sealing engines Cox_ba12
sealing engines Pixel
by TD ABUSER Today at 12:30 am
by batjac Yesterday at 8:05 pm
by gkamysz Yesterday at 7:29 pm
by roddie Yesterday at 7:22 pm
by GallopingGhostler Yesterday at 1:04 pm
by 1/2A Nut Yesterday at 12:43 pm
by roddie Yesterday at 11:13 am
by sosam117 Yesterday at 9:32 am
by rdw777 Yesterday at 7:24 am
by rsv1cox Wed Nov 20, 2024 1:21 pm
by 1975 control line guy Wed Nov 20, 2024 6:17 am
by rsv1cox Tue Nov 19, 2024 4:35 pm
sealing engines Empty
sealing engines
sealing engines Empty sealing engines
Post  bullit132 Tue Aug 06, 2013 12:25 pm
what is the recommanded product to seal an engine?also where are all the spots that should be sealed up on an engine, after reading rustys post on mouse racer style engine,i believe air leaks might be one of my problems with some of my engines,any info would be greatly apperciated:cox engine: Small Cox Logo
bullit132
bullit132
sealing engines Empty Re: sealing engines
Post  pkrankow Tue Aug 06, 2013 1:30 pm
Use an aluminum safe product. I use "anaerobic" sealant from Permatex
http://permatex.com/products/product-categories/gasketing/anaerobic-gasket-makers-flange-sealants/permatex-anaerobic-gasket-maker-detail
Most auto parts stores sell it. It is kinda expensive for the little tube, but nothing too crazy. Get the small tube since barely any is used on these engines.
For a tanked engine I fill the groove in the tank, strike the top flat, clean up the inside of the tank with some rubbing alcohol on a paper towel, assemble and clean the outside.
I also seal the venturi by applying to the o-ring. If you get it in the venturi, chunks foul the reed and the engine won't run. (learn from my mistake) at least it cleaned off my reed just fine. A stripped q-tip from the reed side, wet with alcohol, will clean this out...but it is a pain.
I also seal the gasket at the crankcase. Apply a very small amount to both sides of the paper gasket and install.
Post  RknRusty Tue Aug 06, 2013 1:57 pm
Another thing to watch out for is sometimes the screws bottom out before they pull the assembly tightly enough together(the holes are deep enough, but they can be incompletely threaded). This is where a 2-56 bottoming tap is handy. Or you can shorten the screw by a thread or two but some of them barely bite already, so I don't like that option.
Post  bullit132 Tue Aug 06, 2013 2:09 pm
thanks for the info guys off to auto zone for me before they close Small Cox Logo
Last edited by RknRusty on Tue Aug 06, 2013 2:39 pm; edited 1 time in total (Reason for editing : FIXED COX LOGO TAG)
bullit132
bullit132
