» My N-1R build logby roddie Today at 12:17 pm
by bsadonkill Today at 11:31 am
by MauricioB Today at 10:49 am
» Octura engines?
by UncleLumpy Today at 8:16 am
» Tatone EM-7
by sosam117 Today at 7:50 am
» Honoring All Who Served
by rsv1cox Yesterday at 3:30 pm
by TD ABUSER Yesterday at 1:41 pm
by balogh Yesterday at 1:36 pm
» K&B .09 Torpedo Engine
by LooseSpinner99 Yesterday at 12:01 pm
» 3D printing of parts?
by UncleLumpy Yesterday at 9:08 am
» L4 Grasshopper
by bottomgun Yesterday at 7:58 am
AMF Wen-Mac parts or help
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Hi new to the group, I have a 1960 vintage Wen Mac MK XIII 0.049 engine that I am trying to get into running condition. I need help on the head/glow plug. I cannot find a replacement, measures at 14.150 mm 0.75 mm pitch or in imperial 0.555 inch at 36tpi OD, thread depth is 4 threads, also no head gasket. I think the original design of the plug was the gasket was integral to the plug as there is a fine aluminum ring on the base of the plug cut in that is only 0.010" thick, this is cracked. Hence the original is shot, the body is badly damaged so I'm not able to modify it for a 1/4 replacement type plug. I can make a new head but no way to cut the threads, my lathe does not have threading capability, (old Unimat). I have an old TD type plug but the thread diameter is too small, 1/2".
Any Ideas on a tap and die set for this fine of pitch, location of a plug, or replacement head?
The top of the glow plug has flats instead of spanner notches.
pat
pat
goody- Moderate Poster
Re: AMF Wen-Mac parts or help
I'm not aware of any Wen-Mac parts sources though someone here may be. (Long ago I bought a three-pound coffee can full of assorted .049 parts (INCLUDING We-Mac) at a swap meet.
In your instance I believe a replacement a better avenue than repair of your part. (Once stripped thread repair in aluminum is a chance proposition)
Wen-macs turn up on the 'Bay too. You may find a "parts engine" reasonably priced that has exactly what you need.
Keep looking and you shall find! Good luck!
SD
SD
SuperDave- Rest In Peace
Yo Pat!
I got several "orphaned" Wen Mac carcasses !!! If no one else jumps in, I'll check back in tonight after work and we'll get SOMETHING matched up !!!
Wen Mac Kim
And...in spite of the brand of THIS particular thread...Welcome to the World-Famous Cox Engine Forum !!!!
Wen Mac Kim
There ya' go Pat!
CECF to the rescue.
SD
CECF to the rescue.
SD
It came off a COX model, an SNJ3 Navy trainer, first plane I bought at 12, only flew it once or twice the rest of the time was waiting for parts, it didn't hold up to cow pasture much.goody wrote:Hi new to the group, I have a 1960 vintage Wen Mac MK XIII 0.049 engine that I am trying to get into running condition. I need help on the head/glow plug. I cannot find a replacement, measures at 14.150 mm 0.75 mm pitch or in imperial 0.555 inch at 36tpi OD, thread depth is 4 threads, also no head gasket. I think the original design of the plug was the gasket was integral to the plug as there is a fine aluminum ring on the base of the plug cut in that is only 0.010" thick, this is cracked. Hence the original is shot, the body is badly damaged so I'm not able to modify it for a 1/4 replacement type plug. I can make a new head but no way to cut the threads, my lathe does not have threading capability, (old Unimat). I have an old TD type plug but the thread diameter is too small, 1/2".
pat
It lived for a while on a Wizard I built, then gave it to my Nephew. Then I flew it on a 1/2 A combat zero.
Hey has anyone ever seen a 1.5 I^3 cox gasoline two stroke, we had it on a small chain saw.
pat
If it's the yellow Cox Chainsaw, one or two of our members has one.
Cox chain saw.
Yep that would be the beast, not sure which of my brothers has it but was nearly useless for cutting anything but brush and that only marginal at best, it did rev nicely though.RknRusty wrote:If it's the yellow Cox Chainsaw, one or two of our members has one.
pat
Hey Pat,
The closest thing I could find at the moment is this MK-II core. Did you say there are flats on the your cylinder head's top? That sounds like the head of a later model than the MK-III. I'm still looking...should find some more parts here shortly.
Ah Crap...sorry...I mis-read the Mk #...durn rednecks! Back in a bit!
Any short glowplug will work or add two extra gaskets, three total and use a long 'reach' plug
http://f1.grp.yahoofs.com/v1/7H1wUuTzFf7njKn3pIgidSZ9aXqNmPKpu1CiZzKWXLIPb4tigQG-qExHl6rgj6G2XToKcsT6BVHy3nyBEXio/Wen-Mac.pps
What does a MKIII look like? I several testors/wen mac engines that I have no use for. $20 including shipping and they are yours.
OK...reboot time: I got this MK-XIII. It's got no gasket though.
Both glowheads "attempt" to glow. I can clean and test them tomorrow.
Sorry Ron...I was typing during your post...
opps! lol, i saw the XII and knew it was the later version, but my o'l brain was telling me (as i saw Kim pic) that it was a early version!
