Stirling engine build log Cox_ba12
Stirling engine build log Pixel
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Stirling engine build log Empty
Stirling engine build log Empty Stirling engine build log
Post  mitchg95 Thu Feb 14, 2013 9:26 pm
I am making a stirling engine in my machining class as a project the my teacher assigned. We only 11 weeks left this year so ill have to work fast as my class is 3 hours 45 minutes long.
Any way I have started this week and have 1 part done which is the main shaft. It measures .250" outside diameter and is 2.125" in length
Today i started on the flywheel for this engine, it is made of brass, currently has an od of 3.500" and is just under 1" thick, I faced off one side of the part, drilled the whole for he shaft, and cut the relief in the part .240 deep
Pictures to come in a little bit
mitchg95
mitchg95
Stirling engine build log Empty Re: Stirling engine build log
Post  mitchg95 Thu Feb 14, 2013 9:43 pm
Here is the front view of the fly wheel...
Stirling engine build log 6VM4jXNl
here is the reverse side of the fly wheel, as you can see i still have some more lathe work to do
Stirling engine build log Not3AKMl
main shaft...
Stirling engine build log 4HQnsvQl
Stirling engine build log BEWBEVRl
perfect snug fit Smile
Stirling engine build log Zn9mDU7l
I still have a couple more days of work to do on the fly wheel, both on the lath then the milling machine to drill 6 wholes into the face of the part, then drill and tap at a 45 degree angle for a set screw, then back to the lathe again to do the easy job of getting the final out side diameter of the part which is 3.000" with a tolerance of +-.001"
after this i need to make 2 different pistons, 2 cylinders, 2 connecting rods, alchohol burner, and a few more various parts to complete the engine
one of the cylinders is going to be made out of stainless steel and the other out of brass
mitchg95
mitchg95
Post  Dizzyman2011 Fri Feb 15, 2013 2:16 am
Looking good there Mitch how come your doing one steel and other in brass is that part of the brief to do one of each ? Keep the pics coming
Dizzyman2011
Dizzyman2011
Post  mitchg95 Fri Feb 15, 2013 2:22 am
the plans call for standard steel for the larger displacer cylinder, so my teach told me to use stainless and it said to use brass for the power cylinder
mitchg95
mitchg95
Post  Surfer_kris Fri Feb 15, 2013 2:45 am
I'm only guessing, since I haven't seen your drawing/design, but you don't want to have any heat loss through the piston that works on the hot air side, so there stainless steel is a good choice for the material.
Surfer_kris
Surfer_kris
Post  mitchg95 Fri Feb 15, 2013 2:48 am
Surfer_kris wrote:I'm only guessing, since I haven't seen your drawing/design, but you don't want to have any heat loss through the piston that works on the hot air side, so there stainless steel is a good choice for the material.
that is what i think the teacher was thinking, what is strange is how much smaller the displacer piston is to the inside diameter of the bore for the stainless displacer cylinder, it is about .060'' smaller
mitchg95
mitchg95
Post  Surfer_kris Fri Feb 15, 2013 3:04 am
Do you have any drawings?
If the piston on the cold side is sealed by o-rings, and plenty of grease, then the piston does not have to be very tight itself.
Surfer_kris
Surfer_kris
Post  mitchg95 Fri Feb 15, 2013 4:17 am
i do have the drawings, not on me at the moment. I left them in my locker at school
mitchg95
mitchg95
Post  mitchg95 Mon Mar 04, 2013 10:52 pm
ok, so I have not posted any progress that I have made on the engine here because I have been busy with school and keeping the other build thread that I have for this engine on another forum "home model engine machinist"
here is the link
http://www.homemodelenginemachinist.com/f31/stirling-engine-build-20137/
mitchg95
mitchg95
Post  mx862 Mon Mar 04, 2013 11:03 pm
Very nice work Mitch!
