» Tee Dee .020 combat modelby getback Today at 7:14 am
by getback Today at 7:02 am
Removing carbon
Removing carbon
I have looked, but do not see any posts about removing burnt castor on the external engine. I have a couple engines (non Cox) that have been really hot and the Castor has burnt into a hard Carbon around the head and cylinder. So far I have been soaking in alcohol and scraping (carefully) with a dental pick. This works, but is very tedious and time consuming. Is there a chemical that is engine safe that will dissolve the carbon?
Re: Removing carbon
I've always heard, a old (not for food) crock pot with the old green glycol anti freeze and heat it up. and leave it a day or two. I'm going to try it soon.
duke.johnson- Diamond Member
Re: Removing carbon
Ron, on older and bigger non-Cox engines I use a small brass wire brush.
After a long soak in Hoppe's #9, I brush all the unfinished
cast surfaces. That's just about the whole exterior on an
older engine. Cleans them like new.
Don't know what it might do to a machined surface.
http://www.grainger.com/Grainger/TOUGH-GUY-Wire-Brush-10D449?Pid=search
dckrsn- Diamond Member
Re: Removing carbon
Bob mentioned the Hoppe's #9 Gun Cleaning solvent for such cleaning tasks!
(I have said that so many times that I've grown weary of mentioning it.)
SD
SD
SuperDave- Rest In Peace
Re: Removing carbon
Makes a great dessert topping too.
Re: Removing carbon
Lol, you guys are funny. Hoppes makes a little bit of sense as it cleans carbon off of guns.
I suppose I could break down and buy some. The carbon is localized to the external head and crankcase. The internals look pretty. OS FP.40
Re: Removing carbon
And it could be used as a laxative also. It would FLUSH you right out!
SD
SD
Re: Removing carbon
Carbon and all!SuperDave wrote: And it could be used as a laxative also. It would FLUSH you right out!
SD
Re: Removing carbon
+1duke.johnson wrote:I've always heard, a old (not for food) crock pot with the old green glycol anti freeze and heat it up. and leave it a day or two. I'm going to try it soon.
It can really work wonders, but if you leave it for too long, it will dis-color some aluminum. Clean-up is with a toothbrush and soapy water, but be sure to oil well immediately after cleaning.
» How do I get the brown off my piston top?
» Cox .049 QRC Cessna 182 Skylane
» 3D printed PeeWee .020 tank backplate
» First Flights of my little Carbon Cub, "Problem Child"
» Removing Paint from a Cox car