About all you can do is look on ebay or hopefully someone here has one, you could always drill it out and tap for a short glow plug.
Its funny that several 1/2 manufactures used common dimensions with Cox engines, but the threads on theses are not.
My fault for continuing my "mis-cue" Mark !! I just skimmed Pat's note yesterday at work, and the term "1960" locked into my brain. Got home late (for me) last night, and was still looking for the type of that year or close to it.
Anyway Pat, let me know on this MK-III. I think it's starter spring is good, though it's castor-stuck at the moment. It's also missing it's n.v. and prop nut, but maybe your originals will still work? I'll send the thing to you for postage if you think it'd be worth messing with.
yep, maybe that's what my brain was 'seeing' along with photo, lol!
Didn't somebody at sometime make a glowhead adapter for that engine?
Think so...but also thought Pat was going for as original as possible. We'll see when he checks in...
In all the years I have been looking I have never seen a Wen-Mac plug for sale on its own. You can find parts engines for less than $10 and just pull parts off you need.
Kim the Mk XIII picture you posted is the right one. The head in the far right is the one I have left. I use to buy my heads from Testors I think, don't really remember. I at one time had several heads, and a cylinder but they have been lost in 50 years. According to the 0.049 users group the Mk XII and XIII are interchangeable, mfg dates 1964-1966. The difference in the motors is Testors on the Mk XII. Heads and a needle valve or two would be good, or if you want to get rid of it I can take the whole motor. I would like to be able take a burned out plug and adapt it to use a standard short 1/4 in. plug. I have both pieces of my needle valve and can possibly silver braze it back together. I can also turn a new one from 3/16" bar but the compound taper may be a problem, very crude machinist skills, and a Unimat micro lathe.Kim wrote:Think so...but also thought Pat was going for as original as possible. We'll see when he checks in...
pat
Yes I would be interested, just for parts if nothing else. I want to try and get this running to put it on a foamy, will have to figure out how to do the muffler throttle that was the 1966 engine option. Also looking for a manual.Cribbs74 wrote:What does a MKIII look like? I several testors/wen mac engines that I have no use for. $20 including shipping and they are yours.
pat
WOW, this group is totally fantastic. This was the plane I had, but mine was Cox not Testors, according what I read the Thunderbolt engine was 1966, mine was from 1964, and this one had the throttle. Testors bought Wen-Mac in 1964/5 time frame. More detail on the engine would be nice to be able to figure out how to make a throttle so I can fly it RC.Mark Boesen wrote:
pat
Hey Pat,goody wrote:Kim the Mk XIII picture you posted is the right one. The head in the far right is the one I have left. I use to buy my heads from Testors I think, don't really remember. I at one time had several heads, and a cylinder but they have been lost in 50 years. According to the 0.049 users group the Mk XII and XIII are interchangeable, mfg dates 1964-1966. The difference in the motors is Testors on the Mk XII. Heads and a needle valve or two would be good, or if you want to get rid of it I can take the whole motor. I would like to be able take a burned out plug and adapt it to use a standard short 1/4 in. plug. I have both pieces of my needle valve and can possibly silver braze it back together. I can also turn a new one from 3/16" bar but the compound taper may be a problem, very crude machinist skills, and a Unimat micro lathe.Kim wrote:Think so...but also thought Pat was going for as original as possible. We'll see when he checks in...
pat
Yeah the poor Wen Mac needles AWAYS took it on the chin, and they're the one item I have to swap around to run my engines. There are probably some in Ron's batch, so you should be in business. If you think you have a use for this engine, I got it turning easy with good compression, and the spring starter IS good! (Miracles!)
Anyway. let me know and I'll shoot it to you on the cheap !
Waking Kim
Pat, its a Testors, not Cox. There were several companies manufacturing plastic 'ready to fly' control line gas powered airplanes in the 60's: Comet, Aurora, Gilbert, Wen-Mac & Cox.
To use with a throttle, you'd need the throttle assembly and then basically connect that to a servo.
I saw a picture of the throttle assembly on a parts list, the throttle is a muffler/throttle assembly the cylinder has to be modified or a throttle cylinder needs to be made or found the fins above and below the exhaust port are missing. I think someone was offering up both styles of engines on ebay, but sans throttle. I'm sure I can figure it out. According to the 0.049 users group the Testors label wasn't until 1966, I know I got mine in 1964 I remember it came with a can of COX fuel, was almost certain it was a Cox oh well guess it was a Wen-Mac then, at least that is what the motor has on it. They also had the glow plug thread specs., .5575 40tpi, I measured .555 36tpi, my guess is 14.150 X 0.75 is most likely the correct thread, since it is a standard extra fine thread.Mark Boesen wrote:Pat, its a Testors, not Cox. There were several companies manufacturing plastic 'ready to fly' control line gas powered airplanes in the 60's: Comet, Aurora, Gilbert, Wen-Mac & Cox.
Finding out a lot of information.
Thanks Pat
» for sell, 3 parts baby bees. and other cox parts
» Well, you can buy some Fox parts again...
» WTT TD .049 parts for Medallion .049 parts
» Cox collectors new in OEM wrap. Helis FF. Rescue/ Cobra. Traded <><
» parts is parts
» parts is parts
Page 1 of 3
