Piston reset. Cox_ba12
Piston reset. Pixel
by getback Today at 7:14 am
by getback Today at 7:02 am
Piston reset. Empty
Piston reset.
Piston reset. Empty Piston reset.
Post  Cribbs74 Fri Feb 24, 2012 8:31 am
Fellow .049ers,
I was resetting some .049 pistons yesterday and I was having a little trouble with one. So I took it into the light and I compared it with a TD one that I had just reset. I noticed that the ball cups were different. The TD one had a bevel on the cup and the one I was having trouble with had a flat edge on the cup. I always assumed the ball cups were the same. Is this piston an anomally or is it something standard? And no it's not a 3 piece piston.
The trouble piston is the one out of my Tach race engine. I will post up some pics later.
Piston reset. Empty Re: Piston reset.
Post  Kim Fri Feb 24, 2012 8:48 am
I promise that I DIDN'T swap it out !!!!!!!!!!!!!!!!!!!
Post  Cox International Fri Feb 24, 2012 9:00 am
TD, Medallion and reed valve engine pistons are indentical with only a few exceptions (Venom, Killer Bee, 051 Medallion).
Over the past 50 years Cox did manufacture a few different versions (tapered, thin-walled) but essentially 95% of pistons made in the last 50 years are the same.
However, Cox used different manufacturers for the blanks and they may have changed the ball-joint design over time.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Cribbs74 Fri Feb 24, 2012 9:21 am
Kim wrote:I promise that I DIDN'T swap it out !!!!!!!!!!!!!!!!!!!
Sure Kim I believe you.........
You saw what an awesome engine it was and just had to have that piston! Very Happy
Nah, it was the same piston with the sloppy ball socket.
Post  Surfer_kris Fri Feb 24, 2012 9:24 am
I have seen a QB piston with a square look to the ball join. That engine was used (and abused) and I thought perhaps they had used a poor piston reset tool and deformed the ball joint...
Has the piston been reset before by someone else?
I'll see if I can find the QB piston again...
Surfer_kris
Surfer_kris
Post  Cribbs74 Fri Feb 24, 2012 9:26 am
Cox International wrote:TD, Medallion and reed valve engine pistons are indentical with only a few exceptions (Venom, Killer Bee, 051 Medallion).
Over the past 50 years Cox did manufacture a few different versiouns (tapered, thin-walled) but essentially 95% of pistons made in the last 50 years are the same.
Ok, thanks Bernie. That makes sense. I did manage to remove most of the play using your tool. It took a little more effort but, it is much better. I probably could get rid of all the slop if needed, I was being cautious as this was my first attempt at resetting an .049 piston. I didn't want to create a domed piston.
Post  Cribbs74 Fri Feb 24, 2012 9:29 am
Surfer_kris wrote:I have seen a QB piston with a square look to the ball join. That engine was used (and abused) and I thought perhaps they had used a poor piston reset tool and deformed the ball joint...
I don't think it was reset before, I got that engine in trade when I was a young teen and it was in a box of HO trains. So I doubt that kid even knew anything about it.
Post  PV Pilot Fri Feb 24, 2012 10:39 am
Ok, it probably wasen't reset then after reading above. You can square that edge if it is smacked way off center or the reset tool bounces and then comes back down while doing it's thing. A person usually mashes one side or the other of the cup flat with the rod cutout area of the tool if it is done incorrectly and allowed to bounce. Then it's basically trash.
Piston reset. Microscopepics002-1
A pic of a NIP TD piston and rod area I snapped last weekend under the microscope. 60X magnification.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  EXModelEngines Fri Feb 24, 2012 10:41 am
It really depends upon how they were swaged on different production runs. The tooling may have been slightly different during the piston/connecting rod assembly process.
I have seen some with a larger bulge than others, as well as some that appeared to have a flared edge. If you are resetting, I would just be cautious and tap lightly first. Once you get a feel for the individual piston, it will be easier to 'tighten' up.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  Cribbs74 Fri Feb 24, 2012 10:56 am
PV Pilot wrote:Ok, it probably wasen't reset then after reading above. You can square that edge if it is smacked way off center or the reset tool bounces and then comes back down while doing it's thing. A person usually mashes one side or the other of the cup flat with the rod cutout area of the tool if it is done incorrectly and allowed to bounce. Then it's basically trash.
Ok, I get what you are saying. I am unable to open that pic up for a visual though.
When I get home tonight I will post a couple pics. Thank you!
Post  PV Pilot Fri Feb 24, 2012 11:20 am
It wont click open Ron, all my pics are hosted on photobucket and I edit them to fit if needed. Still working on my lighting under the scope and I think I have found a nice fiber optic light source used in gunsmithing to clear the next batch of pics up a bit.
