by getback Today at 12:05 pm
cox piston with bulge on top
yesterday or the day before someone, it's really late here is So. Cal., showed a Cox piston with a bulge on the top of the piston head. We all thought it was a loose connecting rod banging into the head of the piston. This picture comes from a Cox Dragonfly I was cleaning up to put on ebay. As I looked it over I thought I saw a little bulge on the top of the piston head, so I flicked what I thought was crud off the piston and to my surprise this is what I saw.
I'll post the pic when host it gets fixed. I can't host from my pc or from postimage.com ????
sorry it took so long. Something happens when you get old, but I can't remember what it is. HD
a hole in the top of the piston with the connecting rod poking thru. look closely.
happydad,. still retired, but ...
happydad- Rest In Peace
Re: cox piston with bulge on top
Looks like you got the finished product from the other day pic . I think that was Joe that had that other one ( yea that s nice )
Punched crown as I call it, happens when the con rod is reset too tight or the engine has a lot of time on it, also does happen with a excessively loose rod. I diagnosed one the other day with a club member, it was an old babe bee that had great compression and ran fine but suddenly started loosing power and kept quitting, he brought it over to me and I checked it out for him and found it had lost compression so I checked the head to make sure it wasn't loose, it wasn't so I popped the head off and there ya go, same issue. sucks. Only fix is a new P/C set (Bandit)
TDbandit- Platinum Member
Or just another piston. I wouldn't hesitate to scavenge a piston out of the parts drawer and use it without replacing the cylinder.TDbandit wrote:Punched crown as I call it, happens when the con rod is reset too tight or the engine has a lot of time on it, also does happen with a excessively loose rod. I diagnosed one the other day with a club member, it was an old babe bee that had great compression and ran fine but suddenly started loosing power and kept quitting, he brought it over to me and I checked it out for him and found it had lost compression so I checked the head to make sure it wasn't loose, it wasn't so I popped the head off and there ya go, same issue. sucks. Only fix is a new P/C set (Bandit)
You're right *bops self in Head* have a habit of replacing p/c sets as matched sets keep forgetting that cox is one of the few that you can mix, match cylinders and pistons (bandit)RknRusty wrote:Or just another piston. I wouldn't hesitate to scavenge a piston out of the parts drawer and use it without replacing the cylinder.TDbandit wrote:Punched crown as I call it, happens when the con rod is reset too tight or the engine has a lot of time on it, also does happen with a excessively loose rod. I diagnosed one the other day with a club member, it was an old babe bee that had great compression and ran fine but suddenly started loosing power and kept quitting, he brought it over to me and I checked it out for him and found it had lost compression so I checked the head to make sure it wasn't loose, it wasn't so I popped the head off and there ya go, same issue. sucks. Only fix is a new P/C set (Bandit)
When I retired a few years back, found this site, and started up my model airplane playing after a very long absence, I went way over board not realizing Cox made millions of these lil buggers. I did not know Bernie or Jason were reselling NOS and purpose built engines.
Long way to say I bid and won a LOT of engine Lots and the occasional good looking Baby Bee, TD, or Medallion
Later I read Paul Gibeault's mouse motor set up recipe and hints
Sorted all the parts paying attention to cylinder configuration and then cleaned each Cyl and piston, finally trying each piston in a cylinder until I got good at the drop out fit
Next I taught myself how to set the pistons with what I believe were junk pistons
Then I reset each piston and found that I should have done that first as now I needed to go back and re-establish best fitting combinations
OK a lot of words (for new folks who may not know this stuff) to say that Bandits mention of "keep forgetting that cox is one of the few that you can mix, match cylinders and pistons " is partly true but proper fit may require some thought and work
ON the other hand; I remember as a kid just running the bee-gee-sus out of the Cox .049s with any old fuel we could scarf up for weekend flying. Some times we just mixed and matched parts to get one working never thinking about the engineering behind making one run the best it could or last for any length of time
Yeah that was mine. I swapped it out for one in better shape. I may put it on an old Bee and let it run until it blows. Remember to always wear eye protection.
Joe
Joe
jsesere- Rest In Peace
» Wanted: Cox .15 piston, or piston/cylinder - FOUND!
» .010 piston or piston/cyl. assy.
» Piston/rod...
» Rusted piston
» Piston/rod...
» Rusted piston
