Pageboy Build Cox_ba12
Pageboy Build Pixel
by rsv1cox Today at 10:46 am
by MauricioB Today at 10:29 am
by getback Today at 7:48 am
by getback Today at 6:39 am
by Kim Yesterday at 9:18 am
by Admin Yesterday at 1:35 am
» Engine choice
Pageboy Build Empty
Pageboy Build
Page 1 of 6 1, 2, 3, 4, 5, 6  Next
Pageboy Build Empty Pageboy Build
Post  rdw777 Tue Oct 11, 2022 4:40 pm
By Ken Willard
Pageboy Build 143c7110
Was designed for .010 but I’m going to try it with PeeWee .020 RC with heli back plate… The .020 is only about 10 grams heavier and has the throttle ring if things get a little too spicy….
I made the following changes for three channel since it was designed as single channel:
Removed all but a scootch of negative incidence in the stab…Took out about half the engine down thrust….Left just a little right thrust…. Reduced dihedral about 25%… Added just a little area to the rudder……If anyone sees any red flags with these please let me know…
Also am giving it a Schoolboy type wing rather than the single surface wing on the plan..I also gave it one more inch of span (“16).
Pageboy Build A36e7410
First time to try fishing line hinges…Seems like a neat system
Pageboy Build Bc2e7f10
A couple more Ken Willard designs I built in the past…. Pulled some old photos from RCG….
Schoolboy and Schoolmaster….Both were great flyers which give me good confidence for the Pageboy…Just smaller and faster… More to follow as I get shop time…
Pageboy Build 06500110
Pageboy Build 48ff8f10
Pageboy Build 515aef10
Pageboy Build Empty Re: Pageboy Build
Post  GallopingGhostler Tue Oct 11, 2022 7:39 pm
Actually from what I understand, both the Pee Wee .020 and Tee Dee .010 produce roughly the same power. Pageboy at 12 inch wingspan is going to be a hot little flier regardless the engine.
I flew Ken Willard's 20 inch wingspan Roaring 20 (downsized Top Dawg) with a Cox Pee Wee, and it was a total blast to fly. It was the best match for the Pee Wee and 5.25x3 Top Flite white nylon prop, would do all the rudder only stunts, yet was fairly easy to manage.
You could mount the prop backwards to reduce thrust on the first couple flights until getting the hang of it, then it is peddle to the metal. Very Happy
Post  andrew Tue Oct 11, 2022 8:24 pm
Looking forward to this build! I've never been drawn to planes under about 36" span, but they do have their admirers. You have a good start on getting another one together -- waiting for pics.
As an aside, until Outerzone, HPA and Aerofred became available, I had never realized that Ken Willard had designed so many float planes.
Post  rsv1cox Tue Oct 11, 2022 9:31 pm
A little more information on the fishing line hinges Robert, a new one on me.
Love the vintage photos. 35mm or 110. I have many pictures of my old builds too slightly grainy and a bit out of focus gives them character.
Post  balogh Wed Oct 12, 2022 12:21 am
Robert, I like the way you build the Pageboy and cannot wait seeing or hearing of its maiden flight.
I built and flew a Pageboy with 010 TeeDee on 2 channels a couple years ago, it was a ball to fly. Mine had to retire after the cowl area, not properly proofed against fuel, got soaked in castor after the many flights it made.
I like the fishing line hinge concept. Less risk of ruining the stab and rudder with an inaccurate,  off-center cut for a normal hinge. I suppose you push a needle into the balsa to make the nest for the fishing line, that you glue then in? Is that CA or epoxy glue that you use there?
Post  getback Wed Oct 12, 2022 5:40 am
So your putting the school boy wing on the pageboy is that correct ? The plans for the schoolboy are more clear for assemble to me , your off to a good run on it . Popcorn
Post  Kim Wed Oct 12, 2022 7:29 am
Also checking in to say how cool this project is!
Post  rsv1cox Wed Oct 12, 2022 8:02 am
What's your Pinboard Robert?
Pageboy Build Pinboa10
Still interested in those hinges, I must have lived under a rock as I haven't seen that type before. You must stiffen them in some way.