PV Pilot
PV Pilot
Post  Surfer_kris Fri Feb 24, 2012 11:57 am
Here is a picture of the QB piston with a "square" fitting over the rod. It did reset fairly okay but one can see that the reset tool has only touched the outer rim.
Piston reset. Img_1624
Surfer_kris
Surfer_kris
Post  PV Pilot Fri Feb 24, 2012 12:51 pm
It looks like the reset tool might have nicked the edge on the right side there, pushing a little more material tabbed inward.
Either that or it's some gunk sitting there.
PV Pilot
PV Pilot
Post  Surfer_kris Fri Feb 24, 2012 1:32 pm
It is the different shape that was trying to show, but it does not show that well in the image. Here is an image of the more common shape, they are clearly machined differently from the start;
Piston reset. Img_1625
Surfer_kris
Surfer_kris
Post  engine049 Fri Feb 24, 2012 2:11 pm
Surfer_kris wrote:Here is a picture of the QB piston with a "square" fitting over the rod. It did reset fairly okay but one can see that the reset tool has only touched the outer rim.
It looks like your making Witches Brew... AHAAAAAAAA Some Frogs Breath, Eye of Newt! LOL (NMB4Christmas)
engine049
engine049
http://TreeTiger.com
Post  altidsulten Fri Feb 24, 2012 3:06 pm
Slightly off this topic, i found the conrods to be hardened on some older piston, while they are soft on the surestarts.
I was building a "V-Bee" and was experimenting with some cylinder sets when i noticed that.
Regards
Thomas
altidsulten
altidsulten
Post  Cribbs74 Fri Feb 24, 2012 3:32 pm
That's what it looked like! Kinda like not enough material was removed from around the socket.
The reset tool will only reset a piston like that so far before it bottoms due to the conical shape of the tool. That's not an .09/.15 cylinder clamped in a vice is it? Shocked
Thank you for the pictures.
Post  Surfer_kris Fri Feb 24, 2012 4:50 pm
Don't worry, that's very soft rubber jays on a hobby vice, held only to enable a picture...
Surfer_kris
Surfer_kris
Post  RknRusty Fri Feb 24, 2012 5:49 pm
While we're on the subject, I want to ask, how many taps/rotations on average does it take for you to tighten up a piston?
Maybe someday I'll try again.
Post  Cribbs74 Sat Feb 25, 2012 12:11 am
RknRusty wrote:While we're on the subject, I want to ask, how many taps/rotations on average does it take for you to tighten up a piston?
Varies Rusty, for me it was like 3-4 taps with my son's tiny hammer. That was for the TD piston. It took quite a few more taps with the other piston.
Upon further inspection I see that both my TD and proddy engine shared the same style piston cup. So that throws out that theory!
So now I am not sure why it was tougher on the one.
Post  RknRusty Sat Feb 25, 2012 2:26 am
I'm up to 50 taps/rotations and never see a change. If I increase the force of my taps I usually mushroom the piston. I use the tool on a clean flat 50lb anvil on the concrete shop floor. All the ones I've done have the "regular" rounded ball cup. Since I have yet to ever successfully reset one, I think I'll back up and re-think my whole method. Or I could blame my tool... yeah that! That damn tool. Laughing
Post  GermanBeez Sat Feb 25, 2012 3:29 am
i think your hammer might be too big. i always use a very light hammer for Cox engine matters,
i think it weighs around 5 ounces or something.
GermanBeez
GermanBeez
Post  RknRusty Sat Feb 25, 2012 4:11 am
I use a tack hammer too. I don't know the weight, but it's a fairly big tack hammer. It has a nice flat face, good quality. I was kidding about blaming the tool, but it's possible it could be deformed. Next time I try resetting a piston, I will video it for CEF expert analysis. Y'all can tell me what my problem is. It's actually kind of embarrassing, as I consider myself a good technician/mechanic.
Post  GermanBeez Sat Feb 25, 2012 4:17 am
i bet you are Smile
GermanBeez
GermanBeez
Post  Surfer_kris Sat Feb 25, 2012 4:25 am
There shouldn't really be any problem with resetting the piston. If you use 50 strokes and cannot see a difference, then you are not hitting hard enough. If an increased force then deforms the piston itself, it sounds like something is wrong with the tools. Check the center part of the little anvil and also have a look at the end surface of the tool itself. The end should only be slightly hemispherical in order to shrink the piston part around the conrod. If the end is too flat you might actually hit the conrod itself and if it is curved too much it will not apply the force correctly. There might then be nothing that will give, hence the piston itself gets deformed.
The picture with a cut-up engine from "Altid sulten" (means "Always hungry" I believe...) shows the piston part quite well.
There is also the TD image at Aerotools;
Piston reset. Cox_td_section_large
Surfer_kris
Surfer_kris
