» Happy Birthday Robert ( Rsv1cox )by GallopingGhostler Today at 8:32 am
» Irvine Mills .75 replica
by Coxfledgling Today at 8:09 am
» COX .020 RC PROJECT
by 1/2A Nut Today at 4:32 am
by Admin Today at 1:33 am
by MauricioB Yesterday at 11:02 pm
» OS MAX-D
by Ken Cook Yesterday at 3:38 pm
by getback Yesterday at 3:22 pm
by getback Yesterday at 7:55 am
» Wanted peewee 20 fuel tank
by GallopingGhostler Yesterday at 2:05 am
» Fox .35 Modifications
by Ken Cook Fri Oct 04, 2024 7:40 pm
by Admin Fri Oct 04, 2024 7:33 pm
by rsv1cox Fri Oct 04, 2024 6:32 pm
sure start time line
Looking on eBay for some .049 engines and saw a what looked like an older Thimble Drome body with a sure start cylinder. Just wondering if this a cobbled together engine?
1975 control line guy- Moderate Poster
Re: sure start time line
Possibly could be cobbled, the double slit exhaust didn't come about until sometime in the latter 1970's. Also, owner could have a worn out cylinder and replaced with a later available cylinder, so it would run.
BTW, welcome to the forum!
Welcome!
The very early Thimble Drome glowheads had a smaller diameter thread. That type of head became obsolete / unobtianable through Cox at some point, so if the glowhead burned out, the cylinder had to be replaced too in order to keep the engine functional. Fortunately, the thread on the cylinder base is same on all the 049s.
A thin-wall cylinder would be more period correct and should not be too hard to find. The engine probably runs just as well with the late model, but might look a bit odd for Cox nerds like myself
Oddness, non-compliance and a tasteful photo might net one a Cox Engine of the Month winner!KariFS wrote:The engine probably runs just as well with the late model, but might look a bit odd for Cox nerds like myself
KariFS wrote:Welcome!
Good to know, thank you for the info.
I've got one of those pre-1956 Cox .049 Thermal Hoppers, story here:
https://www.coxengineforum.com/t17211-cox-049-thermal-hopper-a-never-ending-story
The Thermal Hoppers from 1956 on could use the latest common glow heads. However, if I want, I can change the cylinder on this one to a later one, then use a standard head. It would still be in vogue if I replace the cylinder piston set with one of my thin cylinder ones off one of my other engines.
» The 'Fling' gets Flung...again...this time on it's Hi-Start
» Control line air time....
» Control line time...............
» Cox control line three line throttle
» Does Old Fuel Work? Because my NEW .49 with spring start won't start.
