» Chocolate chip cookie dough.........by rsv1cox Today at 11:20 am
by rsv1cox Today at 11:07 am
by rdw777 Today at 10:24 am
by batjac Yesterday at 10:47 pm
by roddie Yesterday at 9:50 pm
by getback Yesterday at 1:05 pm
by rsv1cox Wed Nov 20, 2024 4:21 pm
by 1975 control line guy Wed Nov 20, 2024 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
cox 049 diesel talk
cox 049 diesel talk
hello
for all of you who are just interested in the engines and not the generator your home is here
i myself have 1 diesel cox that sits in a generator
runs great
but when i got it it was hard to start
this was becaus of a double reed
now that is fixed the engine runs and starts awsome
one dieselhead i got for free witch does not woek (1970? homebuild)
its litterly a countersunk bolt trough a glowhead (countersunk part down)
and i am rebuilding a 049 car engine to be diesel (the one with pull starter)
on this one i already have tempered the head
tomorrow i am gonna cut 13mm coper disks (0.1mm) to test in my diesels
that is my story so far
please be free to share your experience with these engines
runs great
robot797- Platinum Member
Re: cox 049 diesel talk
i made some copper disks today
they work great
but somhow i cant turn the compression high enough to get great rpm
anny advice?
they work great
anny advice?
Check how far up the piston goes in the bore at TDC. This can vary from one engine to another. A worn conrod/piston assembly will also make the piston sit too low at TDC. If the piston is too low at TDC, then you can shave off a little of the crank-case top to lower the cylinder.
Also, you don't need any gasket below the disc when the disc is made from copper or brass. So in case you have that, simply remove the gasket.
mmm that could help
will try it after i get some more ether
Very interested in this topic. I was just starting to wonder about trying to convert an engine to use either nitro or diesel. If I read this correctly, you just installed a copper disc in place of the head gasket? Pictures would also be appreciated. Funny thing is that today at work, I was talking to a co-worker about diesel engines. Thank you.
NEW222 wrote: If I read this correctly, you just installed a copper disc in place of the head gasket?
No not really, the compression ratio needs to be adjustable and it is very sensitive.
The best way is to buy a conversion head made by RJL, and sold by Mecoa.
i have seen engines that just use a copper disk under the glow head
it can be done but they run verry bad
i agree with kriss
but there is also the davis diesel one
but that uses teflon disks
i agree with kriss
robot797 wrote:
i agree with kriss
I have the Davis one. The Teflon disks were designed to blow if you over-compress the engine enough to overheat it. Saves the engine. Some folks do not like that margin of safety and prefer the RJL one. If you start breaking crankshafts, there is a heavy-duty crankshaft available.
gcb- Platinum Member
The problem with the Teflon disc is that they don't seal well enough and they always break sooner or later...
A leaking head ca be very dangerous on a diesel engine, it will trick you into increasing the compression ratio until it fires and then the compression ratio is too high and something will break...
i agree with kriss again
but i must also add that a brass or copper disk would not break as fast
but you lose the protection of the teflon
There is another problem with the Teflon, it doesn't hold heat well and the engines doesn't run as well as with a metal head.
Yet another issue is that the disc covers the whole cylinder bore and the screw for the counter piston becomes very sensitive.
And the list goes on. The head is too simple in its construction to make a usable product, and one is much better of with a proper diesel conversion head.
All these things were well known and criticised when Davis Diesel Development came out with these heads some 35 years ago (or is it more?). There was therefore a lot of competing companies with better products. Such as RJL and even a swedish one called Böhlin (made by Mats Böhlin, an engine builder and competing in F2C at the time).
to bad most of the good head are not around anymore
The RJL ones are readily available from Mecoa, there is really no reason for using anything else;
http://mecoa.com/acc/diesel/index.htm
yea i know that site
but i dont know what shipping to holland would be
the main site is kin d of confusing
The site is just old, I haven't had any problems with ordering from them in the past. If you only buy a conversion head I think the shipping will be around $10. Just send them and e-mail and ask for a quotation. They have many other useful things too, such as really small spinners with cox engine adaptors.
mmmmm
an email will be send
to bad there arent 5-40 to metric adapters (as fas as i know)
Man Thanks that place has all kinds of good stuff , things for cox engines others don't carry !?!Surfer_kris wrote:The RJL ones are readily available from Mecoa, there is really no reason for using anything else;
» Introducing the Blue Bee, the Blew diesel Medallion, and the disappointing OK Cub diesel.
» My DIESEL fleet and Diesel fuel blending DIY
» Diesel Fuel Question
» Enya .15 diesel MK II
» Lucky 13 Rides Again !!!!
