Math Skills (or lack therof) Cox_ba12
Math Skills (or lack therof) Pixel
by Ken Cook Today at 3:23 am
Math Skills (or lack therof) Empty
Math Skills (or lack therof) Empty Math Skills (or lack therof)
Post  Cribbs74 Tue Aug 20, 2013 1:34 pm
I just purchased a gallon of Powermaster 30% Nitro 9% oil (castor/synth) The breakdown is as follows:
9.6oz Nitro
2.88oz Oil
19.52oz Methanol
By my calculations I will need to add 3.52 oz to bring the oil to the 20% that I want.
32x.20= 6.4oz
So the 32oz gallon is now 35.52oz.
My question is do I need to subtract 3.52oz from the Nitro and Methanol to figure out the new percentages?
If I do that the Nitro goes down to less than 20% and that doesn't seem right at all.
Math Skills (or lack therof) Empty Re: Math Skills (or lack therof)
Post  RknRusty Tue Aug 20, 2013 1:44 pm
You're starting with a gallon (128oz.) or a quart(32oz)? Or you're pouring off a quart from the gallon to modify...
Post  crankbndr Tue Aug 20, 2013 2:08 pm
I always have to retrain myself every time I do the mixing. The volume of the nitro and meth would not change and need to be figured using the new total volume to find the%
Post  Cribbs74 Tue Aug 20, 2013 2:12 pm
I'm an idiot...... Yes 1 gallon 128oz
So the new numbers are as follows
38.4 oz Nitro (30%)
11.2 oz oil (9%)
78.4oz Methanol (61%)
I need to add 14.4oz of oil to bring the total oil content to 20%
What I want to know is how to calculate what my new Nitro content is.
Post  crankbndr Tue Aug 20, 2013 2:18 pm
I think you divide the nitro volume by total volume
38.4 divided by 142.4 = .2696% nitro
Post  ian1954 Tue Aug 20, 2013 2:20 pm
I have used existing weights and then rounded %
Add 4.3 oz of Castor oil and you will get this
For total Glow Fuel volume of 36 US Fluid Oz's
54 % Methanol = 00.15 US Gallon or 19.4 US Fluid Oz
26 % Nitro Methane = 00.07 US Gallon or 9.4 US Fluid Oz
8 % Synthetic Oil = 00.02 US Gallon or 2.9 US Fluid Oz
12 % Castor Oil = 00.03 US Gallon or 4.3 US Fluid Oz
Total Oil mix is 20 %
My calculator doesn't do fractions of percentages!
ian1954
ian1954
Post  Cribbs74 Tue Aug 20, 2013 2:41 pm
Thanks guys,
Math is not my strong suit. I about busted a blood vessel coming up with the percentages.drunken
Post  OVERLORD Tue Aug 20, 2013 3:43 pm
You, guys, make it yourself ever so difficult using floz's, oz's, gallons - US or imperial - pounds, stones, inches  and feet. I do not get all this.
Generally speeking, your new obtained total quantity of liquid with the added castor will always be your new 100%.
The quantities of nitro and methanol that weren't touched, are still present as the same quantities in your new mixture. So percentages of nitro and methanol can be calculated using the rule of 3.
To find the new total oil quantity, substract the known nitro and methanol quantities from your total volume. The oïl percentage can then easily be calculated in the same way as above.
Lieven
Post  JPvelo Tue Aug 20, 2013 5:33 pm
I'm with Lieven. Here's how I do it:
I use power master master basher. 20% nitro, 14% castor synth mix. I need to add 6% oil to the total volume to bring the oil to 20%. I hold a metric ruler next to an old rubbing alcohol bottle and fill to roughly 9.4cm with fuel. I then add Klotz to bring the volume to a hair over 10cm just to be safe. A little extra castor is better than not enough. This drops the nitro to between 18 and 19%. this is my favourite fuel and it's only $8.99 at my local hobby shop.
JPvelo
JPvelo
Post  andrew Tue Aug 20, 2013 7:13 pm
Excel fuel mixture calculator --- takes a while to download from Bernie's site and requires that you have Excel on your computer.
www.coxinternational.ca/files/castor.xls
Post  Cribbs74 Tue Aug 20, 2013 7:53 pm
Hey Jim,
Normally I use SIG 25 or the Master Basher 20%. However this time I wanted a little more Nitro. Still powermaster brand. The gallon was 20.99 so it's cheaper than the quart.
Thanks for the tips much appreciated. Klotz is synthetic isn't it? Or are you using Klotz Benol.
Post  pkrankow Tue Aug 20, 2013 8:40 pm
That looks like a good spreadsheet, not much different from mine.
Post  JPvelo Tue Aug 20, 2013 8:50 pm
Cribbs74 wrote:Hey Jim,
Klotz Benol. 20.99!? My shop has it for 39. Curious to hear how it works.
JPvelo
JPvelo
Post  Cribbs74 Tue Aug 20, 2013 9:12 pm
Lol, no I meant the gallon of Powermaster 30% was $20.99. I buy Benol for around $8-10 for a pint.
Edit: My mistake.... I didn't see the period after Benol. Anyway, yes Powermaster 30% was $20.99 it's actually $23 or so, but I got a military discount.
Post  dinsdale Wed Aug 21, 2013 6:28 am
Don't forget though, that after all that you must multiply by the number you first thought of and subtract your grandmother's age and ... tongue
dinsdale
dinsdale
Account Deactivated by Owner
Post  Cribbs74 Wed Aug 21, 2013 8:16 am
Right! I wrote that in my notes.
I added the oil last night. I only had 10oz of Benol castor so I had to pour some off into a quart bottle to mix it.
Appears to be good. Thanks to all who helped
Post  JPvelo Tue Sep 03, 2013 7:55 pm
Did you get this fuel mixed? How's it working?
JPvelo
JPvelo
Post  Cribbs74 Tue Sep 03, 2013 9:43 pm
Sure did Jim,
It works excellent. I had to do it by the quart as I didn't have enough Benol to do the entire gallon. I have run 4 different engines on it. Great runs and no compression loss. I haven't torn one down to check ball socket play, but it looks promising.
