Screen for a Tarno carb Cox_ba12
Screen for a Tarno carb Pixel
by Admin Today at 1:35 am
» Engine choice
Screen for a Tarno carb Empty
Screen for a Tarno carb Empty Screen for a Tarno carb
Post  balogh Fri May 24, 2019 2:13 pm
Screen for a Tarno carb 20190515
I am hoping this make-shift screen I improvised and CA glued to a Tarno carb will boost the fuel suction power of this TD051 without deteriorating the top rpm..
What do you think? Very Happy
Screen for a Tarno carb Empty Re: Screen for a Tarno carb
Post  1/2A Nut Fri May 24, 2019 4:38 pm
You will just have to run it and see, the question is do you have good data on that particular prop / fuel combo to compare
with it now? Is the temp the same and humidity etc.
Popcorn
Post  Mark Boesen Fri May 24, 2019 7:27 pm
Center of carb is higher then fuel tank, if you could rotate engine it might help with draw?
Post  balogh Sat May 25, 2019 1:26 am
Thanks Brad and Mark...it is at the end of the flight when the mixture gets a bit lean that I want to avoid. Unfortunately the bolting to the firewall is asymmetric plus the position of throttle rod is fixed so I cannot rotate the engine mount to lower the carb position...we will see..on my TeeDee 09 the similar screen addition helped the fuel draw.
