Tuning an .049 reed engine with tank Cox_ba12
Tuning an .049 reed engine with tank Pixel
Tuning an .049 reed engine with tank Empty
Tuning an .049 reed engine with tank Empty Tuning an .049 reed engine with tank
Post  Blue Eyes Thu Mar 27, 2014 3:24 pm
How many turns of the needle to get the optimum speed of the engine?
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Tuning an .049 reed engine with tank Empty Re: Tuning an .049 reed engine with tank
Post  Admin Thu Mar 27, 2014 3:33 pm
It varies per engine, the fuel used, atmosphere, elevation... all affects the needle setting. I usually start out at about 3 turns and then fine tune from there.
Post  Blue Eyes Thu Mar 27, 2014 6:27 pm
Is the needle valve turned until it bottoms out and then turn 3 turns from the bottom?
Than you for the information.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  Admin Thu Mar 27, 2014 6:35 pm
Yeah, you turn it down to close it and then open it up about 3 turns.
Post  Cribbs74 Thu Mar 27, 2014 7:17 pm
If possible, please post a picture of what engine you are trying to run. If you know what it is (ie: black widow,babe bee etc.) then let is know and we can point you to a instruction manual for that particular engine.
Tuning an .049 reed engine with tank Empty RE Tuning an .049 reed engine with tank
Post  Blue Eyes Fri Mar 28, 2014 10:22 pm
Here is the pic of the engine.
Tuning an .049 reed engine with tank 03281415
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  Cribbs74 Fri Mar 28, 2014 10:47 pm
Ok, that's a Babe Bee.
You can find the instruction sheet for it here:
https://www.coxengineforum.com/h24-instruction-sheets
Please don't try and run it on that tin lid. Use a proper hardwood mount or a dedicated steel mount.
How long has it been since that engine has been run?
Post  Blue Eyes Fri Mar 28, 2014 11:02 pm
it has been more 10 years.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  RknRusty Fri Mar 28, 2014 11:16 pm
Make sure the breather hole has good air. A piece of plywood would be better, they don't run well if allowed to vibrate. It might foam the fuel on that tin plate. let us know how it goes.
Post  Blue Eyes Fri Mar 28, 2014 11:23 pm
Would Arctic Fuel be okay to run in the engine?
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  Cribbs74 Fri Mar 28, 2014 11:29 pm
Yes,
As long as it has 15 percent or better nitro and at least 20 percent oil with half of that being castor. More castor content the better.
Arctic fuel makes many different blends, but some are geared around 1/2A engines.
Post  Blue Eyes Fri Mar 28, 2014 11:35 pm
Thank you i Will have to order some fuel before i start the engine. I will let you know how it goes.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  RknRusty Sat Mar 29, 2014 1:50 am
Sig Champion 25 is the go-to fuel for my 1/2A engines. It's 25% nitromethane/20% oil, and the oil is a 50/50 blend of Castor and synthetic. good stuff:
http://www.sigmfg.com/cgi-bin/dpsmart.exe/MainMenuFV5.html?E+Sig
Find That page by navigating from the main frame page by clicking on:
"Field equipment>fuel>airplane fuel", then click top left picture of Sig Champion and pick the one you want.
Post  SuperDave Sat Mar 29, 2014 12:45 pm
As a side note, to achieve peak performance it's also important that the engine be CEAN both inside and out.  This is particularly important ifthe engine has sat unused for any length of time.
All gaskets need to be inspected and replaced if necessary.  Things like the pick-up tube snd spring (in the fuel tank) are often clogged with castor gum as is the needle valve seat.
