Removing QRC muffler
Hi,
I want to remove the muffler and run the engine without it. Is it possible to remove the muffler (collector ring ) and how do you do it? Are any special tools or technique required? I cant seem to get the cylinder assembly off with the supplied tool. Is there a trick to it? If I heat it with a heat gun will it distort anything in the assembly? I hope it is not reverse threaded! BTW, the engine was bought used and was lying in storage for more than a decade. Thanks in advance for all the help.
Min
Min
Sakchi- New Member
Re: Removing QRC muffler
Yes, it should run fine without it and you will need to remove the cylinder first. It should then slide off. The threads on the cylinder are normal.
I'll let others chime in on how to clean and remove the cylinder.
It will run fine. It's the same threads as regular, just might be stuck over the years.
By all means use a Cox wrench (or possibly two in combination) to remove the cylinder, Do NOT use pliers or you'll surely damage the cooling fins on the cylinder and possibly distort it as well as the piston.
If you are unfamilar with Cox wrenches check them on the vendor sites here on the forum.
SuperDave- Rest In Peace
That cylinder might not have a milled top to put a Cox wrench on to remove the cylinder and because the muffler is still on it can't be removed using the exhaust ports. Removing the cylinder can be done by heating up the cylinder in front of a blow dryer until it's cookin. You can also boil the engine in water with a few drops of automatic dishwasher detergent added. In either case once the engine is good and hot use a cut down piece of a old leather belt wrapped around the cylinder and grab it with a pair of vise grips and twist off. I have heard of others that use a piece of strap lead to do the same thing.
Joe
Joe
jsesere- Rest In Peace
Yes, as many have mentioned already, it would be advisable to use Cox designed wrenches. We have them for sale here if you do not have any:
http://www.exmodelengines.com/product.php?productid=17631&cat=258&page=1
As Joe, mentioned, if there is not the milled top fin on the cylinder, please use that process to remove the cylinder. If all else fails, we have a rebuild service
http://www.exmodelengines.com/product.php?productid=17825&cat=275&page=1
Regards, Matt
Regards, Matt
Seems to me the process of removing a "frozen" cylinder has been covered here MANY times before. In summary:
-Soak the crancase/cylinder in a solvent like Hoppe's #9 gun solvent for serveral days to let it pentrate throughly.
- Apply a SMALL amount of heat to the crankcase where the cylinder joins in. (personally I use as small butane torch.)
- Use the approriate sized Cox wrenches (in tandem) to work the cylinder back and forth until it loosens. (Using common pilers does considerable amout damge to cooling fins).
- If this fails repeat the process and try again.
The site could use a tricks and tips section.
Monocote heat gun is very helpful with our little Jems. Use common sence and leave prop on. I use old cotton sock to handle engine. I have never melted any plastic on engine ..ever. Use proper Cox wrench that is not all bent. Leather wrap around cylinder also works. Don't take apart cold as you will pay the Piper. Denatured alcohol works better than regulat alky. Crock pot will destoy plastic and anadizing.
dankar04- Platinum Member
jsesere wrote:The site could use a tricks and tips section.
Of course the Cox International "Trouble Shooting "guides are helpful aready. Why they aren't used more often bafles me.
Agree Joe. Gets tiresome repeating same info. over and over.
Could also use a parts vendor thread but my my idea fell flat when I posted it recently.
Oh well...............
Just for fun there is a product called Mother's mag wheel polish that works very well. Makes thos parts shine like a new dime. Detailing made easy. Cuts that old patina down in no time. B/W/G/Bee/Venom/TD .049/.051 uses a 5/40 bolt. Using allen bolt is much better than stock. 5/40X 1" Just some helpful info.
Cheers,Dan
Cheers,Dan
Dan, do you use it to clean/polish Bee tanks and back plates? I use Wrights copper cream for back plates and wet dry P120 metal sandpaper on the tanks after chucking them in a drill.
Welcome in Sakchi, drop a quick few words onto the introduction area of the forum and introduce yourself.
Following the tips provided already and a bit of heat from your heat gun should get the cylinder spinning off again.
Re: Removing QRC cylinder
Thank you all for your help. I have tried removing the cylinder with the Cox tool, but to no avail. I removed the plastic tank, the glow head and heated the cylinder with a Monocote gun but it still didn't budge(possibly because the muffler heats up before the area where the cylinder screws into the crankcase). As I type this, the engine is in an ultrasonic bath. If that doesn't work, then I will try the gun solvent method( will soaking in WD-40 work the same?). I'll keep everyone updated.
Min
Min
Sakchi- New Member
WD-40 might work if you have some available. Otherwise try Hoppe's #9 gun cleaning solvent. Be sure to let them soak the cylinder/crankcase for several days. They are stuck in place with old caster oil residue. Be patient.
