Baby Ringmaster build (Maiden flight report!)
Page 1 of 3
Page 1 of 3 • 1, 2, 3
As promised,
I started the build tonight I should have it done over the next couple days. It's a scratch build based off of Matt Kania's design. Thanks to Rolla for providing me with the plans. Anyway I cut out the fuse, rudder and stab. Wing ribs tomorrow. I gotta make 10 of em and it's painful. I have everything I need here to finish it up at the hotel hopefully I can get it home in one piece.
Re: Baby Ringmaster build (Maiden flight report!)
Almost there.....
Need to do the trailing edge and run the control rod. I noticed there is no weight in the plans for the outboard wing. You think I should add some?
Looks beautiful Ron.
As far as the tip weight, you have a
nice assortment right there on the plan.
As far as a suggestion, I got nothing .
I take it that's your new widdow. Schweet!
Judging from your exploits, I gotta get a room.
dckrsn- Diamond Member
1/4 oz (From an old set of baby ringmaster plans) which is about three pennies.
lousyflyer- Gold Member
I used two pennies for tip weight. Remember to offset either the firewall or the engine with washers. This will help a bunch. I forgot to and had to remove some line. Still flew well.
Rolla
Rolla
Godsey3.0- Platinum Member
dckrsn wrote:Looks beautiful Ron.
Nope, I actually took one with me! Lol, yeah I'm that ate up with Cox engines. That's actually my first Cox engine I ever bought.
microflitedude wrote:How much would you build one of those for, Ron?
Depends....... Shoot me a PM
Godsey3.0 wrote:I used two pennies for tip weight. Remember to offset either the firewall or the engine with washers. This will help a bunch. I forgot to and had to remove some line. Still flew well.
Rolla
Got it. Plans show no offset or tip weight.......
Ok,
Time to cover it! Think the maid will be mad?
Be ready for it. Do not over control it. It was not too bad my first flight. I did not have to much trouble with it. I was back pedalling because of wing and no engine offset. It loops nice and looks great. The Black Widow will fly it nicely.
Hello, room service?Think the maid will be mad?
Yeah, hi, I need....................
Leave her a sawbuck, and all is forgiven.
dckrsn wrote:Hello, room service?Think the maid will be mad?
Hey, good idea! Still going to hide my toothbrush though.
Ok,
I got it covered, not happy with the wing tips. They aren't hateful just not as pretty as I would have liked. I figure this model will be a stunt trainer so it may take a beating from time to time. If it was perfect it would sting more if I messed it up.
I may paint it here or I may wait until I get home. Who knows. I cannot find 3/64 piano wire anywhere around here!!!!!!
What was nice about mine is the short wire flexes very little. I have yet to have a problem with it in the air. I do not have a support or a z bend in the middle.
Godsey3.0 wrote:What was nice about mine is the short wire flexes very little. I have yet to have a problem with it in the air. I do not have a support or a z bend in the middle.
I found some 3/64 rod except it's brass. I think it's going to be too flimsy. I made the hole the rod goes through large enough to change to a steel one if I can ever find one.
Do you solder the lead out rings?
RE: Baby Ringmaster build
Great build from scratch !!! Can't wait to see it fly...Only thing about the thread that bothered me was seeing the inside of your hotel room.. I traveled for a living for 37 years and I'll bet I stayed in at least 500 rooms with the self same carpet, furniture, and mirror !! I think that the nightmares may return !!! Keep your valuables and toiletries locked up while you are out of the room///Of course, I don't have to tell you that...
Pretty model and I'll expect that Black Widow to make some noise and have some fun....
Steve....
Steve....
66 Malibu- Gold Member
For 1/2A planes crimping of leadouts is all that is necessary.
If you need a control rod you might consider a Kwik link on a threaded rod from the local hobby shop. The rods are .073 diameter and you can buy them in 12" or 36" lengths.
The rod is easy bend into a "Z" and the kwik link hooks onto the control horn of the elevator.
That was a quick build. Looks great. Did you add that 1/4oz(7g) tip weight? It will definitely need it, that Black Widow will be lifting the outboard wing. I forgot to put one in my Li'l Satan and it was not a happy bird until I made a slit in the covering and epoxied a weight in there. Or you can put a reverse prop on it and run it backwards, that might work in the absence of a weight.
66 Malibu wrote:Great build from scratch !!! Can't wait to see it fly...Only thing about the thread that bothered me was seeing the inside of your hotel room.. I traveled for a living for 37 years and I'll bet I stayed in at least 500 rooms with the self same carpet, furniture, and mirror !! I think that the nightmares may return !!! Keep your valuables and toiletries locked up while you are out of the room///Of course, I don't have to tell you that...
Steve....
Lol, yeah I travel quite a bit too. Never had a problem with stolen stuff.....yet.
I can't wait to fly it!
lousyflyer wrote:For 1/2A planes crimping of leadouts is all that is necessary.
Good idea, I may just have to go that route. Thanks for the suggestion.
RknRusty wrote:That was a quick build. Looks great. Did you add that 1/4oz(7g) tip weight? It will definitely need it, that Black Widow will be lifting the outboard wing. I forgot to put one in my Li'l Satan and it was not a happy bird until I made a slit in the covering and epoxied a weight in there. Or you can put a reverse prop on it and run it backwards, that might work in the absence of a weight.
Dang it! Where were you 4 hrs ago!!! Yep, forgot. Oh well I didnt like how the wing tip looked anyway.
Thanks Rusty.
Ohhh, you gotta have that tip weight! (BTW one penny = 2.5 grams)
lousyflyer wrote:Ohhh, you gotta have that tip weight! (BTW one penny = 2.5 grams)
Yeah I knew that and I had it all planned out. Just plain forgot!
Thanks for the penny gram info.
Are you flying on dacron lines or spiderwire/spectra line?
» And yet another Baby Ringmaster (Maiden Report)
» Super Clown build thread (Maiden Report)
» Ringmaster maiden flight
» First Baby Ringmaster build
» Twister Wing - Maiden Flight Report from the Zaerodrome
Page 1 of 3
