Fuel Proofing Water-Transfer Decals ? Cox_ba12
Fuel Proofing Water-Transfer Decals ? Pixel
Fuel Proofing Water-Transfer Decals ? Empty
Fuel Proofing Water-Transfer Decals ? Empty Fuel Proofing Water-Transfer Decals ?
Post  Kim Thu Nov 15, 2012 9:13 am
I think this has been discussed here before, but my search didn't turn up anything. I've got some decals on the way from Brodak's for my Ringmaster and Buster restorations, and was wondering about the best way to fuel-proof them on the planes.
I've still got an ancient bottle of Aerogloss Fuel Proofer, but remember it as never really drying when I used it back in the day. The decal's surface always seemed to stay tacky with this stuff.
Any tips would be appreciated, with brand-names of the products if possible. Sorry if this is a re-hash.
Thanks Kim
Fuel Proofing Water-Transfer Decals ? Empty Re: Fuel Proofing Water-Transfer Decals ?
Post  Cribbs74 Thu Nov 15, 2012 9:23 am
Kim,
I am having the same problem on my Bean. The fuel/castor is starting to affect my decals. The decals said they were fuel proof on the card, but not so much. These were old yellow decals from Goldberg so maybe it's the age. I've read in some of the Brodak instruction sheets that they can be coated in thinned dope. I will dig that info up and post it. The problem is if you have plastic covering than dope will look bad. In your case not a problem.
Post  RknRusty Thu Nov 15, 2012 9:30 am
I have had very good results on water-slide decals using Lustrekote clear gloss spray. I mask off the dried-on decal and make one very light pass with the spray and let it dry. Do that several times until it's fully glossed over and it will never fail. The slightest bit too much spray will craze the decal and cause a bubbly mess, so just be very light handed with it and make sure it's dry between coats. The last coat can be heavier. Shake that can for about 3 minutes before you start.
After it's on and dry, you can do your post flight cleanup with liberal amounts of denatured alcohol with no fear of hurting the decal. Also, mine were on top of Ultracote. I don't know anything about how your covering will react. I did this with my Li'l Jumpin' Bean and the decals were about all that was left intact before the rest of her was demolished. The Li'l Satan decals are done the same way.
Post  Kim Thu Nov 15, 2012 9:59 am
Thanks Rusty !!
I'll give it a try...got plenty of that stuff laying around!
Fuel Proof Kim
Post  John Goddard Thu Nov 15, 2012 2:44 pm
The P40 shark jaws and wing stars on the
Bacaruda are covered in thinned epoxy
Kim. Big (comparatively)old oily peewee
Up front and so far completely impervious.
J
John Goddard
John Goddard
Post  Kim Thu Nov 15, 2012 6:12 pm
Hey John,
What do you use to thin the epoxy?
Post  RknRusty Thu Nov 15, 2012 7:26 pm
Can I answer?
I use denatured alcohol. It works okay, just be sure not to whip bubbles into it when you mix it. It doesn't add to your working time.
I've been thinking of acetone, but haven't tested it on balsa scrap yet.
Post  Kim Fri Nov 16, 2012 12:07 am
Thanks Rusty!
Post  John Goddard Fri Nov 16, 2012 5:18 am
I used Scotch which is what I had 'about the place', I drank what epoxy I didn't use too.
tongue
John Goddard
John Goddard
Post  Cribbs74 Fri Nov 16, 2012 9:20 am
That explains a lot John.......... Laughing
Post  Kim Fri Nov 16, 2012 10:11 am
Sounds as if it might might bind-up a guy a little bit....
Post  RknRusty Fri Nov 16, 2012 10:56 am
John Goddard wrote:I used Scotch which is what I had 'about the place', I drank what epoxy I didn't use too.
tongue
Ah yes, Natured alcohol.
Hope you added some castor oil to that epoxy to prevent binding up bearing down.
