» 010 head stops glowingby Cox International Today at 11:00 am
» Modelsmodels
by Coxfledgling Today at 4:08 am
by Cox International Yesterday at 10:35 pm
» Unique Foxie partzie. Potential fishing line/paper weight or something else.
by rsv1cox Yesterday at 2:48 pm
by rsv1cox Yesterday at 2:42 pm
» Ignition Points for Ohlsson 23
by Ken Cook Yesterday at 1:58 pm
» Cox P-40 Clone Project - I just can’t leave well enough alone.
by akjgardner Yesterday at 10:32 am
» COX .020 RC PROJECT
by TD ABUSER Yesterday at 9:29 am
by roddie Tue Sep 17, 2024 6:51 pm
» some pics....
by roddie Tue Sep 17, 2024 6:21 pm
by GallopingGhostler Tue Sep 17, 2024 9:22 am
by sosam117 Tue Sep 17, 2024 8:58 am
Cleaning brushes
Cleaning brushes
Other than the $7.19 aerogloss thinner, what is the best way to clean dope from brushes?
Thank you
Thank you
JPvelo- Diamond Member
Re: Cleaning brushes
When I paint or epoxy with brushes I clean them with acetone. If the brush is decent quality it doesn't seem to damage the bristles. I've never brushed on dope before.
I use acetone for dope, with good or cheap brushes.
duke.johnson- Diamond Member
I use lacquer thinner from Lowes or Walmart for cleaning. I've also used it for thinning clear dope, but have found that it can cause clumping in some colored dopes. I would expect a higher quality thinner or reducer from an automotive paint supplier might work for thinning and spraying.
Acetone is the standard thinner and clean-up fluid for dope. It's also cheaper than most thinners.
I had no idea acetone cleans epoxy from brushed, awesome bit of info. Thanks for all the input.
Acetone is usually about the same price as cheep lacquer thinner, its also great for thinning epoxy for glassing wings, etc.
I think 'back in the day' you could make glue with acetone and celluloid.
Yep -- a fairly common practice. But, the acetone was so volatile that it had to be used quickly.
» Why are wire brushes bad?
» devarnishing brushes
» Cox .049 / .051 Cylinder devarnishing brushes now available
» Cleaning tiny parts/orifices
» Bore cleaning .049's
