Chambers R-1 build - Page 2 Cox_ba12
Chambers R-1 build - Page 2 Pixel
Chambers R-1 build - Page 2 Empty
Chambers R-1 build
Chambers R-1 build - Page 2 Empty Re: Chambers R-1 build
Post  JPvelo Fri May 20, 2016 4:39 pm
I realized last nite I forgot to add a bellcrank mount to the wing so that's the first thing I did this morning:
Chambers R-1 build - Page 2 WNZuPBl
I'm making the fuselage in two pieces. The main section is 1/4" sheet, the canopy/turtledeck will be 3/16" tapering back to 1/8".
Chambers R-1 build - Page 2 EOndCiO
This is the gear mount, I always use beeswax to plug t-nuts so they don't get adhesive in them.
Chambers R-1 build - Page 2 KqrEtaz
Here's the fuse with engine mounts and the primary gear mount installed. I made the gear mount long enough to overlap the engine mounts to reduce flex.
Chambers R-1 build - Page 2 ZOMTsge
This ones the wing test fit in the fuselage. I'm really curious to see how this model will handle in the air.
Chambers R-1 build - Page 2 QawU7jj
JPvelo
JPvelo
Post  stuntflyr Fri May 20, 2016 7:41 pm
Jim,
Where'd you find that small rock maple stock?
Ever notice how that side view looks like the Bellanca a little?
Looking good.
Chris...
stuntflyr
stuntflyr
Post  pkrankow Fri May 20, 2016 7:48 pm
I have a plank of rock maple in the attic of my garage. I bought it at the local home improvement store (Menards) Check lumber yards and such. It can be had for less than buying engine bearers. A table saw makes short work of the plank into building pieces. I plan to only cut off a 2 ft piece when I need some.
I sought this plank after having a bad experience with highly figured engine bearers. Broke the nose off via prop strike on a bench run... I have control over this now so that will never happen again.
I still have more of the figured maple. I might do inlay again some day. I should have called up whoever I bought it from and sent it back immediately. (I don't remember who I bought it from, and sat on it for over a year before using it)
Post  JPvelo Fri May 20, 2016 8:27 pm
Chris,
It's actually mahogany, I buy it at hobby bench. I'm sure there's somewhere in Tucson you can find it. Do you guys have any good hobby shops down there?
I can see the Bellanca resemblance. It reminds me of the space ship from "My Favorite Martian".Chambers R-1 build - Page 2 FWuFznJ
JPvelo
JPvelo
Post  stuntflyr Sat May 21, 2016 1:21 am
Thanks guys. I'll try to find some.
Jim; We have a couple of hobby shops, not too bad. One has Stunt fuel regularly and they both have wood, glue and stuff. One I bought the last ARF Dirty Birdy I ever saw last month. These distractions keep me from finishing a Stunt model!
Chris...
stuntflyr
stuntflyr
Post  JPvelo Sun May 22, 2016 1:27 am
Here's today's progress. First off I've mentioned that I'm building for the plank category and I'm not using any ink lines. I also don't want engine mounting hardware protruding through the inboard side. My fuselage can only be 1/4" thick with the exception of the doublers. With fuselage doublers it can be 3/8" thick back to the mid point of the wing.
I started by cutting out 4 1/32" doublers, I later decided to only use 3:
Chambers R-1 build - Page 2 8kNDuVF
I added two additional gear mounts on the bottom of the fuse and epoxied 1 1/32" doubler to each side:
Chambers R-1 build - Page 2 FmqmMQA
I epoxy doublers in my 65lb press:
Chambers R-1 build - Page 2 3QbQvZg
I installed blind nuts and sanded them down so they are thinner than 1/32":
Chambers R-1 build - Page 2 7QqTiFi
Another 1/32" doubler (tripler?) goes inboard:
Chambers R-1 build - Page 2 5pxZJzk
I was originally going to cut the 4th 1/32" doubler (quadrupler?) into individual panels for the inboard side. I decided to go with 1/64" quintuplers on the inboard and outboard sides, cut out to represent the panels shown in the 3-view drawing. I'll epoxy them tomorrow and post how it goes.
