new reed fit problems
Has anyone else had problems with new reeds not fitting in the plastic retainer? I had this before, and it wouldnt fit without bowing in the middle, so I carefully sanded one edge until it would lay down straight, and would rotate freely when assembled. I didnt think to much of until I tried another one from stock today. I was the same. Any tips on fitting reeds would be appreciated.
chevyiron420- Gold Member
Re: new reed fit problems
Sometimes the mylar reeds have a ridge or curl around the edges left over from being stamped out of the mylar sheet. I haven't had any that fit like you're describing, but have had some that wouldn't pass the suck/blow test in one direction. Flipping it over usually makes it work. And sanding the edges with some very fine paper generally cures them. I think the tool doesn't always make a clean cut. I don't know how many layers of film they try to punch them out of, maybe too many.chevyiron420 wrote:Has anyone else had problems with new reeds not fitting in the plastic retainer? I had this before, and it wouldnt fit without bowing in the middle, so I carefully sanded one edge until it would lay down straight, and would rotate freely when assembled. I didnt think to much of until I tried another one from stock today. I was the same. Any tips on fitting reeds would be appreciated.
Same here, i've had a few that had burrs on them could be that the die is getting dull. (Bandit)
TDbandit- Platinum Member
These reeds from VGE are OEM and most likely better, I haven't tried em yet though
http://www.ebay.com/itm/OEM-Cox-049-Airplane-Engine-Nylon-Reeds-Lot-of-20-/131501865490?pt=LH_DefaultDomain_0&hash=item1e9e1f3a12
He also has some for Pee Wee
http://www.ebay.com/itm/OEM-Cox-Airplane-Engine-020-Pee-Wee-Nylon-Reeds-Lot-of-20-/171775890604?pt=LH_DefaultDomain_0&hash=item27fea414ac
crankbndr- Top Poster
This would be something hopefully Bernie could address.
Greg
Greg
Sig Skyray- Gold Member
Some sharp scissors are quicker than sanding. I'm not going to call sanding wrong though.
Sanding has more Zen than scissors. I'm an old hippie.pkrankow wrote:Some sharp scissors are quicker than sanding. I'm not going to call sanding wrong though.
I am sure all three I bought are oversize. I thought someone else would have run in to this that is more familiar than I am with this style reed, and how loose they should fit. I will post more on my blackwidow thread.
With the plastic retainer the fit can be quite sloppy loose and preform fine. The wire G clip is more particular to the fit, since the retaining area is much much smaller.
I just want to know , can you put a Mylar reed in a sportsman 15 ? and I would like to add that there is enough material left on the sheet to cut several more freebies
getback wrote:I just want to know , can you put a Mylar reed in a sportsman 15 ? and I would like to add that there is enough material left on the sheet to cut several more freebies
Can't see why not to. It's the same setup as any .049.
» Test Report - Babe Bee & Golden Bee
» Tee Dee flooding problems
» Teething problems
» Cox PeeWee .020 Problems
» Teething problems
