home made battery box Cox_ba12
home made battery box Pixel
by Ken Cook Today at 5:09 am
by TD ABUSER Today at 2:30 am
home made battery box Empty
home made battery box Empty home made battery box
Post  bullit132 Sat May 04, 2013 10:02 am
anyone got any ideas on how i could make a cheap battery box for two d cells? a photo would be great if someone out there has any input, Beer Cheers
bullit132
bullit132
home made battery box Empty Re: home made battery box
Post  dirk gently Sat May 04, 2013 12:11 pm
I used to just tape two batteries together with electrical tape, and tape the lead-outs to the batteries as well. The lead out's were terminated with alligator clips.
It worked fine, but the clips were not very convenient, so eventually I just bought a dedicated box online, although admittedly, the price is not exactly a bargain.
dirk gently
dirk gently
Post  RknRusty Sat May 04, 2013 12:21 pm
You can buy a cheap twin D cell holder at Radio Shack(or rip one out of an old talking teddy bear), yank the wires off and rewire it in parallel with thicker wires that lead to your clip. Good quality copper conductor that supports several amps is a MUST. Speaker wire or lamp cord. It's best if your holder has copper leaf springs instead of the chrome steel coil springs, but either will work. Solder all connections.
I bought a Thunder Tiger Kwik Klip which is a piece of junk because the plastic rots. But I removed the electrodes and screwed them to a wooden clothespin and it works great on all engines. The wires are good. They are easily available, usually at the LHS. It has an inline switch too. Don't leave it connected for any length of time in the Test(Off) position because a trickle current still flows.
home made battery box Kwik-klip-300
After trying many brands, including Energizer, I also recommend Rayovac D cells. They keep working much longer for me. I buy 8-packs that come in a convenient plastic box and keep a pair of spares in my flight box.
Last edited by RknRusty on Sat May 04, 2013 5:56 pm; edited 2 times in total (Reason for editing : Clarified an unclear statement)
Post  bullit132 Sat May 04, 2013 1:23 pm
thanks again rusty Jeep
bullit132
bullit132
Post  Kim Sat May 04, 2013 5:38 pm
I made a pack for my friend Patrick, using four Duracell "D" batteries and the plastic blister pack they came in. He's been using it since Spring last year. I soldered a wire around the batteries' ends and wrapped the whole thing with strapping tape.
The plastic box keeps out dirt and prevents shorting while it rocks around inside Patrick's metal toolbox. I think the extra two cells also help clear and fire the occasional overzealous priming his engines receive !
home made battery box 2_14
Post  pkrankow Sun May 05, 2013 1:31 pm
I use 3 single D-cell holders from radio shack, in parallel, fastened to a board, with binding posts. The 3rd battery really helps for winter flying.
I also find the 3 batteries last significantly longer over using 2. I am sure 4 would perform even better, but I am not remaking my setup.
Post  dckrsn Sun May 05, 2013 6:45 pm
I'm thinking of cutting open a 6volt lantern battery
and using a pair of the cells in parallel. 3 might be a bit
much. Open for comment.
Post  andrew Sun May 05, 2013 6:49 pm
I run two D-cells in parallel. They get replaced each spring, whether they need it or not.
Post  Cox International Mon May 06, 2013 11:06 am
What is cheap?
These are only $8.95 and wired correctly:
http://coxengines.ca/cox-starter-battery-box-no-clip.html
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Cribbs74 Mon May 06, 2013 11:10 am
I agree, the cost of materials and time to make one makes $8.95 seem pretty cheap to me.
Post  kevbo Mon May 06, 2013 12:00 pm
When I was a kid, No.6 cells were very expensive, and the cox starting batteries tended not to last, probably due to being past their sell-by date by the time I bought them. I used to wait for radioshack to have a sale on D-cells. I'd get 8 of them, bundle them like cord wood, and solder a wire around the ends. I'd put a little block of wood between two of the end cells with two brass screws in it for connections. Then I'd make cardboard end covers, and wrap the whole mess up with masking tape. (cause it was the cheaper than electrical tape). One of these would last me about a year or two IIRC. A couple of tricks: Rough up the ends of the batteries with sandpaper where you intend to solder. Use a big iron and work fast, so you don't heat up the insides of the cells.
kevbo
kevbo
Silver Member
Silver Member
Post  RknRusty Mon May 06, 2013 12:08 pm
kevbo wrote:...Rough up the ends of the batteries with sandpaper where you intend to solder. Use a big iron and work fast, so you don't heat up the insides of the cells.
Good advice. I always worried about damaging the internal connection to the end plates.
Post  tubebass Mon May 06, 2013 2:21 pm
I've had no luck soldering to D cells. Yes, I used a big iron and tried to work quickly, but when I was done, both cells were reading dead - zero volts.
tubebass
tubebass
Silver Member
Silver Member
Post  OVERLORD Tue May 28, 2013 4:29 am
Hi Alan,
Here's a batterie box for 2 "D" cells I made over the weekend. I used the formed plastic bit from the retail package and built a plywood box around it. I cut 2 pieces of copper to size and inserted them on both sides. With 2 brass bolts the inner plastic is held in place and wingnuts hold the cables . The cover is held on with a rubber band. Here are some pics.
Lieven
home made battery box Imgp2810
home made battery box Imgp2811
home made battery box Imgp2812
home made battery box Imgp2813
home made battery box Imgp2814
Post  bullit132 Tue May 28, 2013 8:55 am
that is very cool im making one today Small Cox Logo
bullit132
bullit132
Post  RknRusty Tue May 28, 2013 12:58 pm
Pretty slick. Funny how the simplest things turn out to be the best solution.
