What Cox .049 Cox engine is it? Cox_ba12
What Cox .049 Cox engine is it? Pixel
What Cox .049 Cox engine is it? Empty
What Cox .049 Cox engine is it? Empty What Cox .049 Cox engine is it?
Post  MauricioB Tue Mar 05, 2024 9:29 pm
Hello boys....
...could someone tell me what .049 Cox engine it is?
I bought it moments ago, but I don't know exactly what engine it is.
I leave you photos here, all information is appreciated in advance! thank you!
What Cox .049 Cox engine is it? Cox_0411
What Cox .049 Cox engine is it? Cox_0412
What Cox .049 Cox engine is it? Cox_0413
What Cox .049 Cox engine is it? Empty Re: What Cox .049 Cox engine is it?
Post  GallopingGhostler Tue Mar 05, 2024 11:07 pm
Mira este enlace por favor: (See this link, please)
https://www.coxengineforum.com/t15703-mesh-screen-049-cox-engines
Eso contiene la información que estás buscando. (That contains the information that you're looking for.)
Post  MauricioB Wed Mar 06, 2024 10:49 pm
GallopingGhostler wrote:Mira este enlace por favor: (See this link, please)
Hello friend, thank you very much.
When I get this engine in my hands I will do maintenance on it. I'll check how many transfers you have.
From what the photograph says, it seems that the steel mesh is to prevent the operator from burning his fingers.
The rear plate is interesting to me since I don't have one that is white and old, I wonder how the air intake hole will compare to others today?
Post  roddie Thu Mar 07, 2024 12:57 pm
Hi Mauricio! I wish you "good luck" with your engine. My records indicate that it is designated as a Cox pe 191-5-mesh. The pe=product engine.. and was utilized in their RTF plastic U-Control airplanes.
What Cox .049 Cox engine is it? Cox_pe10
Yours looks to be all original.. but as you say; you'll need to remove the cylinder or glow-head to observe the porting to know which cylinder you have. These older cylinders were higher precision; being "custom-fitted" with a piston using an air-gap fixture at the factory.
What Cox .049 Cox engine is it? Inspec11
Here is a comparison of a vintage white backplate with a "Killer Bee" (red) high-performance backplate.
What Cox .049 Cox engine is it? Cox_ho20
What Cox .049 Cox engine is it? Cox_ho19
I have two of these "white" backplates. One is alone; (no crankcase-see below) which I've had for a LONG time..
What Cox .049 Cox engine is it? White_10
What Cox .049 Cox engine is it? White_11
Note; the "circlip" style reed-housing.
The other one (see below) came on a mystery engine given to me by rsv1cox (Bob V.) back in 2017.
What Cox .049 Cox engine is it? Dsc04916
What Cox .049 Cox engine is it? Spray-10
I used that engine in my Rodd-E-Liminator tether car.
I made an air-filter to help prevent debris from entering the venturi.
What Cox .049 Cox engine is it? Air-fi12
What Cox .049 Cox engine is it? Air-fi11
Post  MauricioB Wed Mar 13, 2024 11:29 am
Thanks Rodiee for that information!
Dear friends, I share the modification I made on this engine, I hope you enjoy the video.
The engine is great, will be waiting for a future project!
Modified:
Steel mesh was removed.
Gas escape chamber was manufactured.
Speed control air valve was installed.
Post  GallopingGhostler Wed Mar 13, 2024 5:23 pm
¡Buen trabajo duro, Mauricio! (Good hard work, Mauricio!)
La baja velocidad del motor es muy excelente y el nivel del sonido es muy aceptable. Very Happy Thumbs Up
(The low engine speed is very excellent and the sound level is very acceptable.)
Post  balogh Wed Mar 13, 2024 7:01 pm
Very nicely made exhaust muffler Mauricio, and congrats for the low idle speed achieved.
Does this engine have SPI?
Post  MauricioB Thu Mar 14, 2024 1:50 am
Thank you very much friends! I feel very happy with this engine...giving it a little love has won me over and it works incredibly well.
I tell you then:
Andras, yes, it has SPI, I read an article by Rusty that said that for the SPI to be effective, the engine must work at high rpm and with a propeller smaller than 6 inches, so it doesn't change practically anything for me. regarding engine performance.
I took the opportunity to disassemble it to show you photos and polish the exhaust chamber that I manufactured a little, in the photos you can see the machined interior and the stepped part at the bottom, this means that it does not interfere with the rear plastic plate and transmit temperature to it, there is no contact between the muffler and the rear plate.
I wanted to make the SI engine more compact, and lower the original height of the Surestar stem, so that the air valve is lower and not protruding from the engine as if it were an external part. I was surprised by the result, it seems that now there is also a faster response when accelerating, I didn't do many tests because my neighbors sleep, hahaha, just a few jerks, tomorrow I will do more tests.
I want to make a simple model for this engine, I am excited about it, I also want it to not have an engine fairing, I want it to be completely visible, so I will see if I make a model for it...since I like to fly in lonely places, rural streets, I think I have the name "Explorer"...but it's a vague idea, I still don't know whether to make a low wing or high wing model, I'll get into that topic...here are the photos.
What Cox .049 Cox engine is it? Screen30
What Cox .049 Cox engine is it? Screen31
What Cox .049 Cox engine is it? Screen32
What Cox .049 Cox engine is it? 20240310
What Cox .049 Cox engine is it? 20240311
What Cox .049 Cox engine is it? 20240312
What Cox .049 Cox engine is it? 20240313
What Cox .049 Cox engine is it? 20240314
What Cox .049 Cox engine is it? 20240315
What Cox .049 Cox engine is it? Empty Wow!wow! Wow! Wow!
Post  Boats13 Thu Mar 14, 2024 2:34 am
You're an artist, sir. I have the privilege of knowing a gentleman that is an artist building radio tx's, boards to final touches. I used to build Jeeps when I was younger and I felt they were my artistic outlet. I welded frames, roll cages, bumpers, hitches, anything else the we needed or rusted out! But, sir that was beautiful in form and quiet function! Conventional theory says that long intake tubes help build torque through air velocity. Shorter intake tubes help with throttle response (less mass of air to change the velocity) and help top end hp, at the expense of torque in the low to mid range. Who needs torque on a small high speed two stroke motor?! I could see that on a diesel swinging big ole prop at low rpm and its being slow to accelerate anyway, overcoming the flywheel effect... You, sir made an art piece with that muffler. Hat is off in respect!
CT Woods
Boats
Boats13
Boats13
Post  MauricioB Thu Mar 14, 2024 1:14 pm
Mr. Boats13 , thank you very much for your words, it is comforting to know that these artisanal works are valued. They are very exciting to do and always make you think and solve problems, which is very entertaining.
Thanks for the information on the intake pipe, I completely understand what you are saying. Thanks again!
