» Betty Skelton by GallopingGhostler Yesterday at 8:20 pm
by GallopingGhostler Yesterday at 6:46 pm
» Jim Walker Bonanza etc.
by Ken Cook Yesterday at 5:03 pm
by rdw777 Yesterday at 2:52 pm
by rsv1cox Yesterday at 10:52 am
by roddie Yesterday at 10:30 am
by roddie Yesterday at 10:02 am
by TD ABUSER Yesterday at 9:25 am
» 1940's?...............
by rsv1cox Yesterday at 7:46 am
by akjgardner Yesterday at 7:19 am
» Lesson learned
by TD ABUSER Fri Sep 06, 2024 6:22 pm
by GallopingGhostler Fri Sep 06, 2024 5:21 pm
August-2024
Help I am having trouble removing the muffler from my .049 Dragon Fly
I removed the cylinder. And I removed the clip from the muffler. Should the muffler slide off of the Cylinder?
Blue Eyes- Bronze Member
Re: Help I am having trouble removing the muffler from my .049 Dragon Fly
Yes, the muffler should freely rotate and slide down off the cylinder. If it's gummed up you will need to soak it in a solvent to soften the hardened oil. If it's not too bad you might could get away with just using a heat gun to warm it up.
RE Help I am having trouble removing the muffler from my .049 Dragon Fly
Than you. I am soaking it i alcohol over night. I will check it tomorrow.
re: soaking in alcohol
Blue Eyes wrote:Than you. I am soaking it i alcohol over night. I will check it tomorrow.
what type of alcohol? isopropyl alcohol is mostly water and can corrode the engine parts. i use old fuel. fuel is only good for so many years then the nitro starts to loose it's potency.
happydad
![RC Plane](/users/3015/29/34/60/smiles/3918962684.gif)
![Futaba Radio](/users/3015/29/34/60/smiles/354952.png)
happydad- Rest In Peace
It was isopropyl alcohol. now it soaking in fuel. How long do you the cylinder and muffler soak.
Do you have a heat source? Perhaps a heat gun or maybe a propane torch?
Hit it with a little heat and slide it off. Soaking will work if you want to wait a while. Heat works in seconds.
re: soaking in fuel
Blue Eyes wrote:It was isopropyl alcohol. now it soaking in fuel. How long do you the cylinder and muffler soak.
I usually soak in fuel for at least over night, then twist and turn the components, muffler, to see if it is loose. if it isn't loose I use an old tooth brush on the areas between muffler and cylinder. NOTE: I ALWAYS use rubber gloves. I paid $5.00 for a box of 500 at Harbour Freight Tools, a local place to buy cheap tools. Note I said cheap, not quality. Some tools are good for many years and some breakdown soon. You get what you pay for.
p.s. I just received a Cox Medallion .049 today and I need to start the same process of cleaning and checking tolerances.
happydad
Thank you. I tried lighting a piece of wood and tried that it did not work, apparently that was not hot enough.
Just try putting the cylinder and muffler into an oven set at around 250. Leave it there for 1/2 and hour or so, remove it with leather gloves and give the muffler a twist. I don't see why it would be too difficult, but some times old caster oil can be stubborn.
Cheers.
Cheers.
No, that was probably only 450 f degrees or so. A heat gun will get up to as much as 1100 degrees f.Blue Eyes wrote:Thank you. I tried lighting a piece of wood and tried that it did not work, apparently that was not hot enough.
I've been chastised for it before but I find an easy way to add heat is to drop the engine in hot water. I heat water in a coffee cup in the micro to boiling, drop in the engine and let it soak for 10
min. Works every time.
crankbndr- Top Poster
Providing there is no plastic, delrin or rubber on the engine. I put them in a pan and boil them. As long as dried afterwards and oiled there should be no problem.
Go to the local thrift shop or Goodwill and buy a $5.00 blow dryer. Heat is the way to go.
jsesere- Rest In Peace
I finally got the muffler off the cylinder. What I did was to use a candle liter three times. I know that open flame is very very dangerous but i was very very very very careful. I used the candle liter away from the fuel.
» Removing QRC muffler
» WTB .049 muffler or muffler parts
» Trouble with a Big Mig
» I'm in trouble...
» Trouble with forum?
» I'm in trouble...
