» Purchased the last of any bult engines from Ken Enyaby sosam117 Today at 11:32 am
by rsv1cox Today at 10:20 am
by rsv1cox Today at 10:07 am
Best rechargeable(or not) glow igniter?
I'm tired of dragging that old battery pack around. That was very inconvenient at the contest.
What's your favorite rechargeable glow starter? NiCad or NiMH? I want one of the short stem ones that will dependably light a plug. But I'm not sure whether the twist and turn or the spring clip ones are the best and most durable and make the best electrical connection. And I bet the twist and turn type won't fit a Norvel/Merlin clamp and drop-in plug. Maybe I need one of each.
I'm tired of dragging that rickety old battery pack with the clothes-pin clip around. That was very inconvenient at the contest.
Thanks,
Thanks,
Re: Best rechargeable(or not) glow igniter?
I've got both, with the aluminum bodies that let you unscrew the cap and replace the battery at the end of it's life. I needed the long-stem one to reach the deeply recessed glow plug in one of my O.S. 4-Stroke Engines. It's kinda "floppy" though, when used on anything other than a vertical engine. The short-stem works fine with horizontal installations.
They won't fit my Cox and Wen Mac engines, and since I had an extra wall-charger between the two, I cut the cord off one and soldered a Cox clip opposite to the adapter end.
Another accessory that gets used A LOT is the little Hobbico Micro Power Panel that has a quick-charger installed for these drivers. It has a glow plug-like head that lets you hook up the driver just like you're putting it on a glow plug. There's no time or charge limiter, just a green LED, so you got to watch it, but it seems to bring mine up to speed just fine.
Of course, they both work off a single "Sub-C" cell, so your COULD just make one up with your clip installed, and rig a way to charge it.
Something to keep in mind, nicad glo starters are very convenient. One major problem with them is safety. Some versions have a strong spring and will pop off like a mouse trap. I've had them go into the prop where I almost lost my teeth do to this. Typically when this happens, the battery departs one way and the metal tip goes the other. A twist lock style would be highly recommended opposed to the spring style. The other thing I've found is that some pilots forget to remove this from the cylinder head and then go flying with it on. I've had 1/4 Oz tip weights come off of planes and hit me so I can't imagine what a igniter would feel like.
The other factor when deciding if a nicad glo battery is a good solution is that they're only 1.2 volts. Depending on what type of plugs your using, they may not adequately light them off properly. As the temps drop and the engines therefore require more prime for starting the rechargeable nicads may not be up to par like drycells would be.
From an economical standpoint I've seen D cells soldered with a piece of heater cord about 6 feet long do probably a better job than any power panels or nicads. I've seen 4-6 cells ganged together and last up to 2 years. Ken
Excellent points Ken !!!
Another possible alternative is a "Baby Field Box" like the one in my photo. With a light 12 volt battery to power it, a guy can use a clip with an extended wire, AND have a few tools handy for loose heads or screws.
It also gives the glow driver a "home" once the engine's going...I NEVER put a glow driver in my pocket...Rednecks are in enough danger around amps and flammable liquids WITHOUT putting other recreation devices at risk !!!
Good points, thanks. And I did have the redneck pocket storage method in mind too. Just trying to streamline my cranking routine next time I am at a contest. I'd hate to be trying to fly shapely stunts with my pants on fire.
Though, from the pursuit of posterity standpoint, you WOULD remain in everyone's memories...probably forever...RknRusty wrote:Good points, thanks. And I did have the redneck pocket storage method in mind too. Just trying to streamline my cranking routine next time I am at a contest. I'd hate to be trying to fly shapely stunts with my pants on fire.
Haha, a dubious honor.
Possibly...but you know, few people on the street remember the fate of the USS Los Angles, but EVERYBODY remembers the Hindenburg !!!RknRusty wrote:Haha, a dubious honor.
Now remember when you see the price Rusty, you did ask for the best glow driver. This is what a lot of the guys around here run. They say they only charge them once a year. Here's the link.
http://rcatsystems.com/rc.php
They are about $120 plus $10 for the rubber case.
duke.johnson- Diamond Member
I can tell you one not to use. The one made by Hangar 9
I bought one a week ago and used it this past weekend. It's a twist lock style. I used it twice and when I pulled it off during the last use the stem stayed with the engine and the battery assembly was in my hand.
Piece of junk! $16
Those red Dubro ones work well. My LHS didn't have any so I bought a dud instead.
Piece of junk! $16
http://en.wikipedia.org/wiki/USS_Los_Angeles_%28ZR-3%29Kim wrote:Possibly...but you know, few people on the street remember the fate of the USS Los Angles, but EVERYBODY remembers the Hindenburg !!!RknRusty wrote:Haha, a dubious honor.
Getting decommissioned after years of good service is not very memorable.