My first engine was a stirling.. a tuna can/ junk i had laying around version...that i "dressed up" a bit.. still run it from time to time... my elderly stepfather calls it robo porn.. HA! lol!
mx862
mx862
Post  mitchg95 Mon Mar 04, 2013 11:33 pm
lol!
this engine is coming along great, still have more parts to machine
2 cylinders, finish the flywheel along with the piston that I have right now that is almost complete
robo porn... lol!
mitchg95
mitchg95
Post  mx862 Mon Mar 04, 2013 11:44 pm
It even has "Authentic" sound lol! i should make a video.. one of the supporting A arms broke off last month when i accidentally dropped it Embarassed , as i used JBweld to attach them to the top back then... can probably clean it up and solder it properly.
mx862
mx862
Post  mitchg95 Mon Mar 04, 2013 11:46 pm
mx862 wrote:It even has "Authentic" sound lol! i should make a video.. one of the supporting A arms broke off last month when i accidentally dropped it Embarassed , as i used JBweld to attach them to the top back then... can probably clean it up and solder it properly.
you should make a video! shame you dropped it, buy hey jb weld fixes everything... i even used it to fix a crank case on my 1/5 scale rc car with a 30.5cc engine
mitchg95
mitchg95
Post  mx862 Tue Mar 05, 2013 12:28 am
Jb-Weld 1001 uses! i cant count how many times it has saved my a$$, or used for model building.. i found the stuff makes excellent heat formed foam molds, no other metal filled epoxy has given me the same results.
Repaired enduro bikes out on the trail with it (had to wait overnight).
I love the stuff... like duct tape.. a must have for the common DIY man.
mx862
mx862
Post  mitchg95 Tue Mar 05, 2013 11:47 am
lol, one cant live without some jb weld lol!
mitchg95
mitchg95
Post  mitchg95 Wed May 01, 2013 11:37 am
I have made a lot of progress to this engine since last updating this build log, I have finished the flywheel, main shaft, fly wheel standards, power piston, power cylinder, displacer cylinder, displacer cylinder back plate, discplacer cylinder standard, displacer cylinder standard support, displacer piston (2x), connecting rod, and one of the crank disks, here are the pictures
Flywheel with main shaft:
Stirling engine build log Len7CZxl
Stirling engine build log PkIqB1Il
Stirling engine build log QWIRC0al
Flywheel standards:
Stirling engine build log D9fu6Fyl
Stirling engine build log COryZB3l
Power Piston and Cylinder:
Stirling engine build log OIc3DBul
Stirling engine build log T8CZ98jl
Stirling engine build log KAvcYIVl
Stirling engine build log MWJEXxOl
displacer cylinder, displacer cylinder back plate, discplacer cylinder standard, displacer cylinder standard support, displacer piston (2x):
Stirling engine build log TEtL2ZOl
Stirling engine build log G1a2Johl
Stirling engine build log OVwodsEl
Stirling engine build log N9svjKzl
Stirling engine build log TTelZ6ol
Stirling engine build log UALyYQdl
Stirling engine build log ZsjQeybl
Stirling engine build log AkvKScnl
Stirling engine build log Mck45E6l
Stirling engine build log IS39gRIl
Stirling engine build log 2rVZjOpl
new piston,
Stirling engine build log CfnHN2El
Stirling engine build log 7Xhy4tCl
Stirling engine build log 26aXmcCl
Stirling engine build log X7rNUlDl
Connecting rod:
Stirling engine build log MXhlBOWl
Crank disk:
Stirling engine build log Bl9Bc5il
Stirling engine build log XD7MdIWl
Stirling engine build log Wlb7Wzrl
Stirling engine build log FVQEhSbl
mitchg95
mitchg95
Post  PlaidHatter Tue Jul 21, 2015 3:16 am
Darn! I was hoping to see the finished product at the end! Looked real nice.
PlaidHatter
PlaidHatter
Silver Member
Silver Member
Post  cox24711 Tue Jul 21, 2015 5:34 am
oohhhhhhhhh nice its going to be great !!
cox24711
cox24711
Post  AUjack2003 Tue Jul 21, 2015 5:35 am
It sure is going to be great
AUjack2003
AUjack2003
Silver Member
Silver Member
Post  pkrankow Tue Jul 21, 2015 6:26 am
Awesome!
Have a greenie for that photo spread.