New parts are available from Cox International or EX Model Engines.  (which see)
SD
SuperDave
SuperDave
Post  Blue Eyes Sun Mar 30, 2014 2:16 pm
I ordered the Sig 25 Champion today in the quart bottle. I also ordered an .049 tune up kit and also a tank back plate. I found a piece wood that i can use to mount the engine on.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  Blue Eyes Fri Apr 04, 2014 6:12 pm
The SIG Champion 25 arrived today now i am waiting for parts from Cox International. Then i will start the engine. RC Plane
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  getback Fri Apr 04, 2014 8:29 pm
Cool like SD replied make sure ur engine is clean before u even start gaskets, orings make a big difference I found out the hard way getting started back again , well still am learning Getback Babe Bee .049
Post  Blue Eyes Sat Apr 05, 2014 1:05 am
Every thing is cleaned. To clean the engine i used rubbing alcohol.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  getback Sun Apr 06, 2014 10:03 am
Get that Baby fired up there Blue Eyes ? last we heard u got some nitro.  Small Cox Logo Very Happy  Getback
Post  roddie Sun Apr 06, 2014 12:45 pm
Blue eyes, another important factor in getting that engine to run well, is making sure that the reed is sealing correctly. You may have gotten a new reed with your tune-up kit. There are different kinds of reeds.. but they all work the same way, and they will all fit your engine. The reed must seat correctly.. and the seat must be clean. I like to use a Q-tip cotton swab dipped in solvent to clean the seat of any gummed-up fuel residue that may be there. You must be careful not to scratch the seat. An old reed itself can be cleaned in the same way.. just be sure not to bend/crease it. When you install the reed with the circlip that holds it in place, do a simple test. Gently blow and suck against the reed. You should feel the resistance of the reed sealing when you "blow".. and feel it opening when you "suck". If you can feel air passing through the reed while blowing.. you need to re-check the seat to be sure it's clean, and you can also try flipping the reed over and re-installing it again with the clip, until you achieve this action. This is how the engine operates. It "sucks" the reed away from it's seat when the piston moves upward in the cylinder, which pulls in the fuel and air mixture.. and "blows" (pressurizes) the crankcase when the piston moves back down, causing the reed to seat against the venturi. This is why it's very important for the engine to be assembled carefully.
Tighten the four screws that hold the back-plate on "alternately" and "evenly" using a crisscross pattern once they start to become snug.
Although not necessary; an extra step that's well worth doing, is to take your crankcase and smooth the area where the gasket goes. You will need a piece of perfectly flat window glass and very fine (600 grit) sandpaper. Place the piece of glass on a nice flat table, lay the sandpaper (abrasive side "up") on the glass, place the crankcase's flat gasket surface on the paper and lightly move it in a circular motion a few times.. not too much is needed to make it smooth. Clean it with solvent afterward. When you reassemble the engine, you will know that the gasket has a nice smooth surface to seal against. SEALING and CLEANLINESS is KEY with getting these engines to run correctly from the start.
With your new back-plate, be sure to attach and locate your fuel pick-up tube correctly when you assemble the tank on the engine. Some people (including myself) prefer not to use the tiny spring in the pick-up line. Just make sure that #1.. the fuel line attaches firmly to the nipple on the back-plate.. #2..  that the line doesn't kink.. and #3.. that it extends to the left hand (outside) corner of the tank (for conventional "counter-clockwise" flight direction) when you reassemble it.
photo-courtesy of Paul Gibeault
Tuning an .049 reed engine with tank 12-10-11
Post  Blue Eyes Tue Apr 08, 2014 8:20 pm
Today i got the engine running. It was a very loud scream.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  Cribbs74 Tue Apr 08, 2014 9:02 pm
Good job!
Maybe ear plugs are next on your list!
Post  RknRusty Tue Apr 08, 2014 9:27 pm
Blue Eyes wrote:Today i got the engine running. It was a very loud scream.
Good work. Smoke and castor slime are good for the soul.
Post  Blue Eyes Wed Apr 09, 2014 2:40 am
The tune up kit came with a read valve.
Blue Eyes
Blue Eyes
Bronze Member
Bronze Member
Post  RknRusty Wed Apr 09, 2014 3:59 am
Blue Eyes wrote:The tune up kit came with a read valve.
Oh yeah, the heart of the system.
