Sealing Decals From Fuel Cox_ba12
Sealing Decals From Fuel Pixel
by rdw777 Yesterday at 5:07 pm
Sealing Decals From Fuel Empty
Sealing Decals From Fuel Empty Sealing Decals From Fuel
Post  kpriddle Thu Jan 01, 2015 4:16 pm
Hi, everyone:
I'm building an Ace Simple Series Corsair and documenting it over on RCGroups, but seeing how many of us have moved to this forum, I'd like to pose my question here.  I'm trying to seal hinges and decals which lie over Helsman Spar Urethane.  Can anyone share their method for sealing? Might nail polish fit the bill?
Sealing Decals From Fuel A7422110
Many thanks,
KP
kpriddle
kpriddle
Bronze Member
Bronze Member
Sealing Decals From Fuel Empty Re: Sealing Decals From Fuel
Post  RknRusty Thu Jan 01, 2015 8:51 pm
Hi KP, I used to spend a lot of time at RCG, and remember you from there. My recent interests have caused me to defect to Stunthangar, with CEF being my hobby anchor.
Clear fingernail polish seals them, but on the last two planes I used it, it turned white after cleaning with alcohol. For the sake of looks, I had to rub some clean castor oil on it to make the white disappear. Maybe I bought the wrong kind.
On other planes, I have masked around the decals and sprayed several dustings of Lustrekote crystal clear. Mine were applied on top of Rustoleum paint, so I don't know if the urethane will have a problem with Lustrekote. But I have gotten overspray on Minwax Polyurethane and it didn't phase it.
I use either sewn hinges, fabric or pin hinges, so I've never thought of sealing them. Can't offer any help there.
Post  Ken Cook Thu Jan 01, 2015 8:57 pm
I used to seal all of my decals with Minwax polyurethane. The only problems I encountered was yellowing. Ken
Post  andrew Thu Jan 01, 2015 9:13 pm
K --
Fingernail polish generally contains acetone which will melt foam. If you decide to try fingernail polish, test it on a safe location before use.
I usually seal trim and decals with clear butyrate dope -- again, you may want to test it on a scrap piece of decal material. Some decals will bubble or wrinkle with dope.
Post  kpriddle Thu Jan 01, 2015 10:16 pm
Thank you for all the responses. Rusty, may I ask how long the polish took to turn white? I usually use a light spray of Windex on a paper towel. I read elsewhere that Windex contains isopropyl alcohol, but I don't know if it contains enough to harm the polish.
Either way, I have three types of polish on a test piece now and will give all three a go with Windex. I'll post the results...
KP
kpriddle
kpriddle
Bronze Member
Bronze Member
Post  ian1954 Fri Jan 02, 2015 4:06 am
I am sure that clear finger nail polish will not be fuel proof. The main constituent is nitro cellulose and this is not fuel proof.
A coat of butyrate dope will be fuel proof but only with low nitro fuels. From the Windy videos I watched, it was his conclusion that it was only fuel proof to 5% nitro and definitely not to 10%.
From my own experience, butyrate dope (or the version I used) was definitely not fuel proof at 20%.
Ron has been bravely flying the Rocking Donkey - This has decals and was coated with this stuff
http://www.pegasusmodels.co.uk/product.asp?prodid=995857#.VKZsUp1FCUk (probably not available in the US)
I believe he used 30%+ nitro so it would be interesting to see if the decals have survived ( Apart from his attraction to landing upside on concrete and flying into trees! lol! )
ian1954
ian1954
Post  RknRusty Fri Jan 02, 2015 10:54 am
It turned hazy white before I ever flew the plane. I would rub some oil on it and it would look a lot better.
Post  pkrankow Fri Jan 02, 2015 5:40 pm
If you are using polyurethane varnish already, use some more polyurethane varnish to seal the decals. This is easiest and know to work, as long as it doesn't wrinkle or damage the decals. Look up the product you are using, there usually is an amber varnish and a clear varnish in most product lines. Use the clear.
Post  kpriddle Fri Jan 02, 2015 7:02 pm
Ian, as you said, the nail polish wasn't fuel proof on any of the three polishes.  After reading Rusty's post about the nail polish turning white before alcohol was applied, I thought I'd skip the alcohol and go straight for the fuel.  It definitely didn't work with 25% nitro.  Also, I can't seem to find the videos you refer to.  Do you happen to have the link (if not, no worries)?
By now, I'm thinking I will settle on Sig Butyrate Dope (I'll have to go pick some up tomorrow) or Helmsman Spar Urethane.  Phil, my only issue with using the urethane is that I have gotten very grainy results from spraying multiple coats of this stuff (a wet over a dry).  One rather wet coat is usually the best.  By the way, if anyone is interested, I highly suggest checking out post #15-#25 HERE.  This stuff is very fuel-proof, yellows little to none, can be sprayed on lightly, and dries quickly (although my tests have shown that two days of drying is best for "fuel-proofness").
For those more experienced, are there any big hints or things-to-avoid with butyrate? Or is it pretty straight forward?
Thanks again,
KP
kpriddle
kpriddle
Bronze Member
Bronze Member
Post  Ken Cook Fri Jan 02, 2015 7:10 pm
Do I understand this correctly that you already put the spar varnish on? If so, it's a oil base product. You can't place dope over top of it. It will alligator the finish. I'm not saying it can't be done, but it would need to be done in light misting coats. In addition, is this a foam wing. If indeed the dope eats through the finish it will melt the foam. In order to get a decent glossy finish you have to thin it which will more than likely attack the underlying surface. Staying back and misting the coats on will help. But if this is indeed a foam wing I would use a lot of caution. While your choice of dope (Sig) is the best in regards of fuel resistance, most dopes have little fuel proofing qualities and they all eventually fail or begin to wipe off.
Post  kpriddle Fri Jan 02, 2015 7:29 pm
Ken,
Yes, I have already sprayed everything with Rustoleum Navy blue and then Spar Urethane.
The wing has been covered with Doculam just like the other parts, so any reaction with the foam can be factored out.
KP
kpriddle
kpriddle
Bronze Member
Bronze Member
