Plug it or use it? Cox_ba12
Plug it or use it? Pixel
Plug it or use it? Empty
Plug it or use it?
Thinking Plug it or use it?
Post  Forgetful John Wed Mar 04, 2015 7:53 pm
Good evening,
I have a well used TD 049 that is drilled for pressure at the factory nipple and the venturi has also been drilled out.  It looks like a real runner Flying .  I compared the venturi to one that is not drilled and it is bigger by a little.  I thought about putting the smaller venturi on it but I could not find in the search anything concerning sealing the drilled crankcase.
Does anybody have an experience with plugging the crankcase?  Or should I run it on pressure like it is?
I know it will probably slice my finger either way.
What do you say, guys?
John
Forgetful John
Forgetful John
Silver Member
Silver Member
Thinking Re: Plug it or use it?
Post  Mark Boesen Wed Mar 04, 2015 9:46 pm
As long as it works you can seal it about anyway you want: silicone glue or cap it off with plastic (vinyl) tubing melted on end, apply warm, when cold it should lock on. Or run it on pressure, thats usually a good thing.
Post  GallopingGhostler Wed Mar 04, 2015 10:52 pm
One could also seal the hole with J.B. Weld. Just keep it off the interior bearing surfaces.
Post  Forgetful John Thu Mar 05, 2015 5:39 pm
I think that I will try to run it on pressure with the larger venturi then, just for grins before I plug it, if I do.  Will post my results if I make the change.
Not much to attach a pressure line onto but I have seen topics here dealing with that, just didn't think it would apply to me until I got this new (to me) engine. I've been lurking on this site for a while before registering.
My last TD 049 was mounted in a Twilighter (scratch buiilt from a Randy Randolph plan from Model Builder) and it greatly advanced my flying success as I was learning to fly R/C by myself; but it did not have and certainly did not need pressure.
It sure has a lot of "provenance"-- bored out venturi, drilled for pressure, great compression, scrapes on the spinner, cracked carb body and what appears to be a well made one-off motor mount of bar stock, somebody certainly had a long relationship with this one.
If they could only talk...
Ok, good advice, thanks!
John
Forgetful John
Forgetful John
Silver Member
Silver Member
Post  GallopingGhostler Thu Mar 05, 2015 6:11 pm
Forgetful John wrote:If they could only talk...
Engines do talk, John. Wink
With tight gaskets and good compression in good state of repair with the right prop, right glow plug or glow head, right fuel with right oil and right mixture setting, they sing! Very Happy
Good luck with your prized engine, please give us a run report! Thumbs Up
Post  RknRusty Thu Mar 05, 2015 6:37 pm
Yeah and a video would be great too. We love those.
Post  Forgetful John Thu Mar 05, 2015 7:43 pm
Y'all know what?
"GallopingGhostler" has pretty much --  "Said It All!" Beer Cheers
I'll re-assemble the TD 049 on pressure with a small tank for a bench run.and see how wild of a song I hear!
I would like to think that this engine must have been very special to someone for all that attention so I might as well see what it will do before I attempt to neuter it back to stock.
Forgetful John
Forgetful John
Silver Member
Silver Member
Post  getback Fri Mar 06, 2015 6:53 am
Great decision John , If it were that special to someone else there is a song to sing in its self .
