kit BAD... I was bummed-out that I couldn't buy it direct from anywhere. I already had the Dumas hardware-kit for the .049 glow-engine installation.
Running some marine engines: OS MAX-S 30 RC 9-1-1410
Running some marine engines: OS MAX-S 30 RC Dumas_10
It's a tiny 18" length boat.. but would be a blast to run with a Cox .049 engine. Given today's feather-weight radio-gear... that little boat could be a lot of fun on a small pond.
Post  OVERLORD Thu Apr 27, 2017 12:51 am
The Half Pint is still on the Dumas site:
http://www.dumasproducts.com/product_info.php?cPath=136_58&products_id=353
Post  1/2A Nut Thu Apr 27, 2017 1:27 am
I remember the Half Pint, guys use to make them speed boats nix the cabin section
and dress them up for race use, would speed them up pretty peppy for 1/2A.
Check out this IC cabin boat er has some motah..
ANZAC DAY ANZAC DAY ANZAC DAY
Post  KariFS Thu Apr 27, 2017 11:18 am
Not sure... The muffler does seem to have some fittings fore and aft the mounting flange, otherwise it looks like just an ordinary muffler. Could be that this engine is a mix of parts.
Running some marine engines: OS MAX-S 30 RC Image46
I am going to skip this one anyway, a bit expensive at 37€.
Post  roddie Thu Apr 27, 2017 5:36 pm
OVERLORD wrote:The Half Pint is still on the Dumas site:
Thanks Lieven! I wonder when it was re-introduced? I haven't kept up with the Dumas offerings in some years now. The price has more than doubled.. Shocked but I guess that's to be expected..
I think that a slight dome to the cabin-roof and a windshield-visor would dress it up a bit. If I bought the kit, I'd make templates of everything. That's always a good thing to do with any kit; for reproducing parts.. or scratch-building another complete model.
Post  roddie Thu Apr 27, 2017 6:26 pm
1/2A Nut wrote:I remember the Half Pint, guys use to make them speed boats nix the cabin section
Yup.. I'd say it has some "motah"!! Kinda' silly to have that engine in a scale cabin-cruiser... but it sure runs good. It's really stable at speed in the straights. As big as that pool was.. it was too small for it. A good size pond on a calm morning.. or evening; when the water is like "glass" would be nice!
I hope that we have more model-boat activity here on the forum. There's so many models that could be explored. You've contributed a lot Brad.. and I love your Cox-powered models!
Post  1/2A Nut Thu Apr 27, 2017 8:51 pm
Thank you Roddie I should be able to get some good vid of the new rigger soon
been windy and rainy here, the water moccasins have been running around
at the club 1 got caught up in the strut of a large gas mono the other weekend.
He was banged up but alive and managed to free himself up and swim away.
pic from the vid..
Running some marine engines: OS MAX-S 30 RC Vlcsna10
Post  OVERLORD Wed May 17, 2017 6:57 am
The next engine is an OS Max-S 30 RC. When I got it, the engine was equipped with a blue anodized muffler that was screwed on with bolts and further glued to seal the gaps. Dried castor oil was abundantly present between the fins.
Running some marine engines: OS MAX-S 30 RC Imgp3418
According to the 1968 Graupner catalog, this engine was not sold as a marine engine. One had to buy a conversion kit with water cooled head, crankcase cooling flange , bolts and flywheel.
Running some marine engines: OS MAX-S 30 RC Motore10
I started removing the muffler. This glue paste could be chipped off and for 1 bolt, I had to grind away the bolt head as the slot was gone.
Running some marine engines: OS MAX-S 30 RC Imgp9913
I managed to find an extra conversion kit for this engine which might be useful in the future. To replace the non standard muffler, I found an original new OS 703 silencer.
Running some marine engines: OS MAX-S 30 RC Imgp9910
Running some marine engines: OS MAX-S 30 RC Imgp9912
The first run was accompanied with lots of vibrations due to the crankshaft end play. Also, the engine did not run without tension on the glow plug. I supposed the plug was too cold and I replaced it by a Enya nr4. I made a thrust washer to get rid of the end play but that need replacing by a more durable one. The engine runs well but fine tuning is still neede and it starts from the first pull.
