» COX .020 POWERED SPEEDSTERby TD ABUSER Today at 8:28 pm
by EXModelEngines Today at 7:29 pm
» BMFA. UK AUCTION
by rsv1cox Today at 7:25 pm
by rsv1cox Today at 7:20 pm
» Pt19 pilot and windshield
by rsv1cox Today at 4:18 pm
» Cox Star Cruiser Instruction/Manuel/Information
by DanMc Today at 9:47 am
by roddie Yesterday at 5:50 pm
by Cox International Yesterday at 12:32 pm
» Stealth SB-X
by getback Yesterday at 8:15 am
by Ken Cook Yesterday at 3:39 am
by rsv1cox Sun Oct 20, 2024 8:04 pm
by roddie Sun Oct 20, 2024 5:44 pm
Rusted piston
Re: Rusted piston
The problem is that rust equates to pitting. Even if you get it apart, more than likely it's performance if it runs is going to be compromised. I've salvaged some by installing the piston upside down and using fine polish and a lap tool I made to polish out areas. Unfortunately, the cylinder itself usually ends up being the worst. Heat is what I use . I use a paint stripping heat gun and if that isn't enough, I carefully use the propane torch.
Re: Rusted piston
Ken, Thank you for the info!
midtown711- Moderate Poster
Piston
Hi midtown,
I think I would try putting some old car engine oil in an old saucepan, enough to cover the cylinder and heat using a camping cooker to heat the part. Heat to expand everything evenly and the old oils cleaning action on the rust.
Do it outside in dry weather. When old oil starts to smoke, turn off heat and try to move the piston.
A wood dowel as a punch to gently tap the piston crown, it's top, out.
Good gloves needed as the cylinder will be hot.
Several attempts may be needed.
Hope that works for you.
Coxfledgling- Gold Member
Re: Rusted piston
are you sure its rusted, and not just dried glow fuel gunking up the works?
i like the ideas others presented here.
I am a HUGE fan of gently warming it with a heat gun. see if that will free it up.
if not?
https://coxengines.ca/top-end/cox--049-tee-dee-cylinder-and-piston.html
if not?
cstatman- Platinum Member
Re: Rusted piston
If it is rust then simply clean with kerosene. Works.
Levent Suberk- Diamond Member
Re: Rusted piston
cstatman wrote:are you sure its rusted, and not just dried glow fuel gunking up the works?
Those were my thoughts, also. The cylinder in the picture looks pretty bright and dried castor can sometimes have an amber or reddish color.
» The knob broke off...
» Another rusted engine! Full size....
» Wanted: Cox .15 piston, or piston/cylinder - FOUND!
» .010 piston or piston/cyl. assy.