Post  getback Wed Oct 12, 2022 8:22 am
Post  rdw777 Wed Oct 12, 2022 1:47 pm
Thank you for your kind support Gentlemen , Appreciated,
I looked at a video on the fishing line hinges and melted in my own “that seems about right” and just used what was already in the shop…. I had some 10 lb Spider Wire that measures about .005…. No small needles around so I used a piece of .010 metal guitar string and made a little drill by sharpening the end with a rotary disc…I practiced on some scrap 1/16 balsa to I got the hang of it then clean the line with alcohol and glue with thin CA…. Then satisfied myself that it was an OK bond by trying to pull it out…
Pageboy Build 240e1810
So then on the fin/rudder I marked with pencil the lines to follow and drilled the parts before rounding were they will hinge, It’s easier to find center that way…I pushed in the fin side hinges first (4 or 5 mm) then glued and left them long …. Then trimmed what was hanging out to 4 mm….The line cuts most cleanly with a very sharp knife and supported by a wooden block …
Then fit lines into the holes in the rudder and CA’d them too… The trick obviously is to not glue them together so I used a little gluing tool I learned about doing some indoor FF rubber..,It’s just a couple of straight pins bent and bound to a stick to be able to hold a tiny drop of glue… Very controllable this way..,,
Pageboy Build A8ae1110
I deflected the rudder about 45 degrees while gluing to have access and try and keep the gap as small as possible
Pageboy Build A3365f10.
The hinge is very free and I cannot see any evidence of the CA making a hard or brittle place on the line… It’s pretty strong material…. I will keep an eye on it though…
Eric, The original wing for Pageboy is a one sheet affair with exposed ribs hanging in the breeze…. The Schoolboy type from the same designer was similar but also sheeted on the bottom and has a better leading edge… I remember my Schoolboy being able to penetrate pretty stiff breeze so I though it would be good for this one and be more warp resistant as well…
Bob, My entire work surface is just 1/2” drywall… Nice and flat and you can push a pin in anywhere although I have to use a thimble (Drome  lol! )… I have smaller pieces for glue ups so I can clear the big table while they are drying…
One more fly by from the Schoolmaster on a pleasant summer evening at a local schoolyard many years ago….
Pageboy Build B5b7ef10
Post  rsv1cox Wed Oct 12, 2022 2:34 pm
Thanks Robert, looks like a great way to do hinges, clean but not easy. I got on-line and watched this video:
https://www.bing.com/videos/search?q=fishing+line+hinge&view=detail&mid=D45EAE3F3A56EC67A275D45EAE3F3A56EC67A275&FORM=VIRE
It seems when installing you should maintain tension on the line, glue in one end, pull on the other. Would work fine on open-framed structures but on closed like your vertical stab? How do you maintain tension for a tight fit? It looks like something I would like to try as I'm always in a fight with them.
I use foam board or the back side of suspended ceiling tiles. Foam board works well but the fumes from CA quickly eats it.
Pageboy Build P1014283
Post  rdw777 Wed Oct 12, 2022 6:48 pm
Hi Bob, Yes, That was the same video I watched…. So my work around on the final join was too push the two surfaces together and wiggle them around a bit to seat best possible…. Then deflect just enough to expose the line that needed a dot of CA… The glue applicator helps alot…. You can see it wick into the hole…. Some CA may get on the other half but it’s such a minute amount it doesn’t threaten to glue them together …. You can fiddle with it scraps of balsa if you would like to try it… Got the stab/elevator done….
Pageboy Build 29c8fe10
Post  balogh Thu Oct 13, 2022 3:45 am
Robert, very neat work on the hinges and in general!!!
I thought you first cover the rudder, stab and the elevator flaps in heat shrink material like Oracover, and apply the hinges afterwards. That way, the edges of the flaps - exposed to precipitating castor - would also be sealed by the heat shrink material. If the hinges applied first, and the heat shrink afterwards, the edges remain naked and exposed to castor, and that will seep into the balsa real quick and destroy it, as you may well know..
Of course if you fuel-proofed the balsa, then hinge application can also be done on the naked balsa surfaces before the heat shrink cover film addition.
Just my humble thoughts...
Post  rdw777 Thu Oct 13, 2022 5:32 pm
Thanks Andras, I appreciate your suggestions Very Happy…. I plan to do a dope finish with tissue trim…. Probably not as durable as film but I’ll give it a diligent cleaning after use …. I have a good stock of Japanese tissue that holds its color well….
Post  balogh Thu Oct 13, 2022 5:53 pm
Thanks Robert, dope and Japanese tissue make it totally fuelproof indeed. Back in the 70-s I built a full wing CL plane with dope and tissue...I remember how nice the tissue spanned between the ribs like a curved, saddle surface and how strong it held..
