» Purchased the last of any bult engines from Ken Enyaby getback Today at 8:24 am
by rsv1cox Today at 8:05 am
by rsv1cox Yesterday at 4:21 pm
by 1975 control line guy Yesterday at 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
by TD ABUSER Mon Nov 18, 2024 12:30 pm
by rsv1cox Sun Nov 17, 2024 7:40 pm
by rdw777 Sun Nov 17, 2024 7:03 pm
by amurphy6812 Sun Nov 17, 2024 6:43 pm
Mesh screen .049 Cox engines
I have been looking for one of these. When our old friend redbaroness put one up BIN for $22 I jumped on it.
This one appears to be no prize, one NIB would be a prize. Looks like the mesh seam is situated at the front, not a good look and is frayed a bit. Get's here next week.........maybe. But...........how do you remove the cylinder? Top fin slots didn't arrive until the slit cylinders, then only later.
From Sitter/Dannels:
"Painful burns"..................Poor babies out there. I was lucky to escape with finger whacks and just a little loss of blood.
Re: Mesh screen .049 Cox engines
Last edited by Marleysky on Mon Nov 15, 2021 12:47 pm; edited 1 time in total (Reason for editing : added picture)
Do what Marleysky says.
Heat the cylinder up and then I would use the glo plug wrench on the glo plug and see which comes loose?
If the glo head unscrews then remove it and then file flat spots on the cylinder to where the Cox wrench fit the cylinder.
They probably assembled the screen over the cylinder then screwed the glow head into the cylinder, then screwed the cylinder into the crankcase and tightened the entire assembly with the wrench on the glow plug.
Then it was your problem to get the cylinder off, because I think the glow plug will come loose first. (any bets?)
That is what I would do.
sosam117- Diamond Member
Here's another recipe, Bob(like you need one).
1. Heat the glow head(to expand and tighten it to the cylinder)
2. Heat the crankcase(to expand the case threads)
3. Try the head wrench to loosen the cylinder.
4. If necessary, try the inverted canned air trick.
Chilling the cylinder tightens it to the head and shrinks
the cylinder in the case. Got to work quickly to beat the
heat migration between parts. If all fails, hit the cylinder/case
threads with some sort of penetrating oil while its hot, and try
again tomorrow. If the head comes lose, you're probably going
to have to try the leather strap, or your choice of cylinderectomy.
I envy you Bob. I've never faced this challenge.
Good luck,
Good luck,
dckrsn- Diamond Member
Cool you got one coming , i have i think two of them and have sold about the same till I realized I should keep some for ME ! lol Maybe you want have to take the cylinder off ?!
Thanks all..........tricks of the trade.
Maybe I won't have to take it off. Depends on how castor locked the crank shaft is. I'll probably just run it once then mount it on one of those plastic mineral stands.
» Venturi without mesh screen (installation) --- Enya Rear Induction engines too!
» .020 Mesh screen cylinder
» Cylinder Mesh Screen Size
» Screen for a Tarno carb
» The mesh Babe Bee and a slightly bent prop
