how to remove the crank from a td 0.10. Cox_ba12
how to remove the crank from a td 0.10. Pixel
by getback Today at 12:05 pm
by getback Today at 11:53 am
how to remove the crank from a td 0.10. Empty
Help! how to remove the crank from a td 0.10.
Post  preecy Wed Dec 02, 2015 3:49 pm
can anybody tell me how to remove the crankshaft from my td 0.10 , as i need to change the piston thanks,
preecy
preecy
New Member
New Member
Help! Re: how to remove the crank from a td 0.10.
Post  Kim Wed Dec 02, 2015 5:08 pm
WELCOME TO THE FORUM!
If you unscrew the back plate and cylinder, you can remove the piston and connecting rod without pulling the crankshaft.
Post  Jason_WI Wed Dec 02, 2015 8:35 pm
You will need to use the .010 wrench to remove the cylinder. If you don't have any get a pair from Cox International or EXModel Engines.
The .010 cylinder is extremely thin at the exhaust port so you must be careful not to turn a burr into the cylinder or even deform the cylinder rendering it useless. Use of a pliers is definitely NOT recommended. Heat from a hair dryer helps if the cylinder is stuck. Carefull not to melt the tank or carb body with the heat.
Welcome to the forum.
Jason_WI
Jason_WI
Post  Mudhen Wed Dec 02, 2015 9:20 pm
Mudhen
Mudhen
