RC Airboat Engine
RC Airboat Engine
Built this one up from spare parts. I'm hoping to get about 14K RPM with a 6x3.
SureStart top end
Dragonfly muffler/throttle assy
Babe Bee metal back plate
TD spinner
LH starter spring with SnapStart cam (this combo works pretty well I think)
Brass driveplate
SureStart top end
TD spinner
Brass driveplate
Re: RC Airboat Engine
Nice little workhorse there. Is that a regular starter spring using the snap starter cam? I never thought of using that spring with a cam.
You doing a pusher or puller Matt?
RknRusty wrote:Nice little workhorse there. Is that a regular starter spring using the snap starter cam? I never thought of using that spring with a cam.
Thanks.
Yep, it doesn't wear down the prop, and it also completely disengages and doesn't rub against the cam robbing power. You just hook the spring onto the hub, wind back once, and wallah.
microflitedude wrote:PV Pilot wrote:You doing a pusher or puller Matt?
Pusher, on a Dumas Lil Buggy.
Cool!,,just finishing up a Dumas 1/2A SK Daddle JR boat,,that will have throttled TD .049 action. (prop drive)
You building from a kit?
Now that is a good idea.microflitedude wrote:RknRusty wrote:Nice little workhorse there. Is that a regular starter spring using the snap starter cam? I never thought of using that spring with a cam.
Thanks.
PV Pilot wrote:microflitedude wrote:PV Pilot wrote:You doing a pusher or puller Matt?
I bought it built from Joe. It was cheaper than getting the kit, plus I don't have hardly any kit building experience.
Eventually I want to run either my Medallion or my TD on it. Using the Bee right now for sake of simplicity.
microflitedude wrote:PV Pilot wrote:microflitedude wrote:PV Pilot wrote:You doing a pusher or puller Matt?
I see. As a tip,,add a phenolic thrust washer,,so you don't grind away case or drive washer material when in pusher mode with any engine you put on there.
http://coxengines.ca/cox-.049-thrust-washer-phenolic-3.html
Well, speaking from experience,,the little swamp buggy kit is a good one to cut your teeth on as far as construction. Instructions are straight forward, you have bulkheads and rib sections just like building a wing on a plane. it all translates over as far as general wood model construction is concerned.
So what the heck is a Swamp Buggy?
RknRusty wrote:So what the heck is a Swamp Buggy?
In my terms, a 1/2A Airboat! (others might say 4x4 dune buggies for mudding and stuff)
I have a Dumas Lil Swamp Buggy.
http://www.ebay.com/itm/Dumas-LiL-Swamp-Buggy-18-DUM1502-/360331785199#ht_1827wt_906
Here is a video from TeeBee. (not mine)
Pretty cool.
I guess if your engine takes a drink, just shake it out and get it cranked up as soon as possible and boil all the water out and it'll be like it never happened. I'd get one for the swimming pool but my wife would kill me if I left an oil slick in it.
Lil swamp buggy will tear over just wet grass, or dry. They are a fun little airboat.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXE383
Just posted a pick of my latest boat in the gallery section. My 20yr old Lil swamp buggy is there also.
RknRusty wrote:Pretty cool.
My friend has a .40 size J-3 Cub on floats. He has dunked it many times, but it never really hurt anything. He holds the nose down, and turns the engine over for about 30 seconds with an electric starter. Ran fine after that.
» Cox Powered Airboat
» R/C airboats
» Cox powered airboat outrigger
» Check out my custom Airboat. Cox .049
» *Cox Engine of The Month* Submit your pictures! -December 2014- *ENGINE GIVEAWAY*
» R/C airboats