Chambers R-1 build - Page 2 Fsa42xv
So if my math is correct 1/4"+ (3 x 1/32") + (2 x 1/64")= 3/8"
The tired of cutting doublers Jim.
JPvelo
JPvelo
Post  JPvelo Sun May 22, 2016 10:13 am
This is the stringer test patch with carbon veil doped down. Results look real good so far.
Chambers R-1 build - Page 2 FFs6xtN
JPvelo
JPvelo
Post  roddie Sun May 22, 2016 1:19 pm
Man.. that's a lot of work! It must be fun though. I enjoy making laminations.. and using exotic woods. What are you using for glue on the laminations?
That fuse is going to be solid.. and tough as nails! I love what you've done there! I'd guess that 1/2" length machine-screws will hold the engine in place without bottoming on that inside 1/64th cap? What size thread are the blind-nuts?
Post  getback Sun May 22, 2016 1:22 pm
It's Coming along nicely Jim , I kept looking at that funny looking cut out below the wing,l went back to the drawing its the landing gear witch I would think will be in the down position all time. I think the stringers will look good covered with the silk too . Eric Wink
Post  JPvelo Sun May 22, 2016 4:29 pm
Roddie,
Yeah it's fun but it gets tedious. The laminations are laid down with 30 minute epoxy. I don't like to take any chances with all the vibration and fuel at the front of the plane. It's the only epoxy I'll use on the plane, everything else gets Titebond wood glue.
The blind nuts are 2-56, Dubro sells 2-56 allen hardware I really like.
JPvelo
JPvelo
Post  roddie Sun May 22, 2016 4:55 pm
JPvelo wrote:Roddie,
Cool! I've used allen-head screws to mount my engines on my last few builds.. and they're sOoOo much easier to work with! Most everything on little airplanes is tedious! That carbon-fiber veil is pretty cool man! That should work well for your needs. Are there different weights/grades that it's offered by.. kinda' like fiberglass cloth?
Post  pkrankow Sun May 22, 2016 6:12 pm
Carbon cloth and glass cloth are somewhat similar. They are built from "yarns" if twisted, or "tow" if not twisted (more common).
Glass cloth and carbon veil are not very similar. Veil is non-woven and somewhat similar to tissue paper.
Post  JPvelo Mon May 23, 2016 12:05 am
Here's how the panel lines worked out. I need to install the engine with the spinner and possibly massage the shape of the top just a bit.
Chambers R-1 build - Page 2 P0kmANs
It's looking much more proportional with tail feathers:
Chambers R-1 build - Page 2 TTAp2sJ
Chambers R-1 build - Page 2 XmpQ5e0
Chambers R-1 build - Page 2 IHYUWSx
JPvelo
JPvelo
Post  stuntflyr Mon May 23, 2016 8:55 pm
Nice, Jim.
Chris...
stuntflyr
stuntflyr
Post  getback Tue May 24, 2016 6:51 am
You are doing one heck of a job with the model , But to be honest that is one large fuse!! Kind of a strange looking plane anyway and I hope it fulfills its purpose and I know it will from your passed builds . getback tongue
Post  JPvelo Tue May 24, 2016 1:42 pm
Eric,
Yeah it's a funky looking one. Here's the full 3-view.
Chambers R-1 build - Page 2 XIOzpK5
JPvelo
JPvelo
Post  JPvelo Tue Jun 28, 2016 6:52 pm
I'm in a leadership training program at work that's taking up all of my spare time so I've not been able to get much done on the R-1. I did find time to finish laminating the control surfaces and get preliminary sanding done. Hope to get carbon veil on the fuse before I leave town next week.
Chambers R-1 build - Page 2 RMVaVmI
Chambers R-1 build - Page 2 6virHxk
Chambers R-1 build - Page 2 OtBM5ZU
JPvelo
JPvelo
Post  Cribbs74 Tue Jun 28, 2016 11:03 pm
That's a good looking plane Jim. I enjoying seeing builds that are different from the usual stuff. Good work as always!
Post  JPvelo Wed Jun 29, 2016 2:49 pm
Thanks Ron!
I managed to sneak a little work in today. I suspect this thing is going to land like a brick so I built some structure into the tail skid mount.
