Jerobee Alfa T33 Can Am.... It works! Thanks Jason - Page 4 Cox_ba12
Jerobee Alfa T33 Can Am.... It works! Thanks Jason - Page 4 Pixel
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Jerobee Alfa T33 Can Am.... It works! Thanks Jason - Page 4 Empty
Page 4 of 4 Previous  1, 2, 3, 4
Jerobee Alfa T33 Can Am.... It works! Thanks Jason - Page 4 Empty Re: Jerobee Alfa T33 Can Am.... It works! Thanks Jason
Post  Cribbs74 Fri Jan 29, 2021 6:01 pm
I had the flywheel and clutch installed. There was a load on the engine just not representative of what the actual load would be. It wouldn’t be any different than when installed in the car and the clutch not being engaged. At least at idle anyway.
J’ai fait installer la roue volante et l’embrayage. Il y avait une charge sur le moteur tout simplement pas représentatif de ce que la charge réelle serait.Il ne serait pas différent que lorsqu’il est installé dans la voiture et l’embrayage n’étant pas engagé.Au moins au ralenti de toute façon.
Post  davidll1984 Sat Jan 30, 2021 9:10 am
The flywheel Not This is not enough in fact the car must be complete is ready to drive we must start very rich on the floor then lean mix as the cars run To lean the engine over rev and stop from To lean To hot the low jet neadle is the last To set and it have To exit the niple inside the carburateur at ful trotle try set carb wit prop if Not redy
Post  Cribbs74 Sat Jan 30, 2021 5:59 pm
Next run will be mounted in the car. Jason is sending me a muffler throttle and I think that will work out, also easier when I go to rig the servos. Thanks
Post  Cribbs74 Wed Feb 03, 2021 4:52 pm
Success! Still some fine tuning to do, but it works! Way better than the Tarno. I was getting pretty bummed. Special thanks to Jason_WI for the throttle muffler. Enjoy the short video.
Post  Jason_WI Wed Feb 03, 2021 5:03 pm
Looking good. When the servo is setup I always had to have the brake engaged to stop it at low idle. This was with the Cox/Sanwa pistol grip controller. Basically you could never shut off the engine with the throttle. At least that’s the way it’s setup in the manual page I posted above.
Jason_WI
Jason_WI
Post  davidll1984 Thu Feb 04, 2021 12:44 am
Cool u get it To run Thumbs Up y stil wonder wat was the trouble wit the tarno carb ?? y have never use one. Me y like the wasp .061 carb bether easy To get (Find )the tarno carb To expensive y have very Good result wit the wasp carb cox .05 tee dee carb Not To bad work just fine  just hard To fit on cars nead modification To the body of the carburateur Now the engine look happy wit the exaust ring if u give 2 try To the carb vidéo the engine runing  wit This way it would be easier to make a diagnosis  if posible mesure the ventury size of that tarno carb u have use Huh... posible To big for cars engine ???Or modified ventury possible ?? Y was interested in buying one I am not sure now Be willing to pay half the price of a .061 engine just for the tarno carb tink y have To try one at last just for m'y self .....  Y wil look forward for runing vidéo ad weight To the Front if u dont want To do wely  help turn just dont ad weight try as is first wit m'y y have To place batry forward as possible and cars do wely just litle bump make its Front wheels lift of the ground  its like Find A compromise between traction power without adding too much weight on the front because it could break the suspension parts Front hevy wil turn charp and let the rear drift To mutch To mutch To rear and get redy for a take off  RC Plane  Be aware that the little car is capable of speeding Beyond is capability of stay stick To ground at hi speed and The front rises from the ground air flow wil turn the litle Car in plane ready to take off and posible crash Be careful Not To find yourself in a plane instead of a car Doh! Laughing lol!