Remember WD-40 and gun solvent ARE flammable.
Check the Trouble Shooting Guides @ www.CoxInternational.com to learn about useing Cox wrenches properly. Scroll down the home page to find them.
Re: removing QRC cylinder
The ultrasonic bath did not free up the cylinder but certainly cleaned up the engine! I guess the next thing to try would be soaking it in Hoppe gun solvent (if I can find some here) and the butane "treatment"
SuperDave, I did check the troubleshooting page prior to posting here but couldn't find anything specific to the QRC and hence the question. Thanks again to you, Dan, Joe and Matt for being so patient and helpful.
Min
Min
Sakchi- New Member
Amazon is finally selling Hope's #9 in quarts.
Reasonably priced. Much better deal than the little 5oz bottles.
http://www.amazon.com/Hoppes-No-Solvent-Quart-Bottle/dp/B00109AAN2/ref=sr_1_1?ie=UTF8&qid=1332382737&sr=8-1
dckrsn- Diamond Member
dckrsn wrote:Amazon is finally selling Hope's #9 in quarts.
The local Wal Mart had the quarts on sale right before hunting season for $9. Couldn't pass that up. Usually $12.95 and have seen them as high as $20 for the quart.
dankar04 wrote:Monocote heat gun is very helpful with our little Jems. Use common sence and leave prop on. I use old cotton sock to handle engine. I have never melted any plastic on engine ..ever. Use proper Cox wrench that is not all bent. Leather wrap around cylinder also works. Don't take apart cold as you will pay the Piper. Denatured alcohol works better than regulat alky. Crock pot will destoy plastic and anadizing.
I second this. Once I started using my heat gun I haven't had to soak a single engine. I hear hair driers are effective too.
cribbs74 wrote:dankar04 wrote:Monocote heat gun is very helpful with our little Jems. Use common sence and leave prop on. I use old cotton sock to handle engine. I have never melted any plastic on engine ..ever. Use proper Cox wrench that is not all bent. Leather wrap around cylinder also works. Don't take apart cold as you will pay the Piper. Denatured alcohol works better than regulat alky. Crock pot will destoy plastic and anadizing.
Had one of these handed to me still NIP from a buddy who I helped move. Came with the 5/16 reduction nozzle that snaps on the end. The nozzle makes it very nice to direct the heat where you want it,, .
http://www.craftsman.com/craftsman-professional-27801-1500-watt-corded-heavy-duty-heat-gun/p-00927801000P
Heat almost always gets these gummed up motors loose. Get the thing ouchie hot and they slowly spin free as the goo softens. If there is a muffler in the way, heat the whole thing up hot. Use good judgement of course,,dont heat until the plastic tee dee induction piece is dripping off.
Sakchi wrote:........ the glow head and heated the cylinder with a Monocote gun but it still didn't budge(possibly because the muffler heats up before the area where the cylinder screws into the crankcase). ..............
Although heating the cylinder can be effective, you really want to heat the case where the cylinder screws in --- this will soften the congealed castor oil and help expand the case in the area of the joint.
Sakchi wrote:The ultrasonic bath did not free up the cylinder but certainly cleaned up the engine! I guess the next thing to try would be soaking it in Hoppe gun solvent (if I can find some here) and the butane "treatment"
Min
Sakchi:
The problem of cylinder removal is not unique to the QRC but plauges old Cox engines generally. (Gummed castor oil is the likely culprit holding the cylinder) What works on one is likely to work on them all.
Gun shops are the best source of Hoppe's #9 cleaning sovent or you can find it on-line too.
QRC muffler removal
I have acquired an old QRC 049. How much does the muffler reduce power over a standard Babe Bee? Conversely would removing the muffler bring up the power output? The muffler fitted is the type with a side spout and a rectangular opening to the rear. Thanks.
cggs- New Member
Hi cggs, welcome to the forum.
Removing the muffler from a QRC won't yield much, mainly
because the engine was designed for use with a muffler. It
features a cylinder which has no "sub port induction" If you enter that
phrase into the search feature, there are several threads that debate,
explain and question how it works.
CGGS
FIRST welcome to CEF
too hop up for more power you can mix and match many parts on any Cox engine
Bernie in Canada owns CoxInternational and is a good guy:
https://coxengines.ca/cox-.049-tee-dee-cylinder-and-piston.html
Matt owns ExModelEngins in te USA AND also a good guy
http://www.exmodelengines.com/product.php?productid=17674&cat=267&page=1
» Help I am having trouble removing the muffler from my .049 Dragon Fly
» Removing old sickers
» Removing Ano On Engine Parts
» Removing carbon
» Removing Carb Body from TD 0.049
» Removing carbon