Chambers R-1 build - Page 2 MyhgslV
I also added a 1/32 ply biscuit to the very tail end of the fuselage so I can sand it to a point without it getting to fragile.
Chambers R-1 build - Page 2 I9eAeEz
Chambers R-1 build - Page 2 BpHa1XS
Ailerons are now seperated from the wing.
Chambers R-1 build - Page 2 CecVjq0
JPvelo
JPvelo
Post  ian1954 Wed Jun 29, 2016 3:13 pm
All the parts look like perfect fits with no visible glue lines.
A few posts mention "Carbon veil". I only see this as carbon fibre tissue here.
https://www.deluxematerials.co.uk/gb/rc-modelling/97-carbon-fibre-tissue-5060243901361.html
Is this the same stuff?
ian1954
ian1954
Post  JPvelo Wed Jun 29, 2016 3:23 pm
ian1954 wrote:All the parts look like perfect fits with no visible glue lines.
That's the stuff.
JPvelo
JPvelo
Post  JPvelo Fri Jul 01, 2016 11:42 pm
Made a little progress today. Glued on the vertical stabilizer and the sub fin under the rudder.
Chambers R-1 build - Page 2 CemxTiX
Here's the profile with full vertical stab and rudder in place.
Chambers R-1 build - Page 2 DCOUKil
That's going to be it until I get back from vacation. My wife and I are driving to Idaho early Tuesday morning to do an 80 mile mountainbike tour, camp next to a river in grizzly country, see family, and generally escape the heat for a week.
JPvelo
JPvelo
Post  roddie Sat Jul 02, 2016 12:04 pm
That's such a cool looking fuse Jim! I have a question about the ailerons though. Seeing that you cut them out.. will they be operational as "flaps"?
Maybe I missed something.. but I'm wondering how you'd make them work without fabricating "lucky-boxes" on each flap, to accept a torque-rod having angled-ends, perpendicular to the hinge-lines. This would require two bearing-tubes cut into the wing and a steel horn brazed onto the torque-rod in between them,. and in line with the pushrod.
Please excuse my crude use of "Paint".. Rolling Eyes
Chambers R-1 build - Page 2 Cecvjq11
Maybe you'd want to only make the inboard flap operational? That might help with line-tension.. and landing squarely-level on the gear? Just a thought... and something to ponder while you're on vacation. Have a good "safe" time!
Post  JPvelo Sat Jul 02, 2016 3:30 pm
Roddie,
The flaps are for scale effect only. They will be attached with light gauge music wire. I will be able to tweak them on the ground a little bit but they are essentially fixed in place.
JPvelo
JPvelo
Post  roddie Sat Jul 02, 2016 4:53 pm
Rolling Eyes  Rolling Eyes Serves me right for assuming Jim. Please humor me.. I've been brainstorming.. for the last hour; trying to figure out a way to make them functional..
(before reading your reply..)
Another matter to consider, is a lead-out guide arrangement with operational-flaps on this design. If you wanted/needed a raked-back guide.. it would need to be lower (or higher) than the inboard flaps' deflection out at your wingtip.
Concerning my previous post.. I've never had to couple flaps that were cut-in on an angle like that. Remember the lucky-boxes on Rusty's "Yak-9"? This may be the only way to couple the flaps on your model.
Chambers R-1 build - Page 2 Rustys10
Chambers R-1 build - Page 2 Rustys11
Rusty was able to drive his flaps with a horn; independent of the flap-linkage. Where yours are out further from the chord; you'd need to braze a metal horn onto the linkage-wire itself. If you used .045" music-wire, it should be strong enough, without adding too much weight. The alloy-tube (bearing) material for this size wire is 1/16" OD.. and would be invisible once installed in your sheet-wing. Make a horn from 16ga. steel sheet and use a #56 drill (.046") for a thru-hole to silver-solder/braze to the flap linkage. Your pushrods (bell-crank to flap-horn and flap-horn to elevator-horn) could also be .045" music-wire.. but keep in mind that many off-the-shelf 1/2A bell-cranks/horns have pre-drilled holes for 1/16" (.062") music-wire. Sig's #SH-234 1/2A bell-crank/horn set has holes for .045" wire. Install a pushrod support-guide halfway between the wing and stab.. and you'd be all set for your control-linkage.
