» Kofuku Maru Fishing Boat Modelby rsv1cox Today at 9:47 am
by TD ABUSER Today at 12:50 am
by 1975 control line guy Yesterday at 10:35 pm
by 706jim Yesterday at 9:32 pm
by TD ABUSER Yesterday at 2:58 pm
» Pathé Modeling Videos
by rdw777 Yesterday at 10:28 am
by roddie Tue Nov 12, 2024 3:27 pm
needle valve
needle valve
I have an os max 10 set up for rc but I want it for cl need a needle/carb for it mine is broken. also enya mod 3303 15-III need cl needle set only thing left is carb. threaded tube please pm me if you can help Thanks !!
Re: needle valve
Is this the OS MAX-S .10? I can tell you from years of experience using the Enya 3303 that it will work, but it will suffer some problems. The Enya 3304 had a slightly larger head, it also has no web casting obstructing the exhaust. The 3303 tends to overheat badly. The stock muffler is the worst thing to use on this engine as it will overheat the engine to the point it will be smoking when it lands regardless of how rich you set it off. The 3303 thermically advances and it doesn't want to return. Mainly due to the extremely thick cylinder liner. The 3303 came with two venturi sizes and the larger works far better. This engine likes to wind up and most try and use a 8x4. It doesn't tolerate large props well and the Master Airscrew 7x6's and 7x4's work far superior. These would be the narrow bladed versions and not the wider ones. Everything you buy now will be the newer and thinner GF series Master Airscrews which are the correct size. However, the Enya has a metric hole so using the proper reamer is a must. Many times I can use the standard Fox reamer and come through the rear but I don't break through all the way which works well.
Shtterman on Ebay has Buy It Now auctions and has the parts you seek. Here's a link http://www.ebay.com/itm/ENYA-15-19-McCOY-19-40-NV-ASSY-C-L-NIP-PART-15220-/221303078611?pt=US_Radio_Control_Control_Line&hash=item3386b0fed3 to his needle valve for the .15. E-mail him as he will respond quickly and just because you don't see it, don't hesitate to ask. Ken
os max 10 [ken]
thanks for the info on the 15 iii enya here is the os 10 don't see an S I AM GOING TO GET THE needle set up for the 15 but have plans for the 10 thanks again!!
Re: needle valve
What it looks to me is that you have the FSR .10. That's a pretty hot little .10. It was the model prior to the FP. Most of the FSR's that were larger were ball bearing. I believe that may just be a plain bearing. Nonetheless, a good engine. Here is the problem, the FSR and the FP .10 shared the same control line needle valve. These were an excellent needle. They're just non existent. No one has them and those that do aren't giving them up. I can provide you a picture of one as my .10 has one. They're that highly desired . My recommendation would be to seek the OS FP -LA .15 needle. If you know a machinist, you can turn the spray bar down slightly in the venturi area. This can crudely be done carefully in a drill press using a file and sandpaper to really smooth it up. The OS spraybar has plating on it and your going to break through it. You could also try and use it as it which may require the case hole to be slightly opened up in order for it to fit. As for venturi, I can't comment. It may just be the same as the FP engines. If you have the stock r/c carb, you could contact Jim Lee
http://www.leemachineshop.com/ who makes venturi's for ALL engines and he may already know the size your seeking. Ken
Re: needle valve
i have several O.S. 10's an a few spares let me know if i can help
ekitten2- Gold Member
Re: needle valve
i just got PM from some one else needing a venturi an NVA set for O.S 10...so what do i do sell it to them or do you want em?
» .049 Cox-Killer Bee-Valve ?
» Cox .15 Drum Valve on the Bay
» Question about the RR-1 Valve
» TD needle valve
» Did I get the right needle valve?
» TD needle valve