Post  Yabby Thu Oct 13, 2022 6:14 pm
balogh wrote:Thanks Robert, dope and  Japanese tissue make it totally fuelproof indeed. Back in the 70-s I built a full wing CL plane with dope and tissue...I remember  how nice the tissue spanned between the ribs like a curved, saddle surface and how strong it held..
lol! Yes, I too remember for many years using dope and tissue on my planes and in my memory it was easier to do than the solarFilm type coverings that became available. I always found the joins and seems and such with the tissue easier to make nice and neat and hide. I have always found the heat shrink coverings difficult to not have the odd bits from joins and curves here and there sticking up. I also like the look of Tissue and dope better than the heat shring type coverings, but thats probably nothing more than getting old and fading memories holding on to those early teen years flying models. Huh... Very Happy
cheers Flying sunny
Yabby
Yabby
Yabby
Post  GallopingGhostler Fri Oct 14, 2022 1:08 am
I agree with Robert on the very light finish of clear doping the balsa surfaces with color trim. There isn't much wing area on the Pageboy, so keeping it light so it flies well will be essential.
Regarding tissue covering like Essaki and Silkspan, I was never a fan of those on an R/C aircraft because it didn't take much to puncture the finish especially in rougher field conditions like we have here. My first experiences with Silkspan was my 1965 Walt Musciano Scientific stand-way-off-scale Grumman F6F Hellcat with built up fuselage and wing. First experiences with tissue was in 1964, by the time I finished 6th grade, built at least a dozen stick and tissue kits to include Ed Lidgard's 32" Comet Sparky. Best flying was Comet's 18" wingspan North American P-51A Mustang (one with the turtle deck fuselage), because it was framed very light.
Back in the late 1970's, I tried lightweight silk for the first time on the wing of my 36" Sterling Minnie Mambo. With a Pactra Solar Film covered fuselage and tail feathers in transparent yellow trimmed in color, the silk wing kept it light, was an excellent flyer. The Cox R/C Bee engine made it really move out, 3 position throttle on Ace rudder only pulse, could do all the single channel aerobatics with ease.
Lightweight is the way to go with these half-A sport models.
Post  MauricioB Fri Oct 14, 2022 3:48 am
rdw777:
I am enjoying this construction!...beautiful how this work is going!
The hinges made with fishing rope is genius! I really would not have thought of it and what a great idea in itself it is!
Very applicable to small models without the risk of breaking anything, just a puncture in the center and that's it!
Great idea, thanks for sharing it!
Post  rdw777 Fri Oct 14, 2022 1:46 pm
Gracias Caballeros, Tus palabras son muy amables Very Happy
I have a good stock of Esaki tissue left over from rubber free flight days… The Schoolboy in the photo was Esaki trimmed….Unfortunately it’s not made anymore….Certainly not as durable as plastic film….It adds practically no weight though and maybe just a bit of strength to balsa sheet….. Trade offs….I do think it goes with the vibe of these vintage designs….
I’m glad the fishing line hinge is liked but please proceed with caution if any decide to try it….First time for me but I think it should be OK… I usually use a figure eight thread hinge on small models but the fishing line hinge appeared to me to withstand the rigors of gas powered flight better…. Yes, It was a bounce off Levent’s centering tool post, Thanks for the idea Very Happy
Post  Yabby Sat Oct 15, 2022 3:42 pm
really nicew build Robert. I very much like the high quality yet pragmatic approach you have to your build. The way you have done the hinges is excellent! cheers I could see myself at least giving the stiched with fishing line method try now. whereas previously I couldnt really see myself being able to do it. gtreat build and I will continue to follow and keen to see/hear how it flies when all is complete and ready. all the best with it! Thumbs Up
cheers Flying sunny
Yabby
Yabby
Yabby
Post  rdw777 Sun Oct 16, 2022 11:04 am
Thank you Yabby! Will try to do justice to the nice little design 😊
Post  rdw777 Fri Oct 21, 2022 9:59 am
Got the wing mostly completed…I gave it 3/32 washout on the tips and faced the leading edge with bass because of the rough field it will fly from…. Constructo photos….
Pageboy Build A46ced10
Pageboy Build F8bb7210
Pageboy Build 316b3910
Pageboy Build 456cc210
Pageboy Build Eca5f910
Pageboy Build 12d4b910
Pageboy Build 98239210
Pageboy Build Acee1b10
Pageboy Build Edd16210
Post  GallopingGhostler Fri Oct 21, 2022 10:06 am
Exemplary wood craftsmanship, Robert, kudos! Thumbs Up Even the wing tips are hollowed out, ought be really light, with bass wood leading edge, should be able to handle the briar patches well. It looks like a downsized Schoolmaster. Cool
Post  rsv1cox Fri Oct 21, 2022 10:25 am
Norm Abram couldn't have done it better. I love the wing!!
Post  balogh Fri Oct 21, 2022 10:50 am
This is just beautiful, Robert. Smooth and soft surfaces and contours.
I too use hard leading edges because of the rough, weedy terrain I fly on. If nothing else like hardwood is available, then I use a small diameter round or square carbon rod that well submerges into the foil contour.
