throttle backplate
Re: throttle backplate
Yes, the grey backplate is the correct one and you can use the brass needle from any other backplate.
Thanks. I need to see if we need anything else, then make the order.
duke.johnson- Diamond Member
Well, the boys and I flew the 1/2A carrier plane today before dinner. We put in about a dozen flights and things work ok. Needs a little work. I'm not sure if I have the right piston and cylinder. I bought the grey throttle back plate and if I remember right I should not ue te SPI cylinders, right? How do I tell if I'm using the right cylinder?
Any twin slit sure start cylinder should work as these did not have SPI. A #6 QZ cylinder or #8 cylinder would also work.
Jason_WI- Top Poster
tarno
Not dure about thispart though,I never got one to do a chech against my TD tarno carbs.ahrma_581 wrote:ado1974 wrote:bernie
i was thinking, modify the reedie backplate,
remove and plug needle and fuel nipple holes
then use TD carb mounted either on chock tube(similar to yours)
or make adaptor and mount TD carb directly onto backplate opening
cheers
a.
Tarno made a reedie adapter for their carb: they occasionally turn up on ebay. Absolutely correct. Vaguely recall they had slightly different carbs for TD and reed engines. Location of throttle stop, maybe id??
There is still the old style ,simpler ACE reedie engine throttles to go another route too.
Jaspur_x- Banned
» COX backplate throttle
» TD .020 backplate
» shure start air intake break
» Cox RR - 1 Backplate
» 049 backplate never seen before
» TD .020 backplate
