Need some help with parts identification Cox_ba12
Need some help with parts identification Pixel
Need some help with parts identification Empty
Need some help with parts identification Empty Need some help with parts identification
Post  acprc Sat Feb 14, 2015 5:08 am
Hi all,
New to the forum and Cox engines and if possible I am after some expert help. I'm a collector of all things vintage nitro based in the UK and recently picked up a Cox 0.49 Stocker. Its the newer version, kit number 9160 circa 1990.
I am going to fully restore the car for my collection but need some help with the engine parts. I didn't get a manual but the downloaded one doesn't give me any help with the parts breakdown of the engine.
I need a new cylinder and piston and there seems to be a lot of 0.49 variants about. Can anybody help with advice on the engine model fitted and or a manual?
Will get some pictures of the finished article soon but this is how she came to me: http://www.tamiyaclub.com/showroom_model.asp?cid=121715&sid=4
Thanks for your help in advance
Adam
acprc
acprc
New Member
New Member
Need some help with parts identification Empty Re: Need some help with parts identification
Post  Oldenginerod Sat Feb 14, 2015 6:00 am
G'day from OZ Adam. Glad you could join us. There's folks here who will be able to give you far better advice than me, but can I suggest that you contact Cox International http://coxengines.ca/
or Ex Model Engines http://www.exmodelengines.com/
They should be able to help with a suitable cylinder/piston. Have a close look at the cylinder and see if there is a number stamped on it. It will be either below an exhaust port or on the flat section on the inside of an exhaust port, right hand side generally. Most car engines I believe only had a single by-pass port in the cylinder and did not have sub piston induction because they used a muffler. A good look inside the cylinder should tell you if it's single port and if you look into the exhaust port while held up to the light while turning it past top dead centre you should not see any light below the piston skirt. This is all assuming it has its original engine or cylinder. Finding out the exact engine configuration for this particular model may prove difficult, but if anyone can help, the folk on this forum should be your best shot.
Cheers.
Post  roddie Sat Feb 14, 2015 3:06 pm
I don't know how much help this will be.. but here's some part#'s from a 1991 Cox list I dug up.
Need some help with parts identification Dsc02459
Need some help with parts identification Dsc02460
Need some help with parts identification Dsc02461
Need some help with parts identification Dsc02462
Post  Admin Sat Feb 14, 2015 3:44 pm
Need some help with parts identification Engine10
Did you download the manual here yet?
Since it uses a throttle ring, you're going to need a ground cylinder where the blued (black colored) finish was ground off. The manual calls for a 1477 piston/cylinder assembly and this seems the closest you're going to get to that http://www.exmodelengines.com/product.php?productid=17765&cat=267&page=2
Need some help with parts identification IMG_2318
The guy you're going to want to talk to around here is Jason_WI, he's our GTP Nissan, Stocker, Indy... guy.
Last edited by Admin on Sun Feb 15, 2015 3:32 am; edited 1 time in total (Reason for editing : spelling error)
Post  roddie Sat Feb 14, 2015 4:41 pm
My 1992 Cox parts listing has a better breakdown of engine parts.. and indeed lists the piston/cylinder set as #1477 for the "Throttle Muffler" equipped (engine #24909). If by chance you have a "Maples" equipped throttle, then the piston/cylinder set is #1472.. and the complete replacement engine carries the #24910.
Need some help with parts identification Dsc02463
Need some help with parts identification Dsc02510
Post  acprc Sun Feb 15, 2015 12:03 am
Thanks all.
Exactly what I needed. It doesn't have the Maples throttle fitted, would love to get one actually but that wont be easy. The parts breakdown has exactly what I need to get the engine up and running again.
acprc
acprc
New Member
New Member
