Line tension.....or lack therof. Cox_ba12
Line tension.....or lack therof. Pixel
by batjac Today at 9:47 pm
by roddie Today at 8:50 pm
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Line tension.....or lack therof. Empty
Line tension.....or lack therof. Empty Line tension.....or lack therof.
Post  Cribbs74 Mon Sep 03, 2012 6:16 pm
I finally decided it's not me and it's the plane that is allowing the lines to go slack.
I am not sure what is causing it. It flies great in level flight but when I loop or try anything else it flys inward. I can usually control it, but as I get more wild so does the slack lines.
I have 2 washers under the engine mounts so about 3 degrees of offset. Rudder set per plans and 3 pennies for tip weight. All control surfaces are parallel to each other. There is a tiny bit of a tweak in the wing but ever so slight.
Any Ideas guys?
Line tension.....or lack therof. Empty Re: Line tension.....or lack therof.
Post  RknRusty Mon Sep 03, 2012 7:16 pm
When you eyeball the plane check for: if you hold the leadouts at neutral and suspend the plane from them, is it pointed a couple of degrees nose down(if not, adjust by moving the leadout guide backwards); any wing warp; any twist in the fuse; the distance from the LE to the plane of the nose is equal; the distance from the TE to the stab is the same on each side; the stab and the wing line up together when you kook over the wing from the front; the rudder is vertical; no loose patches of covering causing drag.
I know you mentioned some of those things, but I figured I'd post it all. How much of a slight tweak in the wing? If you have a left handed prop, you could run the engine in the other direction. That would possibly help some. This is bound to get laughs, but if all else fails, tie a short streamer to the outboard wingtip. I swear I've never done that or heard of it, but what the hell, I'll try anything.
If I think of anything else I'll post it.
Post  Ken Cook Mon Sep 03, 2012 7:22 pm
Ron, grab the plane by it's leadouts and hang it in front of you like a plumb bob. Take note how the fuse is parallel to the ground. You certainly want the nose pointing slightly to the ground. This is where leadout placement is critical. Your leadouts are probably non adjustable and permantely fixed. I'm just explaining why this is important. I don't follow ANY plans when it comes to the installation of the tip guides. I generally tack glue them with CA and do the above test. Most of my full size stunters have adjustable leadouts. Sweeping the leadout guides forward makes the plane yaw inboard towards the pilot. Moving the leadouts back, points the nose outboard. In the event your plane is already pointing slightly nose down while hanging, I would look at other issues. Speed is important. I use no rudder offset and it's absolutely not needed and it may just be slowing the plane down due to the plane yawing outboard. Tip weight is really only important on take off. Once the plane is flying, speed takes over and keeps the plane out there. Too much weight can hurt the plane in maneuvering causing floundering especially when the plane goes into a loop for instance. On the downside it can cause the plane to bounce. Your weight in the tip sounds correct. The wing may have a slight twist in it.
I would certainly take the plane while sitting in a chair and place it nose down between your legs and sight the trailing edge to the leading edge. If the inboard wing panel is up, it could be causing the inboard wing to tilt downwards. Twist the inboard wing down and reshrink the covering. If the outboard wing is down, it's causing the same problem as it may be lifting the outboard wing into you. Twist the outboard up and reshrink. After any covering shrinking, sight your trailing edges for any bowing and fix. This can be tedious but it's well worth the effort. I see Rusty and I were typing simultaneously so I apologize for any repeats. Another thing we do is to cut out a piece of aluminum can. Cut a tab about 3 " wide X 1 1/2" use clear packing tape the tab onto the bottom of the trailing edge with about 5/8" hanging into the air. Keep the tab straight and fly. Check for tension. If needed, bend the tab up slightly and re fly and check for tension. It works well and can be done at the field quickly. Ken
Post  Ken Cook Mon Sep 03, 2012 7:38 pm
Another common design factor for line tension used in building was to have the inboard wing slightly larger than the outboard wing panel. This is easily done on a profile simply by sliding the fuse over to the outboard side a bit. The inboard wing is technically flying faster than the outboard wing due to the smaller radius of the circle hence more lift is being generated. This allowed for less tip weight supposedly. Many large full size stunters have the outboard wing shortened by one rib bay. My Yak-9 which was a Sterling Kit had the profile body offset by a 1/2". I've had this work and I also had some planes that I questioned if this was causing problems. Ken
Post  fit90 Mon Sep 03, 2012 7:47 pm
I don't know anything about control line but all airplanes have this in common: if your wings are warped and the warp causes the plane to roll away from you in straight and level upright then that same warp will cause the plane to roll into you in straight and level inverted. Might be worth looking into.
Good luck,
fit90
fit90
Post  Kim Mon Sep 03, 2012 7:48 pm
Ken Cook wrote: Another common design factor for line tension used in building was to have the inboard wing slightly larger than the outboard wing panel. This is easily done on a profile simply by sliding the fuse over to the outboard side a bit. The inboard wing is technically flying faster than the outboard wing due to the smaller radius of the circle hence more lift is being generated. This allowed for less tip weight supposedly. Many large full size stunters have the outboard wing shortened by one rib bay. My Yak-9 which was a Sterling Kit had the profile body offset by a 1/2". I've had this work and I also had some planes that I questioned if this was causing problems. Ken
Not to mention the countless hours spent, down through the decades, as Rednecks stared at their carefully built work of art, wondering HOW they managed to build one wing longer than the other !!!!
Post  Ken Cook Mon Sep 03, 2012 7:52 pm
Kim, I must be a redneck. I'm guilty of what you stated and I've done it. I glued the wing in upside down making the inboard shorter. You never realize this when the glue is drying. It's always the next day after it had plenty of time to set. I think we've all been there and done that kinda stuff. Ken
Post  Kim Mon Sep 03, 2012 8:02 pm
Yeah...thus my policy for staying out of the shop when I'm tired !!!
There WAS that ugly incident, back in the 80's when I built a Ken Willard "Poolboy" flying boat fuse UP-SIDE-DOWN, priding myself on the precision cuts and squareness of the frame the whole time!
Post  Jason_WI Mon Sep 03, 2012 8:30 pm
If the plan was drawn before 1981 and called for 3 pennies then you need to use pre 81 pennies. New pennies are zinc and are lighter than the old copper ones.
Jason_WI
Jason_WI
Post  Cribbs74 Mon Sep 03, 2012 9:46 pm
Holy Cow gentleman. You guys gave me plenty to think about. I will go over each and every thing mentioned here.
I will check back in with an answer. Funny thing is I put 3 tanks through the Baby Ring Tonight and it flew beautifully! loops were uneventful. Wind was a touch calmer this evening.
It's frustrating...... Huh...
Post  RknRusty Mon Sep 03, 2012 10:00 pm
cribbs74 wrote:...Funny thing is I put 3 tanks through the Baby Ring Tonight and it flew beautifully! loops were uneventful. Wind was a touch calmer this evening.
Uneventful loops are good, glad to hear it. You're evidently getting more proficient, not as much at the mercy of the plane. Show it who's boss.
Line tension.....or lack therof. Empty re: quote of the day
Post  happydad Tue Sep 04, 2012 1:07 am
Kim: that quote has to make it to the hall of fame for quotes of the day. +1. happydad Small Cox Logo
Futaba Radio RC Plane
happydad
happydad
Post  John Goddard Tue Sep 04, 2012 3:09 am
Fantastic thread boys.
The old Paw'ed Spit I inherited some time back is built
Kinda off centre somehow. I think it's a Sterling kit
Which I thought must have been assembled
incorrectly, but I guess not.
Very Happy
John Goddard
John Goddard
