» Tee Dee .020 combat modelby rdw777 Today at 9:35 am
What is a good 6x3 prop?
Page 2 of 2
Page 2 of 2 • 1, 2
Re: What is a good 6x3 prop?
Actually one would have to look at all factors, not necessarily running at an RPM that is at the highest HP output will give the best flight. It all depends on the type of plane, desired performance, etc.
Granted the 6x3 prop may not place the static run Tee Dee .049 at its highest horsepower, when it is in the air dynamics change. Also, satisfactory flight is depended on the torque curve as well as the HP curve.
According to SceptreFlight Nov-62 Aeromodeller Cox Tee Dee .049 by R.H. Warring, the torque curve is relatively flat from 13,300 to 20,000 RPM peaking at 18,000 RPM, decreasing as one approaches maximum HP at 22,000 RPM. A Top Flite nylon 6x3 prop with 25% nitro turned at 18,400 RPM, at the peak of the torque. A 5.25x3 TF nylon turned 21,000 RPM toward its maximum HP.
SceptreFlight Dec-61 Model Aircraft Cox Tee Dee .049 though not stated appears to be written by Peter Chinn. It's observations are similar.
CL fliers take advantage of the torque curve, turning larger props at slower RPM and slowing engine speed down a little running a rich 4 cycle that breaks into 2 during stunts even though modern sport Schneurles are designed to provide more power at higher RPM's.
Figuring that the engine unloads once plane is up to full speed means an another 1,000 - 2,000 RPM to the static bench running figures, bringing the engine closer to its higher horsepower figure.
Thus as Bernie points out, the sales of the props with feedback from buyers tell a slightly different story. In the right setting, that 7x3, 7x4, 6x3 or 6x4 prop may be more than suitable on the Tee Dee .049 although it is not driving the engine at its maximum rated horsepower. Then other factors enter in such as fuels and glow heads.
Also of interest, according to SceptreFlight May-61 Aermodeller Cox Babe Bee & Golden Bee the 6x3 and 6x4 props run close to maximum HP, making them the right prop for these engines. I like them for my Black Widows.
Prop selection is perhaps more of an art than science.
Dec-61 Model Aircraft wrote:Performance. The Tee-Dee .049 was very definitely much happier when allowed its head - in other words, when permitted to turn at least 17,000 r.p.m. This is not to say that the engine lacks power when loaded for lower speeds. One of the remarkable features of the .049's performance is its ability to turn comparatively large props (e.g. 7x4, 7x3) faster than any other engine of similar capacity. However, it is apt to become a trifle uneven and for r.p.m. to wander slightly on such props, whereas it smooths out at above 17,000 and is absolutely rock steady at speeds around the b.h.p. peaking speed of 21,000 r.p.m. The fastest we had the .049 turning was 23,000 and it seemed quite prepared to go on at this speed indefinitely. [....]
The actual torque developed by the Tee-Dee .049 was the highest yet recorded in this series for a 0.8 c.c. engine and reached a maximum of 8.1 oz. in. at around 14,000 r.p.m., equivalent to a brake mean effective pressure of approximately 64 lb./sq. in. - a figure which, a few years ago, would have seemed impossible with a Half-A glow engine. The decline of the torque curve was at an almost constant ratio up to 20,000 r.p.m. and resulted in the quite phenomenal b.h.p. of .145 at 21,000.
I really like the 6x3 and 6x4 props on my stronger reed engines. For CL flying the 5 inch props just don't pull as well. I never thought of trying a 7 inch prop on either a bee or TD for my flying, but might have to give it a go once.
Regardless of suitability for a particular engine or application, we are approaching this on a business level. Having sold about 6,000 props 6x3 in a few years, and almost out of stock, we are simply sourcing a replacement.
Not too sure what our buyers do with the props but they sure sell well
Sorry, Bernie, this is the wrong place for such a debate. What I said in my first paragraph of my most recent post was meant to be relevant and helpful to your selection of a new 6x3 source. I should have left it there.
I wrote: I think the best thing about the Cox 6x3 is the reason it's coined the "Rubber Ducky." Nobody I know of makes props that are as indestructible these days. My direct replacement for my Cox and Norvel engines is the MA GF series 6x3 which I cut down to my preference. They will break but are not as fragile as APC and others. Usually not on a dead stick nose-over landing.
As this being said Bernie , Do you believe the replacement should be as close to the original as possible to assume the sales will bee the same ? If using a different product may not sell as well ? And is it asking too much of A company already set up to make a prop could not make a mold from the assisting product in question at a reasonable price knowing you would buy more or could have a byers contract to purchase a amount in a reasonable amount of time . I just think that if it sells that good don't change it . EricCox International wrote:Regardless of suitability for a particular engine or application, we are approaching this on a business level. Having sold about 6,000 props 6x3 in a few years, and almost out of stock, we are simply sourcing a replacement.
I think it not a matter of debate but rather discussion. Everyone approaches from their own view point tempered with their experiences and preferences. Each has a unique viewpoint. There is not wrong, it is just a matter of personal context related to their use.RknRusty wrote:Sorry, Bernie, this is the wrong place for such a debate. What I said in my first paragraph of my most recent post was meant to be relevant and helpful to your selection of a new 6x3 source. I should have left it there. RustyI wrote: I think the best thing about the Cox 6x3 is the reason it's coined the "Rubber Ducky." Nobody I know of makes props that are as indestructible these days. My direct replacement for my Cox and Norvel engines is the MA GF series 6x3 which I cut down to my preference. They will break but are not as fragile as APC and others. Usually not on a dead stick nose-over landing.
I pointed out from Warren's and Chinn's articles to show that there is technical justification to prop use and may explain why sales are popular for these size of props. Of course it may be that some use them as paint stirrers.
Probably the closest to the old nylon unreinforced Cox props might be the Grish Tornado nylon props. I don't know if they are still available. I liked the old Top Flite white nylon props with red silk screening, they were decent props for the reedies. Too bad they are no longer made.
Page 2 of 2 • 1, 2
» Anybody have atwood boat engine parts that you would part with???
» Kyosho Cox .049 Mini Cooper Engine Assembly
» cox 4x2.5 prop?
» Cox Prop Rod
» cox 4x2.5 prop?
» Cox Prop Rod
Page 2 of 2