Post  Oldenginerod Tue Jul 21, 2015 6:45 am
That post is over two years old. We haven't heard from mitchg95 for quite a while. I will agree, that's a neat looking build.
Post  mitchg95 Thu Jul 23, 2015 10:58 pm
Holy cow.... I had no idea it had been 2years since I posted last. ALOT has changed over the last year and a half, I dropped out of precision machining at the community college, got into drugs and alcohol back in January 2015, got kicked out of my parents house in April, since then I lived in my car for the last 3 months, got clean and sober and moved in with my great aunt in geneva Minnesota.
I should never have gotten into that whole ordeal in January because of that, I litterally only have a very small handful of relatives that will have anything todo with me, pretty much all my friends and family that I grew up around in colorado have left me.
I've done some stupid [bleep] and I do regret it. But one song keeps me going. It is a folk punk song by my favorite band, days n daze... It goes "we'll I've made my bad descisions and I can live with that, because even on the worst days life's never all that bad."
Ok, so now about the engine, because of the whole ordeal, all the parts that I worked so hard to create have gone missing and now I am set back a little further than were I began. I wish I could finish the engine but, that is a physical impossibility. Unless I could find someone with a mill and a lathe that they would let me use, even then I have to track down a full set of drawings and start the whole project over again
MitchG95
mitchg95
mitchg95
Post  Cribbs74 Fri Jul 24, 2015 12:28 am
Mitch,
Have you considered the military?
It will give a young man direction, a paycheck, pay for your schooling, pay for a certification and allow you to travel.
Yes there are some things that won't be fun, but the good far outweighs the bad.
Just a thought,
Post  Oldenginerod Fri Jul 24, 2015 7:38 am
Well Mitch, I'm glad you felt you were able to share with us the troubles you've had. It can be pretty tough keeping the house in order and sometimes things just go wrong. I think I'll get my 20 year old son to read your last post. It seems his folks (us) know nothing and he seems to be determined to do whatever we say not to do. Life can mess up real quick and sometimes making mistakes is the only way we learn. Just gotta hope things don't get too bad along the way. Drugs and alcohol will kill you, and maybe a few other people along the way, so they're a no-where road.
I hope that you can sort out the issues with your folks. It doesn't take too long to realize how much families need each other and one simple mistake can mess up a whole heap of relationships.
Go well. Thumbs Up
Post  GallopingGhostler Fri Jul 24, 2015 8:30 am
Mitch, thankfully by the grace of God you still have family that cares for you to give a roof over your head. Military is a good option if you qualify as they will give you a roof over your head with 3 squares a day and spending money for several years, plus educational benefits.
I did that in 1972 and after 3 years in the Army went to college on the GI Bill (a scholarship grant). Got a friend who was in college, but got married, had kids and had to drop out of college. He spent several years job hopping, now fortunately with 3 kids is in an electrician apprentice program.
Another friend had a lot of potential, as he won awards through his science fair projects. He got married out of high school. I met him while in college one day at a local supermarket. With several kids, he was a meat cutter, nothing wrong with that. It is just that he was extremely intelligent, could have been something earning far greater wages instead of above minimum.
Since you are young and single, you still have options and would be best for you to seek a career type program. I can't say exactly which as you have certain gifts and talents and would want a job that you enjoy doing, not just surviving in.
Construction field is wide open as it seems many no longer like to do hard physical work, although it pays decent wages. Good skilled tradesmen are getting harder to find and are in demand. Commercial truck drivers and equipment operators make good money, too.
Since you enjoy operating lathes and milling machines, I imagine you enjoy wrenching, too. Electricians, plumbers, air conditioning mechanics, ASME certified welders; building automation system, fire alarm, security system mechanics, etc. are a few specialties that earn a better wage.
There are train engineers, got a friend doing that. But I'd stay away from that field as they put in long hours with stretches away from home, affects family life.
If possible you might want to seek out an apprenticeship program. After 4 years experience, you get licensed and have a career path. If you are not sure of what job you might be suited for, your community college or employment office might have an occupational interest survey you can take, which could help point the right direction.