Perhaps I was too harsh, I looked at it closely and all it was is the set screw came loose
So, with that said it works ok when you tighten the set screw. It also has a little amp meter built into it. It's probably not real accurate, but it will tell you if something is amiss with the glow plug.
For Cox engines I still hold with the Cox two D cell battery pack (in paralell) with clip designed for Cox engines.
I also have a "Hot Shot" rechargeable but it doesn't fit a Cox nearly as well. (You need three hands to use them)
SD
SD
SuperDave- Rest In Peace
Thanks for all the replies. That's what I wanted, a bunch of ideas and opinions all in one place so I can compare and think about it.
For solo field flying and fooling around, I think I'll build a nice twin D box with soldered spring loaded copper contacts and a spring clamp on a wire. For times when I'm either taking turns with others or in the occasional contest where I need to keep clutter contained, I will decide between a stem type with a manual spring release or push and twist. And also whether to get a re-chargeable or replaceable battery. Wayne told me he had accidentally unscrewed a glow plug with a push and twist stem type. But I've seen him tighten a plug, and I definitely horse it in a little tighter than he does.
I bought this today on e-bay.
http://www.ebay.com/itm/271311211253?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
$5 bucks and I was the only bidder.
I can put an alkaline or a rechargeable D cell in it.
The problem with NiCad and NiMh is that the battery has to be absolute fully charge in order to deliver anything near 1.5V. With extension wire and glow clip for cox you will also loose some power in the wires.
The best glowdriver I have owned so far is the LiPo one from Dynamite RC
It will give you the right voltage independent on battery charge status and it is just as small as the short stem NiCad/NiMh ones. For cox engines with stock head you still need the wires, while with the Norvels and insert style the glow driver sort of works as it is. But it can easily come off when there is no regular glow plug so be a bit careful.
Hi Kris, I never trusted rechargeable batteries for any high current applications. I'd definitely consider a glow plug high current. I'll use alkalines in it, and always keep spares in my box. And for my 1/2A engines I still have the dependable old Cox box with thick wires on it.
Depends how you wanna go about it.
If you don't mind adding 5/6 grams to the aircraft I added one of these to
most of my (sadly dwindling) glow aircraft in the last couple years.
http://www.ebay.co.uk/itm/RC-ONBOARD-GLOW-PLUG-DRIVER-IGNITER-NEW-FROM-UK-SELLER-/380685607609?pt=UK_ToysGames_RadioControlled_JN&hash=item58a2a162b9
It's on the glow all the time so no faffing around with clips etc, you just
need to fashion a socket/plug for the battery.
I used a 4000mah 2 cell lipo which I think I charged twice last year.
I also have one with a small 700 mah 4 cell nimh that's fitted in the aircraft
once started (usually first flip) it stays running until the fuel runs out or I
stop it. If fact thinking about it that engine (which was never very reliable) hasn't
missed a beat since I fitted it no matter how over rich or what different fuel I've chucked
in it.
in it.
John Goddard- Diamond Member
Rusty:
So tell us about what's so great about a rechargeable unit? Did I miss something?
Are you selling them?
SD
SD
I think Rusty is looking for an igniter unit and use alkaline batteries in it.
Dave, I'm not sure what you're talking about. I'm sure not talking them up or selling them. See the following quote from above:SuperDave wrote:Rusty:
SD
I was going to get a replaceable alkaline type, but Wayne called me from a hobby shop on his way home from Huntersville Saturday evening and told me he picked up a rechargeable one for me. He says the sub C battery is good for a couple of years. So I guess I have a rechargeable one after all.RknRusty wrote:...I never trusted rechargeable batteries for any high current applications....
It's what I am using and it seems to make em' glow even in 20 degree temps.
I have had it for a couple months and only charged it twice.
Ron:
Presumably Rusty has a charger for those rechargable alkalines then.
This whole matter isn't my worry. I just wanted to read Rusty's reasoning.
SD
SD
One of there?
http://www.ebay.com/itm/DYNAMITE-DYN1950-D-ALKALINE-GLOW-DRIVER-TLR-TEAM-LOSI-ASSOCIATED-DURANGO-/131056410720?pt=Radio_Control_Parts_Accessories&hash=item1e83922060
There are also adapters to use rechargeable batteries if you want.
I haven't seen it yet, Wayne still has it. I don't know what kind of battery it has. My original intent was to get a Non rechargeable Alky, one where you toss the battery for a new one when it dies. But now apparently he got me some sort of rechargeable doohicky, a Dyna-Glow brand. I'll let you know when I get it. Tuesday looks like a good day for us to go fly, so maybe I'll have it then.SuperDave wrote:Ron:
SD
» Glow plug igniter.
» What do you use as a Glow Plug Igniter?
» Glow Head Igniter Trouble