Running some marine engines: OS MAX-S 30 RC Imgp3711
The video:
https://www.youtube.com/watch?v=8Xws5otUono
Post  roddie Wed May 17, 2017 9:30 pm
Hi Lieven, Are there any wear-marks on the back-plate? I didn't see any indication of the crank drifting fore/aft while running/throttling. The engine seemed to run pretty smooth.. albeit "rich. I think that I see excess un-burnt fuel blowing out-of the muffler's pressure-line.
Apparently a plug-change helped stabilize the engine with glow-driver disconnected? What were you using to pump coolant to the head? A conventional coolant-loop I think will run hotter. I wonder about this for bench-running marine-engines. The pressure/volume at which cooling-water is pumped to the head.. would directly affect engine-performance and throttle-response.. IMO.
Great that the engine is starting easily. Any history on the engine; as it was set-up? That blue muffler/header may have increased performance for a certain application. Huh...
Your OS Max-.30 doesn't resemble my  .29 C/L aero-engine..  but yours is an RC variant... and I have very little info on my C/L version.
Running some marine engines: OS MAX-S 30 RC Os_max10
This engine may have been built in 1962.
Running some marine engines: OS MAX-S 30 RC Dsc02416
See though.. this photo of my .29's castlng ID..
Running some marine engines: OS MAX-S 30 RC Os_max11
Looks very close to the era of your .30RC.
Thanks for posting the vid Lieven!  I'm intrigued by IC model-marine engines.
Post  OVERLORD Thu May 18, 2017 4:19 am
Roddie, glad you liked the video! You can see the axial play on 4:42 when the engine stops. I haven(t inspected the back plate yet but there is some wear on the back of the drive washer. The water is just flowing through the engine by gravity.
Running some marine engines: OS MAX-S 30 RC Imgp9311
For dating OS engines, the OS website has a page. From the main page, choose "OS facts" at the bottom right and then click on "manufacturing timeline gallery " top left. Your .29 III is dated 1961.
http://www.osengines.com/history/ostimeline03.html
I never saw any year on the mounting pads of OS engines, only 2 letters.
Post  1/2A Nut Thu May 18, 2017 9:47 am
I bought a OS Max .10F SR last year new old stock in box from a
hobby store who was doing some liquidating of it's store stock that
was shelved in the back storage room.
I had seen one run in a Dumas Lil Rascal rigger back in the day and
was surprised just how much power the set up was providing on the
small rigger. For old times sake I may rekindle the moment with a
more modern rigger running tricks and a 1.5cc tuned pipe for sound
and make it run a: Lil Mo Peppy.
The design will have a taste of old school with sneaky speed tricks added
in without being too obvious giving a appearance of a vintage kit. At first
glance the guys at my club will think I have a old dog with no bite... just
a flashy new bark. Could do 45- 50 mph and be a fun non fussy runner.
Fyi...period steel chromed OS .10 flywheel.
Running some marine engines: OS MAX-S 30 RC Imag4311
Running some marine engines: OS MAX-S 30 RC Imag4310
Post  OVERLORD Sun May 21, 2017 11:38 am
That looks great. Is the tuned pipe the only mod? Do I see a nipple for a water cooled exhaust? I see no second nipple so I assume that the water is blown out by the exhaust. Great job!!
Post  1/2A Nut Sun May 21, 2017 10:19 pm
Thank you,
No mods to the engine other than adding a header and tuned pipe.
The tap on the header is for a pressure line to the fuel tank. Can't
run water inside the pipe the engine would get unwanted influx.
If I recall OS recommends running the cool water through the back
plate first then up to the head. I have the manual read it once.
My current boat project for the summer is a Saito .30 4 stroke
rigger here is the design layout. This weekend I finished one
of the sponsons thus far.
Running some marine engines: OS MAX-S 30 RC Imag5010
Running some marine engines: OS MAX-S 30 RC Imag5011
Post  getback Mon May 22, 2017 8:36 am
Hey Brad , whats the two nipples at the back of the CC for ? Is there a water pump in there ? I looked for a breakdown and couldn't find one . Nice looking OS !! Cool
