Pee Wee 020 crank shafts the same? Cox_ba12
Pee Wee 020 crank shafts the same? Pixel
by rsv1cox Today at 10:07 am
Pee Wee 020 crank shafts the same? Empty
Pee Wee 020 crank shafts the same? Empty Pee Wee 020 crank shafts the same?
Post  WingingIt74 Wed Mar 14, 2012 8:01 pm
I have a drive head that won't fit??
WingingIt74
WingingIt74
Pee Wee 020 crank shafts the same? Empty Re: Pee Wee 020 crank shafts the same?
Post  Jason_WI Wed Mar 14, 2012 8:14 pm
I have mixed and matched parts on the pee wees and never ran into a problem with drive plates or any other parts. Do you have a pic of the part?
Jason_WI
Jason_WI
Post  WingingIt74 Wed Mar 14, 2012 10:55 pm
I've found 2 different sizes. One on the tapered case and one on the straight case.
WingingIt74
WingingIt74
Post  WingingIt74 Wed Mar 14, 2012 10:59 pm
I just got an email from Matt, he said the 90's and up version has a larger shaft end/drive plate.
WingingIt74
WingingIt74
Post  EXModelEngines Thu Mar 15, 2012 8:53 am
WingingIt74 wrote:I just got an email from Matt, he said the 90's and up version has a larger shaft end/drive plate.
Yes, and after further research I think the larger diameter crankshaft splined ends/driveplates ones may have been earlier than just the 90's. I pulled a few Skycopter cases (late 70's) and they too had the larger crank/driveplate combo.
This goes for both round and the hex driveplates.
If anyone has any more concrete info it would be appreciated.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  Cribbs74 Thu Mar 15, 2012 10:28 am
Matt
Yeah,
I would like to know more. I recently aquired a really early pee wee. Really pronounced taper case, no step/wrench relief cylinder backplate has no screen no markings and no thimble drome on the red tank. The drive plate is chewed up from pliers and I was going to get a replacement for it but, now I am not sure what will fit or what to be looking for. I really thought they were all the same. This thing looks brand new apart from the driveplate.
Post  WingingIt74 Thu Mar 15, 2012 11:40 am
Sounds like the 2 I have. I don't think red "new" drive plates are available.
WingingIt74
WingingIt74
Post  Cribbs74 Thu Mar 15, 2012 12:37 pm
WingingIt74 wrote:Sounds like the 2 I have. I don't think red "new" drive plates are available.
No, I don't think so. Not readily available but, they do pop up on Ebay more often than not. NOS that is.
Post  nitroairplane Thu Mar 15, 2012 1:08 pm
Well Crank case assemblies with red plates are available from select hobbies.
nitroairplane
nitroairplane
Post  WingingIt74 Thu Mar 15, 2012 1:18 pm
nitroairplane wrote:Well Crank case assemblies with red plates are available from select hobbies.
$25, wow... all I need is the drive plate.
I need one for Jeremy's late Uncle's PeeWee too. This is getting crazy Smile
WingingIt74
WingingIt74
Post  nitroairplane Thu Mar 15, 2012 1:21 pm
Well he has it if you get desperate.
nitroairplane
nitroairplane
Post  WingingIt74 Thu Mar 15, 2012 1:22 pm
I can wait.... I think...
WingingIt74
WingingIt74
Post  Cribbs74 Thu Mar 15, 2012 1:27 pm
WingingIt74 wrote:I can wait.... I think...
I have been toying with the idea of home anodizing. Might save a lot of money in the long run. Especially since most replacement parts are Estes non-anodized stuff.
Post  WingingIt74 Thu Mar 15, 2012 8:45 pm
pic
Pee Wee 020 crank shafts the same? Img_2015
WingingIt74
WingingIt74
Post  Cribbs74 Thu Mar 15, 2012 8:48 pm
Hmmm,
Looks like same length except one has more bearing surface.
What's the diameter?
Post  WingingIt74 Thu Mar 15, 2012 9:13 pm
would the bearing surface cause the engine to overheat?
WingingIt74
WingingIt74
Post  Cribbs74 Thu Mar 15, 2012 9:17 pm
I wouldn't think so. Unless the shaft was a really poor fit and even then it probably wouldn't even run
Post  WingingIt74 Thu Mar 15, 2012 9:20 pm
The engine seems really hot... see my other thread as they are kinda merging together
http://coxengineforum.forumakers.com/t1861-peewee-woes
WingingIt74
WingingIt74
